New member from MO......
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by MO A-Rod, Jan 26, 2012.
  1. MO A-Rod
    MO A-Rod
    from Missouri
    Hello all,
    I've been lurking on here for a LONG time.
    But now that I've actually gotten a hot rod project (1930 Model A) and on here a LOT more, I figured it was time to join.
    I should have done one of these YEARS ago.
    Silly simple, incredible easy to modify and build and I'm just having a blast.
    Started out with a rolling 1930 frame with ***le just before Christmas of 2011 and picking up bits and pieces locally have netted me with an excellent start.
    '30 Model A frame, '47 front axle, spring behind (Model A) on the '47 split wishbones in the front and Model A spring/'47 split wishbones/'47 Banjo in the back, '30 cowl and doors, '30 radiator surround and '40's Ford steelies.
    It's rolling on the '47 axles already.
    Sold the '30 parts to local Model A folks.
    Anyway, I've been doing air-cooled VW's for many, many years as well as turbo Buick Regals and various Chevrolet's.
    Can't wait to get this old rod on the road.
    Thanks for all the info I've already put to use!
  2. brushape
    brushape
    Welcome from springfield mo
  3. toolman1967
    toolman1967
    Welcome from Southern Illinois, sounds like a cool start to your hot rod.
  4. Welcome from Minnesota--Your off to a good start! Post some pics when you can. Love the model A projects. GOOD LUCK
  5. Junk Hunter
    Junk Hunter
    from The Ozarks
    Sounds like you're off to a good start!
    If you haven't found a body for that A yet, I've got the back half of a '30 coupe you might be interested in. If so, shoot me a PM.
    Welcome to the HAMB!
  6. Molonewolf
    Molonewolf
    Welcome from Willow Springs Mo. ,I too am new here. Have you joined the Mo. group?
  7. MO A-Rod
    MO A-Rod
    from Missouri
    Hello all!
    Here are some pics!
    First is from putting the frame back on "all fours" last Sat., Jan. 21.
    Second is of the body parts sitting on it for measurements on Jan. 17.
    Body will be channeled 3" at least, by the way.
    Plan is for RPU rear quarters and rear panel.
  8. MO A-Rod
    MO A-Rod
    from Missouri
    Scored an enclosed '28-29 pickup cab rear section (roof to bottom) this afternoon!
    The last piece of my "puzzle".
    Less than 4 miles from my house, too!
    Needs work but nothing I can't handle.
  9. 60 ford
    60 ford
    Welcome from Indiana.
  10. khead47
    khead47
    Welcome from Mi.
  11. robleticia
    robleticia
    Welcome from Texas!
  12. ct1932ford
    ct1932ford
    Welcome from CT!
  13. MO A-Rod
    MO A-Rod
    from Missouri
    Thanks, all.
    I'm going to town (time permitting) on this thing.
    Don't know what I'd do without the HAMB.
  14. MO A-Rod
    MO A-Rod
    from Missouri
    Well, I've been driving it every chance I get since I got it on the road in June.
    All I can say is I should have built one of these LONG ago.
    It drives fantastic (tracks straight, NO shakes or shimmies) but rides like a log wagon. LOL :rolleyes:
    The response I've gotten while out and about is priceless. The kids love it, bikers go nuts over it (on the road is always waves and thumbs up).
    It's as reliable as my daily driver.
    A big thanks to HAMB for the tech and input!
    Couldn't have done it without you.
  15. dawford
    dawford
    Kind of a big jump from 2/9/12 to 11/10/12 from bare frame and body parts to running rod?
    if you have time fill us in on some details of the build, engine, trans, rear end, brakes and ch***is build.
    It looks great and I'll bet when you get the spring weight adjusted to ride better it will get lots of driving time.
    Probably starting next spring.
    I had forgotten that I had this thread on my list to follow and was surprised to see it pop up after so long.
    I guess if I wasn't on the Hamb so much and was working more on my projects I would also have one of them on the road.
  16. kennkat
    kennkat
    Hello & welcome from Twain Harte, California
