8" Ford thoughts
Discussion in 'The Hokey Ass Message Board' started by Da' Bomb, Feb 2, 2012.
  1. Da' Bomb
    Da' Bomb
    I'm thinking I would like to take my open diff, 2.75 ratio rear and swap the third member out to a 3.55 ratio limited slip...Any thoughts on where to go?
  2. Hotrodbuilderny
    Hotrodbuilderny
    You could shop salvage yards, some v8 Granadas, and Mustang 2's came with them.
  3. estes
    estes
    I bought an 8.8" out of a Ranger 6cyl, 3.55 gears and limited slip for $150 at my local yard.
  4. You might consider an 8.8 out of an '90s Town car, crown vic, or big merc. Comes with disc brakes and posi. That's what I use and the width was perfect for my '29 A. You can pick one up all day long for 100-300 dollars all day long. Although they're not as beefy as a nine inch, they work great unless 500 or more hp and race it or have an extremely heavy foot
  5. KENDEUCE
    KENDEUCE
    I could be wrong, but isn't an 8.8" a different design than 8". Will it fit the same housing or an 8.8" housing only. Good luck finding an 8" - 3.55 posi.
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, the 8 and 8.8 are not the same. He is looking for a replacement center section for his 8 incher.
    Wherever you go, do not buy from a guy from Pa who sells on Ebay. He has a great rating because people put in feedback as soon as they get the product before they use it, however, after a while they start leaking. We have bought two nine inchers from him at the same time and both are leaking from the front seal. We sent one back and he redid it and it is leaking again. Just a word of warning. They also whine like a quickchange.
    Don
  7. Drive Em
    Drive Em
    I've never seen anything but 2.79's and 3.00's in Granadas. MII's have 3.40's in some of them. As a matter of fact in hundreds of 8" rear end tear downs, I have never seen a set of 3.55's, though they are available new.
  8. need louvers ?
    need louvers ?
    Later Pintos were a source for 3.40s too. Look for a manual trans.
  9. Da' Bomb
    Da' Bomb
    I'm trying to avoid the 8.8 swap. I'm thinking I'm looking for a vendor to purchase a complete third member from....Any thoughts there?
  10. Tri-Power
    Tri-Power
    from Memphis
  11. need louvers ?
    need louvers ?
    And you aren't going to go wrong with Randy's either. Good folks and quality stuff.
  12. Lurk king
    Lurk king
    My 2 cents is for the money your getting close to 9" territory.8" are weak and small and were never designed for any sort of power/abuse. I put one in my 29 because it was free and everybody said with my light car small motor I'd never hurt it.......................
  13. RCDARKKNIGHT
    RCDARKKNIGHT
    from Warren CT
    Listen, 8 inch rear are strong if there built properly.
    I purchased my 69 Ranchero 12 years ago and beat the **** out of it
    for 8 years of every day driving.
    Before i decided to remove the 302 and c4 and install mustang two suspension with a 351C and a c6 with 350 hp. I just last year decided to remove it and replace the clutches and brgs.
    But If your looking for a replacement center section listen to what is sai.
    Get one from Randy's ring and pinion.
    There build good stuff and i myself have purchased ring and pinions and other parts from them. They now there ****.
    If you decide to go to a 8.8 you won't be able to change the center section, You have to know how to rebuild it yourself, or dring it to someone that knows how to build them.
    Other then that the only thing i can tell you is.
    Remember: When It Sounds Good - It Looks Good.
    RC
  14. 26 roadster
    26 roadster
    Used them forever and only lost one. Best gear I ever found was a 3.40 open. it worked well with a 29" tire
  15. M.Edell
    M.Edell
    I run an 8" with 4.11's in the 34.I like it.
  16. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've heard great things about Randy's. What is odd is that 9 inch rear center sections are usually cheaper than 8 inchers. Not sure if it is because more 9's were built or what.
