Can someone tell me what motor this is?
Discussion in 'The Hokey Ass Message Board' started by VINNIE JAMES, Jan 30, 2012.
  1. VINNIE JAMES
    VINNIE JAMES
    i was looking for a motor for my 52 chevy 210. this guy has this one. he said its out of a 58 chevy. thanks, vinnie
  2. 32ratsass
    32ratsass
    Looks like a 235 Chevy 6 to me. The guy's probably right!:D
  3. Hnstray
    Hnstray
    from Quincy, IL
    Looks correct for that year model as far as I can see. Has the correct side mount locations, the oil fill/breather cap is in the right location. '59 and later are moved to back to about the middle to clear the lower hoods after '58. It is a full pressure lube 235. The last ones like it were made for '62 models. Good, reliable engines.
    Ray
  4. Rusty O'Toole
    Rusty O'Toole
    Is there a cereal number?
  5. VINNIE JAMES
    VINNIE JAMES
    ill get the number tomorrow. will it bolt up to my 3 speed?
  6. Hnstray
    Hnstray
    from Quincy, IL
    To use your stock '52 tranny you'll need to use your current bellhousing which is a bolt on deal. Same block pattern. However, you need to take into consideration what starter/flywheel setup to use. As I recall, the 6 volt Chevy starter/flywheel ring gears are different than the 12 volt models that began in '55. It may be that your 216 flywheel will fit the 235 crankshaft flange, but I don't know for sure if that is the case. Surely a Stovebolt guy will happen along and clarify that issue.
    If you choose to convert to 12 volt, or already have, then you should be able to use the '58 pieces, or '55/'62 parts if you have to find them.
    Ray
  7. VINNIE JAMES
    VINNIE JAMES
    it was 12volt when i got it. thanks
  8. VINNIE JAMES
    VINNIE JAMES
    these are the numbers he could give me
    GM15
    3836848
  9. squirrel
    that's the head, the numbers you want are near the starter, and stamped near the base of the distributor.
  10. gas pumper
    gas pumper
    And that's the "good" head, too.
  11. VINNIE JAMES
    VINNIE JAMES
    i asked for that #...ill have to go check it out myself
  12. carlisle1926
    carlisle1926
    When did Kellogg's have anything to do with engines? However, it probably does have a serial number.;)
  13. Hnstray
    Hnstray
    from Quincy, IL
    Show a little respect or he may Shred your Wheat! :D
    Ray
  14. Buncha flakes....
    Cosmo
  15. VINNIE JAMES
    VINNIE JAMES
    im going to look at the motor on thursday. he said it was rebuilt. the car was sold b4 he got the motor and trans back. if this is true? how much should i offer him? he wants to sell the motor and transmission as 1 piece. he's not a "car" guy...so talking on the phone to him is a little hard. is there anything i should be looking for??? what would be bad? and what would be good? thanks again, vinnie
  16. 40StudeDude
    40StudeDude
    When you can't spell (and/or don't know the meaning of correctly spelled words)...then perhaps it's the poster that is the flake...
    And cosmo, "buncha" is slang..."bunch of" is correct... who can't spell...???
    R-
  17. carlos
    carlos
    from ohio
    What he said, Squirrel your post are always positive and helpful .Thanks
  18. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Any head is "good" head. :rolleyes: :D
  19. pinkynoegg
    pinkynoegg
    behind the distributor is a flange that has some stamped numbers and letters on it. this is where the serial will be. clean it off really well. trust me they are there. it will tell you what year exactly it is. looks to be a nice 235. without looking at the side with the distributor cap i couldn't tell you if it was the better 261. doubt it is if it came out of a car though. I don't think you need to take the belhousing off. just take the transmission off the belhousing and yours should fit the four bolts from the old one. unless the engine has a synchronized trans on it. you would have to change the belhousing to yours at that point.
  20. Salty
    Salty
    from Florida
    Unless you can fire it up your buying an unproven mill....compression check is your next good bet but still some unknown factors without cracking it open...I would pay the great unknown price AKA the core value....that is of course unless he can show you the wad of reciepts for the rebuild....
  21. DJUDSTER
    DJUDSTER
    if true it would be a 235
  22. 50ChevyFrank
    50ChevyFrank
  23. Hnstray
    Hnstray
    from Quincy, IL
    If, as the OP indicated in his first post, he has the original trans in his '52, and further, IF this later engine has a stick bellhousing, the '52 transmission case bolt pattern does not match the '55 and later pattern that would be on the '58 bell. And, the clutch linkage in the '55 up bells is different than the earlier models.....also making use of the '52 bellhousing necessary IF the stock '52 trans is to be used.
    Further, what is the comment about "if it's the synchronized trans" stuff?? Both the '52 and the '58 used transmisions that were synchro on 2nd and 3rd only. It wasn't until around 1965 that Chevy offered the full synchro 3 speed manuals.
    Ray
  24. squirrel
    The engine number will tell you what month and day it was assembled, and what kind of engine it is (like if it's from a car or truck, what transmission it had, etc), but the suffix code might or might not tell you what year it is. They used the same code on some engines for several years. To figure out the year, you need the casting date which is cast near the starter, or hidden by the starter. It's a letter followed by two to four numbers, like D 14 8
  25. VINNIE JAMES
    VINNIE JAMES
    here's what i have
    con8 e 18 close to the oil dip stick is 15
  26. VINNIE JAMES
    VINNIE JAMES
    here are some pics...
  27. forty1fordpickup
    forty1fordpickup
    X 2 on Salty. You need a compression test as an absolute minimum. I'd fire it up where it sits if there is oil in it. You need to hear it. Listen for bearing noise, valve train noise, skips and misses. All you need is a battery, jumper cables, a clip lead to energize the coil and enough gas to fill the carb bowl. Otherwise offer what a core is worth.
  28. squirrel
    E 1 8 is May 1st 1958
  29. VINNIE JAMES
    VINNIE JAMES
    thanks again guys. what does the first set of numbers mean?
  30. squirrel
    Which set, CON 8? That's the conveyor number it was cast on, I think. Doesn't mean anything to us...for internal foundry use only
