Making your own steering column
Discussion in 'The Hokey Ass Message Board' started by Probesport, Jan 29, 2012.
  1. Probesport
    Probesport
    I set out this past week to order a steering column for my car and when I couldn't find what I wanted i decided to make one. I took some tips form here and set to work.
    1.5" tubing, 3/4" steel rod, a plate cut for the wheel and the bearings.
    Here are the bearings I used, from a local tractor supply.
    plate welded to the rod, mounting tab mounted to the tube and the bearings have been greased and tack welded to the tube.
    Mounted up
    Removed and painted
    I didnt like seeing the bearing and rod when it was installed os I added a sleeve to the wheel plate
    Painted and installed
    Attched at the steering box with a 3/4" DD x 3/4" DD,
    The only thing left is to clean up the exit area and make a lower mount at the firewall, works great very happy. Hope thsi helps someone.
  2. Molonewolf
    Molonewolf
    Nice job it's great to see some home built hot rod stuff.
    pecker head likes this.
  3. F&J
    F&J
    Of couse it will. That and all the other tech posts are a big part of what makes this place so good. Cool
  4. k1w1rodder
    k1w1rodder
    quote''plate welded to the rod, mounting tab mounted to the column and the bearings have been greased and tacked in.''
    did you mean you tack welded the bearing into the tube?
  5. pug man
    pug man
    from louisiana
    Damn dude you made that look easy! Thanks for sharing with us......
  6. Probesport
    Probesport
    Yes, that is what I meant - I will go back and clarify that.
  7. F&J
    F&J
    If you prefer not to tack it in.. You can do sort of what GM did with a coil spring and a locking collar with a set screw. These 2 pieces push up on the lower bearing, and they also pull down on the steering wheel, which presses the top bearing down.
    Both pieces came from the same hardware store as the flange bearings did.
  8. electromet
    electromet
    from Tucson, AZ
    Probesport,
    You have just made a big light go on in my head. I've been pondering this very project for a while now. Thanks for the write-up and pics. Consider you idea stolen.
    Mike
  9. Probesport
    Probesport
    I was going to do the shaft collar until I realized I forgot to buy them, I like that setup. I did not think about adding a spring to it.
  10. F&J
    F&J
    I think GM used the spring for two reasons; One-it holds upwards pressure while maintaing the bearing pre-load on the GM type factory upper bearing, and Two, I think it allows some movement upwards, of the center shaft as the car may twist or whatever, over bumps.
    EDIT; yours will work fine because your inner shaft can move a bit upwards without binding anything. If you did use the collar that you forgot, but did not use a spring, any flex of the ch***is components might put too much wear/tear on the lower bearing.
  11. desotot
    desotot
    looks good, should work fine.
  12. Probesport
    Probesport
    Nice, I will have to remember that if/when I have to service these bearings.
  13. chevy3755
    chevy3755
    good tech ..........
  14. dirt t
    dirt t
    Perfict timing as I am about to do the same. Thank's
  15. Yeh, good tech...:cool: I like it, will save this info for my T "super crew".
  16. 32 hudson
    32 hudson
    Nice clean instalation. I like that exhaust pipe adapter as a transition sleeve. Can't wait to see the lower mount.
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Nice
    I did something simular , although I used a pre existing column for some of my parts
  18. damagedduck
    damagedduck
    from Greeley Co
    cool idea! thanks for posing your tech.
  19. deflaytedwayz
    deflaytedwayz
  20. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Saw an article once where a guy used an aluminum baseball bat for his column. Looked pretty cool actually
  21. Stevie Nash
    Stevie Nash
    Perfect! I was just mocking my steering column up exactly like this post and was wondering how I was going to get an "exact fit"! :cool:
  22. Probesport
    Probesport
    Interesting, I'd like to see how that looked - if you have a link or pics please post 'em.
  23. n847
    n847
    Thanks Probesport, I have had that process explained to me in the past, and you made it look as easy as they made it sounded! Now I'm ready to get rid of that ****py 80's coulmn!
  24. Looks great! Very nice job. I'll save this one.
  25. flatheadgary
    flatheadgary
    from boron,ca
    i have been making my columns like this for many years. the only difference on mine is, i use chrome exhaust tubing for it.
  26. josh highley
    josh highley
    I have done the same thing on my last couple cars. Works great! Home built and fairly cheap! Gotta love the HAMB!
  27. mink
    mink
    from CT
    x2 on that
  28. Take this next task in hand. How do you take a piece to make into a tilt piece without making too many complications? How do make it look clean?
    I built my own steering column and appreciate how yours is built and looked at something I didn't do.
    Good build.
  29. Deuce Daddy Don
    Deuce Daddy Don
    Like FLATHEADGARY, I used 1-1/2 exhaust tube with one end flared out to match the Le Carra hub with shaft bearing inside tube, then chromed the tube.
    I fabbed my own design steering column holder which splits in two with hidden allen 1/4 inch bolts from behind. This makes a clean appearance.
  30. skidsteer
    skidsteer
    Nice, neat and looks good.
