Vin # w/ new frame help
Discussion in 'The Hokey Ass Message Board' started by farmergal, Jan 25, 2012.
  1. farmergal
    farmergal
    from somewhere
    Hello All
    We are going to try and sell our all original rolling , running ch***is from our Model A. Of course everyone who is interested wants the ***le and vin# that go along with it. So how do we go about registering the car if we sell the ch***is with the info for the vin? Wouldn't we pretty much screw ourselves by doing that? We live in CT; land of the hellish DMV, etc so we're not really sure how to go about this...never done it before.
    We would have to take it half way across the state to a head DMV department where it would have to p*** their hellish inspection requirements, lots of money and then it would be ***led as composite 2012 ford coupe....not a 1930 ford coupe
    So wtf do we do?
    Any and all insight is appreciated. We were going to sell the entire ch***is with engine and trans just to rid ourselves of it but if it comes down to it we're going to have to keep the frame; sell off everything else on it and then s**** it to prevent it from opping up anywhere else in the entire "system" because we'd be the ones getting screwed...perhaps??
  2. F&J
    F&J
    Don't you dare sell the frame with the ***le to the car.
    You sure don't want to have your car go through Weathersfield DMV as a "composite". It may never p*** inspection.
    The frame; grind off the numbers. sell it for what you can.
  3. farmergal
    farmergal
    from somewhere
  4. Cruiser
    Cruiser
    Keep your VIN and ***le for your new build, there hard to come by so keep them. Sell all the stock stuff off the frame as parts and sit the frame aside. Once you ***le the new frame in your state the VIN on the stock frame will be useless. You might be able to sell the stock frame to someone after you destroy the VIN on the stock frame.
    CRUISER :cool:
  5. brokenspoke
    brokenspoke
    x 2
  6. No, no, no, no, no.
    CUT OUT the portion of the rail with the VIN on it and KEEP IT. If possible, WELD IT INTO THE NEW FRAME. Clean up the welds, let it flash rust on both sides (unless it's boxed and hidden inside), then clean it up and paint it.
  7. farmergal
    farmergal
    from somewhere
    since the engine matches the numbers on the frame would it be okay to let that go?
  8. Cruiser
    Cruiser
    Good idea................CRUISER :cool:
  9. Gerg
    Gerg
    wow i didn't realize that was legal i will remember that for my next car
  10. farmergal
    farmergal
    from somewhere
    big grey areas, big grey areas.....try to stick to the grey areas. Was hoping to get money from the frame being sold as a complete roller but guess thats not an option
  11. Tomcats30
    Tomcats30
    I'd recommend you keep both the engine and frame. Yours match...thats hard to find.
    Don't give anyone a chance to use your numbers!
  12. F&J
    F&J
    No way I'd sell the complete ch***is with a readable motor number here in Ct. You know already, that we don't need ***les. Someone most likely will reuse that number to get an A back on the road.
    Sure you can say that there are plenty of A motors for sale with numbers still readable, but you would be selling a complete running ch***is with a bill of sale stating that it is a ch***is. I don't trust people when it comes to that.
  13. farmergal
    farmergal
    from somewhere
    then we'd grind off the number :) on everything :)
  14. Mr48chev
    He beat me to it. I'd say not only no but hell no to selling the frame and the ***le. The ***le is worth a lot more than the whole stock ch***is at the current time and that is actually what most guys are interested in.
  15. bentbaggerlen
    bentbaggerlen
    Just went though this in CT. And I got my plates:)
    have you already taken the original car apart? and started building your project?
    If not... Take your car, even if it has to be towed or trailered to a VIN check station, ask around some are more then willing to help you out then not.
    The car dose not have to run, or even look like it dose...
    once you get the VIN check, get the required insurance and head to DMV, and get the car registered. There is no inspection required of the car. If you like send me a PM
    Don't sell your ***le!
    If you already pulled the body of the ch***is... and your not to far along... put it back on
  16. Bilt
    Bilt
    I would keep the ***le as said above. In Kansas if you get the state to attach a new vin to the car it will then be registered as the year which they attach the vin....ie 2012. I would rather my paperwork say the original year.
  17. farmergal
    farmergal
    from somewhere
    well if we have to get it registered as a 2012 then it has to go through absolutely misersable state inspections...and it wont ever p*** if we build it as a hot rod the way we want it. dont want it registered as a composite 2012 either... :) I guess we're keeping everything right now and it is what it is. thanks for all the help
  18. Tomcats30
    Tomcats30
    IMO...do not sell or grind the orig numbers off of your frame/engine.
    In a ***le state like MA you might need them for VIN verification.
    If it's been messed with your taking a big risk.
  19. farmergal
    farmergal
    from somewhere
    we will make sure its registered and already gone through that process before we removed anything and sold it.
