Another henry J build
Discussion in 'The Hokey Ass Message Board' started by Smilin Jack, Dec 19, 2011.
  1. swade41
    swade41
    from Buffalo,NY
    Both of my doors are patched at the bottom too, the p***enger door's patch is a piece of work. They folded the patch over the edge of the door and it sticks out damn near an extra 1/4 inch compared to the rest of it...lol
  2. Clik
    Clik
    I just sold the one small block Boss Hoss 350/345 HP but this one is a 502 CI/502 HP.
    It was fun until a botched inner ear operation destroyed my balance.
  3. Clik
    Clik
    Question: Inside my windsheild frame are little rubber teeth. Were they from the rubber or headliner. I don't plan on running a headliner. If they were for that I'll eliminate them. If they were for the rubber, does newer rubber require them?
  4. Smilin Jack
    Smilin Jack
    Clik,
    I think they are for the headliner. I just took my windshield out and don't recall seeing anything that would have anything to do with the windshield rubber. By the way, where do we get new rubber for the windshield, back gl***, and door weather stripping?
  5. Smilin Jack
    Smilin Jack
    Pretty good day. Got both doors repaired and got the rear rollpan stiffened up with conduit. Front rotors tomorrow and she'll be up on her front feet anyway. Going Tangerine orange for paint.
  6. swade41
    swade41
    from Buffalo,NY
    This is the only guy that has them, he's old school and has no web site so you must call. I bought mine from him and they are perfect one piece rubbers.
    Rudy Phillips
    2136 Walnut St.
    Ramona, CA 92065
    1-760-789-3608
  7. Smilin Jack
    Smilin Jack
    Thanks Phil. Gotta have 'em.
  8. Clik
    Clik
    Try Steelerubber.com
    I think they are in N.C.
  9. 64 Thunderbolt
    64 Thunderbolt
    That's who I was going to suggest but I couldn't rememeber there name.
    Did you try them swade41?
  10. swade41
    swade41
    from Buffalo,NY
    I was over on the Kaiser/Frazer forum http://kfclub.com/forum/index.php which is mostly a bunch of restorers and that Rudy guy is the only guy ever mentioned.
  11. blue 49
    blue 49
    from Iowa
    My Steele catalog is a few years old, but I didn't see anything for Henry Js.
    Blue
  12. 64 Thunderbolt
    64 Thunderbolt
    I just didn't want you to think I was being a smart A..
    I've dealt with them in the past & have one of there catalogs & need to look. I'll post the results when I do.
  13. Clik
    Clik
    You might also check with:
    KaiserBill.com
  14. swade41
    swade41
    from Buffalo,NY
    Ha Ha, you're talking to a guy with a Masters degree from that school...lol
    From my understanding the Rudy guy was the only one, hell there might be others out there but I'm not aware of them. Wouldn't be bad to compare prices.
  15. 64 Thunderbolt
    64 Thunderbolt
    Amen!
  16. Smilin Jack
    Smilin Jack
    Got the ladder bars and brackets finished today along with the front crossmember with the driveshaft loop ready to weld. Got a early Bronco 9 inch rear end coming. Getting ready to roll. LOL
  17. swade41
    swade41
    from Buffalo,NY
    go man go ! They look heavy duty and that bronco rear is a great width, what gears 3.50 or 4.11 ?
  18. Smilin Jack
    Smilin Jack
    I used 1 1/16 OD Dom tubing 1/4 inch thick with 3/4 inch heim joints. It's the same tubing I use to make my 54 caliber smoothbore gun barrels. For the rear end gears, I think I will go with something in the 4.88 range. Not sure yet. I will use a spool in it. What's your thoughts on gears for a 1/8 and 1/4 mile track?
  19. swade41
    swade41
    from Buffalo,NY
    Those were the two gear sets offerd in the broncos that's why I ask. It would depend on what rpm's you want your engine at while crossing the line. I used the 4.11's because I had an extra center section with those in it.
    I've been hearing a few people runing the 4.30's more often than not lately, but it really depends on where you want the rpm's while crossing the line.
  20. Smilin Jack
    Smilin Jack
    That's a good question on the RPM's. I'm just having fun. Not sure how high I want to turn the engine yet. LOL
  21. HOTRODPRIMER
    HOTRODPRIMER
    Jackie, you are on a roll and the work is first cl***.
    That old car should be up and rolling soon.HRP
  22. Smilin Jack
    Smilin Jack
    Thanks Danny,
    I hope to have it rolling by the end of next week. Then a little sandblasting, a little body and seam filler, then some Tangerine Orange paint. Then some new gl*** and rubber, wheels and tires, Gawd, I just depressed myself. LOL
  23. Smilin Jack
    Smilin Jack
    Well, the ladderbars, front bar, and coil over shocks are ready and waiting on a rear end. Can't do more until I get it though. Always welcome ideas.
  24. Smilin Jack
    Smilin Jack
    She's slowly taking on the look of a g***er. Still have to make my own motor noises, not kewl, but it's a raspy fuel altered sound so ain't bad. LOL Got to have a Moon fuel tank for the front.
  25. swade41
    swade41
    from Buffalo,NY
    New way to think about "your car looks like it's on stilts man".....lol looking good Jack, I took a similiar picture myself today.
  26. Smilin Jack
    Smilin Jack
    Got the steel tubing in today for the roll bars. Doing a 8 point cage. I got all the parts cut and fitted, ran out of shielding gas so to9morrow will get everything welded up. Getting closer every day.
  27. Smilin Jack
    Smilin Jack
    Got the 8 pt. roll cage tacked in tonight. Dog chewed up my USB cable so can't load pics. maybe tomorrow.
  28. Smilin Jack
    Smilin Jack
    Finished up the 8 pt. roll cage today. Bought a Edelbrock crossram with 650 Holleys off a Hamb member so I'm getting closer (to what I don't know yet) LOL
  29. Clik
    Clik
    Man! Those stilts look dangerous. Please buy a set of jack-stands. I don't want to hear any jokes at your funeral about why they called you Jack. All it would take is someone to lean on a fender.
  30. Smilin Jack
    Smilin Jack
    The back is on jack stands. The front stands are 4 x 4 an all is solid. The old g***er may do me in but it'll be down the track! LOL