    Don
  17. RFAGrasshopper
    RFAGrasshopper
    The Mustang Two and Pinto with the V-6 engine had a 3.40 or 3.50 gear and will drop right in to your 8". There is a trick to redo your open so it performs like a locker. you need Ford washer #C90Z4238H. Drop me a PM and I'll have my buddy tell you how it's done.
  18. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I agree with what RCDARKKNIGHT<SCRIPT type=text/javascript> vbmenu_register("postmenu_7410749", true); </SCRIPT> said..
    if built right, with the right stuff and maintained, it will take years of use..Usually a rear end failure is due to something not playing well in the set up (tollerances, bearings, lash..used parts etc.)..not so much the difference in between a ford 9" or a ford 8"
    you may have more ratio options
    no question the bigger 9-inch is superior in the strength category, the 8-inch shouldn't be totally disregarded. They share the same excellent design and both use 28-spline axles. 9-inch rears can be equipped with much stronger 31-spline and larger axles, in most cases, the smaller 28-spline setups are more than strong enough for 300hp cars for street use
    If your running more then 300 HP on the street and plan on abusing it, than maybe a 9 would be the way to go..also conciter tire size and width and if you can get those tires to stick or not..thats usually what starts breaking **** thats built right to begin with..dont just ***ume an 8" is weak..because even a ****ty built 9" can blow apart the same way a ****ty built 8" can
  19. Da' Bomb
    Da' Bomb
    Thanks for the thoughts guy's. I agree that the 8 is plenty good enough. I'm looking at about 300 hp
  20. CutawayAl
    CutawayAl
    from MI
    While not the cheapest option, Currie sells an aluminum diff housing for the Ford 8". They also have several different limited slip units, and the ring/pinion ratio you want.
  21. 38Chevy454
    38Chevy454
    3.55 is the lowest factory 8-inch gear ratio. Anything else 3.73 or 4.11 or whatever lower than 3.55 is aftermarket only. Finding a 3.55 is hard enough, a 3.55 factory limited slip is like hen's teeth. You can find the 3.55 in Mustang II or Pinto/Bobcat. Not sure they were ever used in others. Early Mustangs might have that 3.55, although I think they were typically 3.25 as lowest gear? Anyone confirm that? Most all 8-inch I have run across are 3.00 or 2.80 gears. Those are super easy to find.
    As for my opinion on strength, I would put an 8-inch up to about 350 hp without much concern; it will be plenty reliable and take the power without any troubles. ***uming you have street tires and not slicks that will make good traction. All 8-inch have 28 spline axles, same as 9-inch small bearing 28 spline axles. 8-inch also have the 3rd small pinion support bearing like a 9-inch which makes them stronger than they would otherwise be. Ford put the 8-inch behind most all small blocks, only the highest performance small blocks received the 9-inch.
    The Ranger or Exploder 8.8 is popular because many are 3.73 and limited slip. Plus now they are easy to find in the junkyards. Cars with 8-inch are less popular now as they are all 70's and earlier for the most part.
  22. Deuce Roadster
    Deuce Roadster
    Actually ... Ford offered a 3.80 gear set for the 8 inch.
    Fairlane = WCL-G
    WCL-P ... WDK-E
    And I pulled one from a early Falcon station wagon also :)
  23. BigNick1959
    BigNick1959
    V-8 Mustang II's came with a 3.00 8" (I believe the 3.55 may have only been an option in a V-6 car) but the limited slip option was only from 76 to 77. I bought a 78 M-II new in 78 but had to put my own posi unit.. The 8'' is plenty strong, I broke the 4 speed 6 times but only once for the rear end!
  24. 46fatford
    46fatford
    I bought a mustang II 8" from an ad in the paper for $50.00. Took it home and found out it had 3:55 gears and was limited slip, talk about shocked. I ended up selling the center section to a friend for that same $50.00 to use in his B/FX style Comet cyclone.
    Matt
  25. 40FordGuy
    40FordGuy
    Can you fit in the Explorer 2wd 8.8" ? That came with the 3.55 you mentioned,..as well as disc brakes, hat rotors with park brakes.
    4TTRUK