  20. DualQuad55
    DualQuad55
    from NH
    A friend had his A coupe registered in MA for about 3 yrs when he got a notice to turn in his plates as the car 'was sold' to some one else. Long story short, he used the stock A vin for his coupe, used a 32 frame etc...
    The person who bought his old engine/frame combo put a stocker back on the road with it. Using the stock vin from the frame and matching engine.
    My friend was S.O.L. and lost the argument. He had to locate a ***le elsewhere and re-register his car with a new (to him) vin.
    With out the actual VIN, all you have is a Model A body, not an automobile.
  21. Keep them both (the original eng and frame).
    Once you have done all you need to do to get your ***le (or whatever you want to call it) and insurance and plates ... you need to STILL KEEP THEM BOTH.
    When it comes time to sell ("Oh noooooo, this ones a keeper" :rolleyes:) you may need them in order to verify the vin (either you or the new owner).
    Rules/laws change frequently ... if (down the road) you are required to submit to a vin check and you have sold off every item from your car that actually has the correct numbers (stamped by Ford, NOT by you) you might find yourself in a heap of trouble.
    Picture this ... cop pulls you over for no fenders ... turns out a Model A coupe has been reported stolen during the last 6 months ... the cop decides he wants to check your ***le/ownership against the numbers on your car ... UH OH, unfortunately you don't have any numbers (original Ford stamping) anywhere on your car ... guess who's vehicle just might get impounded this evening.
    Do what you will, but I think it would be foolish to sell the frame or the engine block.
  22. mattcrp1
    mattcrp1
    thats probably the best advice, I have verified a few of these here in CA and the DMV is very strict on this. I have heard about others "making" numbers so you definately dont want to have an unumbered car on the road as someone else mentioned. As a vin verifier i have to physically see the numbers, yes lift the body on these, and do***ent them. good luck to you and let us know how it goes.
  23. A Rodder
    A Rodder
    I wonder if you can do what was stated above and go one step further with the Vin inspection. Can you have it verified and then have the dmv issue a plate or sticker with the state seal on it with your Vin number stamped on it and attach it to the interior body post?
    My tudor has a Washington state issued Vin number that is on a sticker that is attached inside the a pillar door jamb. Something to consider looking into.
    If you could do this the then sell your frame and engine with the numbers ground off.
  24. farmergal
    farmergal
    from somewhere
    Yes we are going to Keep the vin and the paperwork for our use when the new ch***is is done. Figured it's cheaper and less time consuming to buy a new manufactured ch***is that is already boxed and set up to handle a Nailhead so thats why we're selling off the original.
    Boyfriend works in a garage and they can do vin verifications right there. He is going to bring the car to work; and their going to lift the body up and record everything right there before we do any work to it.
    I think we might lean towards parting out the ch***is. ****s to have to go this route but it is what it is
    Sorry for the stupid lame-o newbie questions. Never had to do this before so its all new. Thanks for the insight....
  25. farmergal
    farmergal
    from somewhere
    HA! State of CT put any extra effort in to produce a forma;, state sealed sticker?? HA! that would require too much time and effort for them and it would further prevent them from being the pain in the ***es that they are
  26. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Wishing you luck Farmergal
    I want to see this build happen
    One question to the m***es for ya that I havent seen covered
    Will the DMV be happy about 30-31 original A numbers being welded or stamped on to a new manufactured 32 frame? that dont come with any numbers on them, and isnt originally a 30-31 frame?
    and if so how will that still be a Model A frame you would have under your body?
    how does the DMV justify this move?
    inquiring minds want to know how this works? I may run into this someday soon but im thinking my state would call that "tampering"?
    teach me, dont ***** at me for not knowing..thanks
  27. pasadenahotrod
    pasadenahotrod
    from Texas
    Years ago a friend sent his wife down to the Texas DMV with a handful of Model A ***les to transfer to their name. One of them, 29 A Roadster, was rejected because the VIN number was registered to a 31 Coupe in nearby Deer Park TX.
    These ***les were all issued just after WWII and were trade-ins at a Ford dealership in East Texas. The engine out of that 29 ended up being the current ID for a 31 some 30 years later.
  28. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I wonder about mine too, new '32 frame with a '29 body on it. Do I register it as a '29? Or as a '32?
    I'm going to register it as a '29 as thats what it identifies with, but if someday a '32 coupe body came along and I wanted to swap.......... I guess I'd have a deuce coupe ***led as a '29.
    BTW... I have a '29 frame with numbers, no ***ling and I'm hanging onto it until I feel secure in letting it go (if ever)
  29. choptvan
    choptvan
    ding ding ding! We have a winner. This is the only way to do it IMO. Trying to match an original stamp is near impossible. This looks more authentic. Make sure you place it in the same spot as factory as well.
  30. farmergal
    farmergal
    from somewhere
    ^^^^ but its very illegal to do it that way!
