Carson Top info - where can I find?
Discussion in 'The Hokey Ass Message Board' started by oldcarmike, Jun 20, 2005.
  1. Open question - Does anyone know of a good, detailed source for information on how to build a Carson top? I want to do one and have a few articles from R&C and other magazines, but the detail is a little slim... Any suggestions or anyone in the Chicago area have one I can take a close look at? I'd like to avoid costly mistakes if I can. Thanks!!
  2. Rikster
    Rikster
    Perhaps these drawings from Don Post's Blue Book of Custom Restyling might give you some idears.
    50-51 Mercury inside the Carson Top show half way thru the process.
  3. J.B.
    J.B.
    from Sweden
    Rik !
    Your tremendous work with your site and engagement in traditional kustoms
    will inspire generations to come. I'm really in to doing a Carson on my new
    Caddy... Guess I need to get it running first, ha ha...
    Yer pal
  4. Dat Dirty Rat
    Dat Dirty Rat
    There was a thread on this in the Tech Section.....
  5. Nixer
    Nixer
    Thanks man...I can definitely use this...
    tok
  6. Rikster - Those pics hit the spot. Thanks for the visual, ya know the whole 1000 words routine.
    __________________________________________________
    "One thing I'll say about the ex-wife: She sure taught me how to take a punch."
  7. -=LD=-
    -=LD=-
    While this is a pretty good start:Rod & Custom Article
    As for some detail/how to connect it questions, sawzall helped me out sometime back, I'd PM' him.
  8. LD - Thanks for jarring the memory banks. I have that issue of R&C in my archives - somewhere in the nightmare that is my basement. Damn - this means I'll have to clean...
  9. KoppaK
    KoppaK
    Notexactly but a friend of mine has used concrete reinforcement mesh over a steel frame and covered it with glass mat. Its not that heavy either.
  10. james
    james
    One thing to remember is after you build a frame, tape a bed sheet or something over it so you can really see how the lines are. Seems like you see a lot of bad carsons around, and a bare frame is a lot different than one covered.
  11. Chaz
    Chaz
    I know this is probably a stupid question, but are all carson tops removable?
  12. joeycarpunk
    joeycarpunk
    from MN,USA
    Rikster, thanks for posting info.
  13. Chaz - No, it's not a stupid question. They can be set up to be removable or you can just leave it on all the time. I'm gonna set mine up to be removable so if the weather cooperates I can cruise topless and get a sunburn on my bald head. Chicks dig guys with peeling skulls. No, really they do.
  14. Isn't that only half the job?
    Reinforcing the body would be my main concern.
    I like that my doors open. :)
    (unless its already a 'Vert) :dunno:
  15. Good point. Sure, you'll have to reinforce the body, but I'd think you'd have to add some kind of bracing to attach the top to anyway. That would have be built into the body to keep everything aligned and tight. I also think the top would add some structural support if it was well thought out, but that would mean keeping it on all the time if you're relying on the new top to replace the original steel unit as a structureal element.
    X-bracing at the bulkhead behind the rear seat would help as would some extra vertical support at the rear of the door jambs. You'd also have a "U" brace running from door to door under the rear deck area where the top attaches. If all three of those elements were tied together and tied to the body panels with panel adhesive or even spot welds I think you'd get a pretty rigid set up. then if you ran topless you'd be OK. If the chassis is boxed and braced w/ crossmembers like you normally would anyway, that should be enough I'd think. Correct me if I'm wrong. (Geez - that may be a loaded request)
  16. KoppaK
    KoppaK
    Hey guys , going to do a tech on mine sometime soon which is of course a unibody and started as a moredoor.
  17. Docfranknstein
    Docfranknstein
    I'm sure You know this but Gene Winfield sells fiberglass carson tops. Von Doc
  18. Nope did not know that. Thanks for the heads up. I assume he has a website?
  19. Docfranknstein
    Docfranknstein
    He does not, but here is His phone # ( 661) 824-4728 Von Doc
