Hot Rods THREE SPRINGER , 3 SPRINGER picture thread
Discussion in 'The Hokey Ass Message Board' started by bct, Apr 24, 2011.
  1. Uh, I have a '28 and a '27 axle if'n you want to swap :)
  2. Bigcheese327
    Bigcheese327
    I think the Dodge tube makes a pretty good stand in for the rarer Chrysler or Franklin pieces.
    -Dave
    Lil'Alb and bct like this.
  3. bct
    bct
    made a door bottom....it was my first time separating a skin from the frame.....way easier than messing with it all as one piece
    dash is welded and i can't wait to get the steerin column thru the bottom hole
    harley wind screen chopped up ....i like the shape but might just use a single flat piece after all .
    brEad likes this.
  4. Bigcheese327
    Bigcheese327
    That dash is great! The windshield looks good too, but I'd like to see it from further back.
    -Dave
  5. HRS
    HRS
    Why are the springs moved to the outside of the frame rails and not under the rails like stock?
  6. Hackerbilt
    Hackerbilt
    Narrowed body requires narrowed frame and then you have a full width axle to deal with.
    The simple (and traditional) way to make it all work was to offset the springs outboard from the narrowed frame. :)
    volvobrynk likes this.
  7. alchemy
    alchemy
    Plus it gets them lower.
  8. Bigcheese327
    Bigcheese327
    The Chevrolet 490 ch***is had the springs outboard of the rails from the factory.
    -Dave
  9. Dave,
    Is that yours :eek:?!
  10. Bigcheese327
    Bigcheese327
    No, but it was offered to me quite reasonably by a VCCA’er in Ohio. I seriously considered it, but ultimately decided it would be too hard to come up with 490 sheetmetal for it to wear. I occasionally regret it, but I don’t think my wife would have understood.
    -Dave
  11. '24 and earlier Chevs used the same 1/4 elliptic ch***is. Bit of useless info, Stu Hilborn's streamliner used a '24 ch***is.
    bct likes this.
  12. NOTHING useless about that, Jimmy :)
  13. bct
    bct
    funny i looked at one of those yesterday upside down in a junk pile and was wondering what one looked like upright w/axles....it appeared very wide but would be awesome narrowed.
  14. It'd make for a fantastic sprinter!!!
  15. HRS
    HRS
    Thanks for the info about the outside mounted springs.
    I figured you could gain a few inches of drop, but didnt think about the narrowed bodies.
  16. Gremlinguy
    Gremlinguy
    Cool thread. I need more info on these front set ups.
  17. David Chandler
    David Chandler
    It might be a good use for old F1 or Dodge axles of the same era.
  18. twofosho
    twofosho
    Glad to see this thread wasn't a how-to on putting a 9" Ford rear end mounted on semi eliptics under under a SBC powered Ford hot rod.
    Has anyone started a thread on four spring (semi-eliptical) race cars or hot rods? Seems like most race cars up until the mid 30's used a ch***is with a leaf spring at each corner.
    AHotRod and volvobrynk like this.
  19. Tony Travers
    Tony Travers
    Back on the first Page there is a pic - "Chucks Two Man" that was my inspiration.
    I'm using a pair of bobbed '29 Willys frame rails with parrelell leaves up along side the rails, a Chevy axle, Model A rear cross member and spring, as in line six, a 53 Victoria rear, a slightly larger than stock 27 T body and an unknown rectangular tank. I'm not pretending I'm replicating some thing from the 30'sor 40's but building a car that pays tribute. This will finish as a regularly driven road car.
    Bit more work done since this but no pics at the moment.
    Cheers
    Tony
    volvobrynk and AHotRod like this.
  20. youngster
    youngster
    from Minnesota
    Nice build. Cool radiator shroud. What's it from? Keep us posted on your progress.
    Ron
  21. sololobo
    sololobo
    Killer pix, thanx! ~sololobo~
  22. Hmmm, is that a Morris Bullnose Cowley radiator shell and body?
  23. Tony Travers
    Tony Travers
    Yes Cowley radiator shell
  24. metaldave
    metaldave
    from michigan
    I don't know why 3 springers arent more popular . Guys use quarter elliptic's in front and that seems like pretty poor engineering to me. I don't know of any car that used quarter elliptic's except front drive Miller race cars. 3 springers are safer than a suicide front end and don't radius rods or sway bars.
  25. youngster
    youngster
    from Minnesota
    This is the reason I asked
    I used the rear corners of a Model A sedan and some s****s.
    Ron
    bct and volvobrynk like this.
  26. bct
    bct
    so cool. very rare
  27. bct
    bct
    got some stuff done....may be a solid roller by tomorrow.
    j-jock likes this.
  28. youngster
    youngster
    from Minnesota
    Progress feels good huh? Looking good. Please post a pic when it's a roller too.
    Ron
  29. bct
    bct
    semi roller....but the idea is there.
    brEad likes this.
