photo crack early 327 block?fix?
Discussion in 'The Hokey Ass Message Board' started by gasserjohn, Jan 30, 2012.
  1. gasserjohn
    gasserjohn
    what needs to be done?
    is sleeve only option?
    finally wanted to do a full rebuild found this.............
    65/66 block
  2. pinkynoegg
    pinkynoegg
    sleeve that bad boy and call it a day
  3. oldolds
    oldolds
    That needs more than a sleeve. Looks like the crack started at head bolt. You better have a good reason to fix that block. It can be fixed but will take someone who know thier stuff. Knowing stuff = $$$ You have to fix the head bolt hole or it will strip out
  4. raengines
    raengines
    from pa.
    did the sleeve deal on several race engines years ago and they were fine for a while but allways leaked in the end, I would find another block. remember when you torque that head bolt you open the crack up
  5. You could find somebody in your area that does cast iron welding before you do any machine work. Or, sleeve it for a street engine
  6. gasserjohn
    gasserjohn
    i have skill to pin the crack from bolt to cylinder.........ect
    engine has always used a little water /has mondello heads so i blamed them........
  7. Truckedup
    Truckedup
    Will pinning work in a situation like that?
  8. onedge
    onedge
    nice picture concerns me I'd likely p*** on it get another block. Pinning method how will that work?
  9. seb fontana
    seb fontana
    from ct
    Newest issue of Car Craft, pg 24 shows a similiar problem being fixed..Tisn't cheap..
  10. 60 ford
    60 ford
    I'd sleeve and lock***e stud bolts in it. We race dirt cars and use 400 blocks, they are really bad about cracking like that, we have one 421 stroker that has 3 sleeves in it and has survived 6 seasons of 7000 + rpm abuse with no problems. We put so much money in prepping our blocks we can't throw one away because of a crack.
  11. vg62truck
    vg62truck
    We are three race seasons into a 360 dodge that has three sleeves. Best of luck with your chev
  12. tig master
    tig master
    from up north
    Sleeve and pin it.Don't even think about welding it.The weld will cause the parent metal to be as hard as gl*** and the only options after that involve grinding .Pin it and be done with it not a complicated job at all. My2¢
    T
  13. gasserjohn
    gasserjohn
    have old 327 block for$ale one cly needs sleeved lol
    found a 73 4bolt block # says for corvette/camero...free
    hard to replace stuff that we've use on modelA for so long?
    installing mikes trans brake 350//pro action heads /eagle rods &crank...ect
    going to get serious about racing it.....son is having fun with all new stuff
  14. john81
    john81
    Put a sleeve for alum. block in and jb weld stud in bolt hole.
  15. Dave50
    Dave50
    Thats The best .02 and only correct way
