4 speed T Bird
Discussion in 'The Hokey Ass Message Board' started by Chuck Lloyd, Feb 4, 2012.
  1. Chuck Lloyd
    Chuck Lloyd
    from Va
    Has anybody out there tried putting a top loader 4 speed in a 64 T Bird. The old cruse o matic just does not cut it any more.The clutch linkage I think will be nightmare. :)
  2. You might want to look at the brake and clutch pedal, linkage, etc in a '63 or '64 full size Ford to see if they are close to the T-bird parts as a starter. I know a manual trans was offered in the square Birds but it fairly rare. Don't know if your series ever had them. Goiod luck.
    Charlie
  3. 56don
    56don
    You could do a Mustang cable or hydraulic clutch linkage if you could come up with a pedal that fit right inside.
  4. Chuck Lloyd
    Chuck Lloyd
    from Va
    The problem is the engine in a T BIRD sits down deeper in frame so clutch equelizer wont line up. Clutch pedal will be real problem to , Thanks & God Blrss
  5. Chuck Lloyd
    Chuck Lloyd
    from Va
    Thanks for the tip. The Hydraulic clutch sounds like the easy way to go!
  6. oldcarfart
    oldcarfart
    The clutch and brake are a defineate issue, aftermarket swing pedals and a 60's side by side master cylinder look promising. anything is possible, why not a manual shift performance automatic?
  7. Squablow
    Squablow
    There is or was a 61-63 T-bird on eBay this past week with a 4 speed installed into it. Different than the 64-66 body I know, but might be worth shooting that guy an email to see how the conversion was done. Looked cool with a shifter poking out from the console.
