NEED HELP!! My 300 gets 3mpg!!!
Discussion in 'The Hokey Ass Message Board' started by "T'RANTULA", Feb 5, 2012.
  1. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I got a 300 inline 6 with a c6 trans. It previously got 16mpg and now its gettin 3mpg. I cant figure out a bit why. It dosent run rich or leak gas. If anyone can help I would really appreciate it. :(
  2. bobwop
    bobwop
    from Arley, AL
    leaking gas tank?
  3. tommy
    tommy
    with no obvious signs of wasted fuel, I'd be checking my math.
  4. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Ive checked everywere and cant find a leak. I have a 13 gallon fuel tank and can only go 47 miles before its empty.
  5. Chris
    Chris
    Is this reoccurring or just one time? Some meat head siphon your tank?
  6. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Its very consistent, been gettin the same milage for 4 months...
  7. Skeezix
    Skeezix
    from NorCal
    One traditional hazing is to siphon a guys gas for a few days then put it back -can drive the right nuts
  8. GassersGarage
    GassersGarage
    1. Someone is siphoning your fuel.
    2. If you can't find leak when it sits, maybe a leak after the pump when engine is running.
    3. If it has a mechanical pump, the diaphram in the pump may be leaking into the crankcase.
    4. All the fuel may not be siphoning from the tank.
  9. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    That just aint right :eek:
  10. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I can watch the gas gauge drop while im driving!!! And I keep monitoring the oil in the crank case and theres no change there. It has me stumped, Im starting to think the motor is killed.
  11. 42hotrod
    42hotrod
    from S.E. Idaho
    If it isn't leaking it is consuming it, it really is that simple. So now you need to figure out where it is going. Check the oil, if it smells like gas you may have a bad mechanical fuel pump. Start the truck and look down the carb throat with it idling. Is it dripping fuel off the venturi? Is it a holley 2 barrel? Does it have a power valve? if it does it may be ruptured. There really aren't that many options, you just need to start eliminating things.
    And at 3 MPG, it shouldn't be that hard to track. Thats a ton of fuel.
    It's going somewhere.
  12. V4F
    V4F
    from middle ca.
    if in 4 months you havent found the problem ...... sell it !
  13. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    It has a 1bbl carb and it sprays a mist of fuel when idling. as far as i can tell it runs how its sopposed to.
  14. william.ali.kay
    william.ali.kay
    from Milwaukee
    Before this thread turns into a guessing game, why dont you tell us what you have checked?
    A lil more info would go a long way.
  15. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Ive checked for leaks, I checked the trans, I checked the crankcase for fuel, It aint runnin rich, no one is stealing my fuel,The motor has 419k miles and I rebuilt the 1bbl carter carb. Ran excellent and still runs excellent but the milage dropped from 16 to 3. Thats all Ive checked and If I should check anythin else let me know.
  16. LowerthanLife
    LowerthanLife
    does the exhaust smell like fuel? check the plugs to see if theyre wet with fuel....and then check to see if your spark is hot enough. you may just be blowing the fuel through your exhaust.??
  17. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I got autolite plugs and the exhaust dont smell like fuel. Im gonna go pull the plugs and take a look at em.
  18. Rickybop
    Rickybop
    I don't think the engine would even run at that rate of comsumption. But check the sparkplugs...see if they're black. But again...if it was burning that much fuel, it definitely would foul the plugs, and then start running really ****py.
    If the plugs aren't fouled, which I doubt they are if it's runnin' good...you've definitely got a leak. It may be near the engine or the exhaust pipe, and drying off quickly enough, that you can't see it. Look again...real closely.
  19. bobwop
    bobwop
    from Arley, AL
    I find it hard to believe it would even run at 3mpg. It would certainly be smoking black smoke
  20. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    does it waste the fuel if you just let it sit and idle or just driving? may have a hole in the tank so it drains as your driving. Just a thought
  21. LowerthanLife
    LowerthanLife
    that t,rantula is really bad***, how far is the engine set back?
  22. Rickybop
    Rickybop
    One other idea. Where does your fuel exit the tank?...at the top? If so, it may be leaking there, and hard to see.
  23. Hard to imagine that you could force that much fuel through a 1 barrel carb in that amount of time. If you could, it would have to be combined with the right amount of air to run right, and that is also unlikely. I would think that it has to be leaking somewhere.
  24. Rickybop
    Rickybop
    When you look for the leak, don't just look...feel too...with your bare hand. And smell.
  25. schpud
    schpud
    from ME
    [QUOTE="T'RANTULA";7421570]Ive checked for leaks, I checked the trans, I checked the crankcase for fuel, It aint runnin rich, no one is stealing my fuel,The motor has 419k miles and I rebuilt the 1bbl carter carb. Ran excellent and still runs excellent but the milage dropped from 16 to 3. Thats all Ive checked and If I should check anythin else let me know.[/QUOTE]
    Is this a typo? If not than holy ****.
  26. rusty rocket
    rusty rocket
    Have you ran out of gas while driving? it sounds like the fuel gauge isnt working properly. Sounds like your getting the milage of a top fueler! Maybe after 419 K you should think about a rebuild.
  27. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I just pulled the plugs and the motor is still hot. The plugs are a blueish white color but not black. I got a new gas tank with new fuel line and ive diss***embled the bed and looked every were for 4 months and i cant turn up a leak. This just seems to be insane! I do have a couple bad lifters in the engine but I dont think that could cause this problem?
  28. Rickybop
    Rickybop
    Be sure to check, both while the engine is running and not running.
    One other thing. If you can avoid it, don't use a regular trouble light...danger. One drop of gas on the light bulb, and fire. Use a fluorescent trouble light or a flashlight. Good luck. Let us know.
  29. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Not a typo
  30. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I beleive 10 inches cant remember right off hand
