Projects Norm's A build!
Discussion in 'The Hokey Ass Message Board' started by norms30a, Jan 11, 2011.
  1. FORDFREAK05
    FORDFREAK05
  2. 94hoghead
    94hoghead
    I kinda like the 32 tank on an A....
  3. GARY T.
    GARY T.
    from S.W. Pa
    AND it gives you a lot more trunk space compared to one with the tank in the trunk!:)
  4. norms30a
    norms30a
    That's the main reason I am putting it on the back:). Now if I could just make the battery disappear :p!
    Now all the gas stuff is on the outside of the car,less worries about fumes or leaks, and easy to fill too.
  5. GARY T.
    GARY T.
    from S.W. Pa
    Have U seen these batteries?
    http://www.tpibatteries.com/
    Don't know anyone that has one yet---was thinking about buying one,but my battery is pretty new yet
  6. norms30a
    norms30a
    I haven't heard of those batteries, looks really interesting. The biggest problem I can see is if it were to go dead away from home I would have to get a new full size to keep going, then I would probably leave that one in for 5 years since I have it.
    If I could get em locally I think those would be the way to go.
  7. Ford Mike
    Ford Mike
    Any updates? The car is lookin great!
  8. norms30a
    norms30a
    Been busy with farm stuff, I'll get back on it real soon.
  9. norms30a
    norms30a
    Rigged up a hill billy porta power so I could push the right quarter out about 1/8th of an inch. Looks silly but it got the job done:p.
    I need to roll the thing outside so I can do some sandblasting before I start putting in the floor, but the ground in front of my shop looks like this:(. 5 days of rain and snow will do that, April showers,puh.
  10. norms30a
    norms30a
    After stopping last spring to do farm work which lasted until new years due to beautiful weather, I have now gotten started again.
    I first did some sandblasting underneath, then I made some wood blocks for under the bolts in the old part of the sub rails, then after fitting everything together and welding the old and new together I finished putting the last patch panels in.
    The last couple days I made the under floor support much like I have seen done here . Next is the sheet metal floor.
  11. MCINK
    MCINK
    from EASTRIVER
    Welcome back, we missed the updates on this ride.
    But you're right, the weather has been great through the end of 2011.
  12. dexleo2
    dexleo2
    Nice work!.......keep up the good work!..........Love the ford Model A
  13. chopt top kid
    chopt top kid
    Lookin' Good Norm!!! Welcome back after your lengthy hiatius...
  14. norms30a
    norms30a
    Been working on the floor from back to front, made a little door so I can access my gas line and fuel sender easily.
    Done to the front edge of the door, waiting for my trans. to get done so I can do more.
  15. norms30a
    norms30a
    Been doing some measuring before getting a radiator and I think the shell will need to come down a couple inches
  16. Malcolm
    Malcolm
    from Nebraska
    Good to see you're back at it... Nice work!
    Malcolm
  17. Rehpotsirhcj
    Rehpotsirhcj
    looking good Norm
  18. dirt t
    dirt t
  19. 60galaxieJJ
    60galaxieJJ
    Rolfs car is soooooo sweet! Me and dynaflash_8 went up to his place to pick up some tires not knowing it was him and we got to see it up close.
  20. norms30a
    norms30a
    Thanks fellas, Malcolm, I've been following your build and you are building a really nice one, with lots of neat detail.
    60galaxieJJ, wish I'd been with you that day!
  21. norms30a
    norms30a
    I went to Watertown a few days ago to talk about getting some parts at Randy Gribble's shop, and while I was there I got punched :eek:!!!
    Yesterday I got the rear suspension put on, I had to trim just a little sheet metal for everything to fit just right . Now I have about 3 and one half inches of travel before anything would hit. That is with the 2 shortest leaves in the 9 leaf spring removed.
    Today I have to do some finish work on the metal edge that I trimmed yesterday.
  22. pbr40
    pbr40
    from NW Indiana
    not trying to be negitave nacy but that grill looks to strait up and down like it needs to be laid back. just my 2cent great build
  23. norms30a
    norms30a
    I'm planning to lower the grill shell one and a half inches and I'm thinking I might run a hood top, not sure yet.
    So when I put the radiator in I will try to set stuff up so a hood top will fit from a 32 as that is really close to the right length . The pic I took was really just to see how tall it was, you are right, the angle looks off to me too.
  24. Subscribed! Great build, Norm, we are on close levels, so I watch attentively.
  25. chaddilac
    chaddilac
    Wow!! really looks great!! You're doing a nice job!
  26. patman
    patman
    ***y called, he wants his press back...:D
  27. speedy383
    speedy383
    look's good norm. I have the same frame from pete&jake's with a 30 roadster and just getting started with my build. Your's look's real nice!
  28. chopt top kid
    chopt top kid
    I really like the visor. If I could find a guy with some die's like that I'd consider getting mine punched.
    I've thought about cutting my wheelwell for axle clearance and wondered if moving the bottom of the center bead up above the cutout would be worth the effort???
  29. norms30a
    norms30a
    After I was sure I had the rear housing in straight and square I took it out again and put it together, it has a 4.11 to 1 gear ratio.
    I hope this ratio works with 31 inch tall tires and a 700R4 automatic.
    When I had the rear out I did raise the bottom of the center bead up about 3/4 of an inch, I just think it's just a little more finished looking and it was not really hard to do just some heat and some hammer and dolly time to shrink it.
    I also welded on a half inch lip on the inside where I had cut out for a more finished look, kinda got rid of the raw cut edge.
    Keep in mind I am not a pro metal worker, some of the work I do will require a little bit of bondo to make it perfect.
  30. norms30a
    norms30a
    Started working on the front end and it looks like I will have to work on the spindle a little bit to get the backing plate to fit just right.
