Roller cam / dis gear
Discussion in 'The Hokey Ass Message Board' started by 34hemipu, Feb 5, 2012.
  1. 34hemipu
    34hemipu
    Guys , I know about billet roller cams needing a bronze distributor gear . But , does a factory roller cam need a special gear also ? Are factory rollers cams cast ?
    Thanks , I got a smoking deal on a crate marine small block and would like to use a Hunt mag I have in stock .
    Mike
  2. George
    George
    Didn't say what engine, but I'd go to the junkyard & install an OEM gear on your mag.
  3. big duece
    big duece
    from kansas
    Does your crate motor have a distributor? Use that gear.
  4. NAT WILLIAMS
    NAT WILLIAMS
    You did not say what brand of engine. I know on GM the factory used a melonized gear and MSD uses a melonized gear on all of thier new distributors that they sell so the gear is compatable with factory and aftermarket roller camshafts. I have noticed that some roller camshafts have pressed on gears but all I have used were still billit.
  5. saltracer219
    saltracer219
    Most of the cam manufacturers now offer a billet roller cam with a cast gear end mated to the billet cam core. This ends the problems ***ociated with a steel billet cam gear. The cams cost a little more but are worth it in the long run.
  6. Larry T
    Larry T
    I know the factory RamJet crate engines take a melonized (sp??) gear. You can get them from GM, or Summit and Jegs also carry them.
    Larry T
  7. AnimalAin
    AnimalAin
    Fords use steel distributor gears in concert with steel drive gears on the cam. Available from Summit and others.
  8. Deuces
    Deuces
    Yep! I'm running steel gears on all my roller motors...
  9. 34hemipu
    34hemipu
    Thanks guys ! It's a 350 chev , you know . Anyway will probaly swap out the cam for a lumpier one anywho,
    Thanks again
  10. ray-jay
    ray-jay
    from Buford GA
    Instead of thinking "dist drive gear" think "oil pump drive gear". It's the oil pump that puts all the load on that gear pair.
