Had my flathead block welded, pretty cool process
Discussion in 'The Hokey Ass Message Board' started by metalman, Feb 10, 2012.
  1. metalman
    metalman
    Maybe this is old news but I recently came across a guy that repairs cast iron by spraying bronze, I've never seen or heard of it before. He uses a torch, looks just like a cutting torch except for a small canister on top, looks like a cup off of a paint gun. Fires it up, heats the metal till a dull orange and pulls the trigger, spraying bronze powder out. The powder melts and sticks as it comes out. You can start layering it just like adding coats of paint to build it up.
    The block, someone in the past must of gotten a little too agressive with the valve tool bar and broke the intake port.
    After it was sprayed.
    Cooled & filed, just like new again. The whole process took about 20 minutes.
    The guy says he's fixed all types of broken parts, ears broke off of blocks, freeze cracks, even broken end plates off a big milling machine with no failers. He's even built up cam lobes for special grinds, say's it's harder then the original lobes. I asked him about fixing a normal crack in a flathead (you know, wall to port) and he wants to try it. He checked with the powder manufacture's engineers and they said it would work as long as combustain temps stay below a substained 1200 degrees. How hot is a combustain chamber? I might give it a try, i got a couple good blocks except a crack, might work better then the drill & pin repair I've done before. It would be great to have a reasonable ($$$) way save some of these old motors. Anybody try it before? If it works I might invest in the torch and some powder.
    Stogy, kidcampbell71 and Tman like this.
  2. F&J
    F&J
    Pic #2 is pretty cool; it sure looks like the new metal flowed great and has a very good bond... just like solder on copper.
    Stogy and kidcampbell71 like this.
  3. TexasSpeed
    TexasSpeed
    from Texas
    Old news or not, I learned something new today. That looks pretty cool and is good to know for whenever I find something needing this sorta repair.
    Thanks for sharing this with us!
  4. Interesting - Thanks
    Stogy likes this.
  5. Hnstray
    Hnstray
    from Quincy, IL
    Very impressive process.........thanks for sharing
    Ray
  6. rcshaggy169
    rcshaggy169
    I have heard about the process, just never seen it done. Very cool!
    Stogy likes this.
  7. hombres ruin
    hombres ruin
    Impressive repair. Learn something new, keep us posted
    Stogy likes this.
  8. plym49
    plym49
    from Earth
    You won't see 1200 under normal conditions. Aluminum pistons begin to melt up around 1300, IIRC.
    Stogy likes this.
  9. Gumpy1940
    Gumpy1940
    metalman...could you ask him where we can purchase this special bronze spray torch? thank you
    Stogy likes this.
  10. sounds like the spray welds that rust busters use to repair rust outs in bodies. they say that they can use tape then spray holes 3 inches across
  11. tommyd
    tommyd
    from South Indy
    Well THAT was worth logging on for.:eek:
    kidcampbell71 likes this.
  12. metalman
    metalman
    plym49- I'm not a mechanical engineer ( I'd have no idea of combustion temps) but I was thinking along those lines, if it was hot enough to melt the bronze, aluminum wouldn't be far behind.
    Gumpy1940-his torch was made by Victor, I'd check and see if your welding shop could order one. He said the torch cost him around 250. The powder he used is manufactured locally and kinda pricy, around 350 for a 11 lb can. I understand they have different alloys for different materials and hardness requirements.
    NONAME- don't know what type of tape they would use to hold up to the heat, must be good stuff! Wouldn't know about rust busters around here!
    Stogy likes this.
  13. 56don
    56don
    I'm impressed. I wonder if this is a patented or a company process or just something a good mechanic/machinist has come up with.
    Stogy likes this.
  14. dmw56
    dmw56
    That's a really neat process. Does he have a shop in town?
    Stogy likes this.
  15. paleot
    paleot
    from louisiana
    It must be a patent the machine shop in the refinery I retired from used it to metalize shafts, it is a neat process. They would spin the shaft in a lathe then heat and apply the metal.
    Stogy likes this.
  16. stealthcruiser
    stealthcruiser
    It's known as a "powder torch" I believe. One of the powders sprayed is Nickel, and they have been used to replace damaged or broken "ears" on engine blocks and transmission cases.
    To save the hole in the ear, they stick in a carbon rod of the proper hole diameter, and start spraying.
    Look here: http://www.metalspraysupplies.com/equipment/powder-flamespray.htm
  17. metalman
    metalman
    56don- might be patented but I don't thinkit's a company or franchise type of thing. Still looking into it.
    dmw56- He's in Los Lunas Don. I can get you his number if you ever need it. Speaking of shops you need to stop in our new shop and say hi one of these days.
    Stogy likes this.
  18. metalman
    metalman
    That "powder torch" looks like the setup he used all right. I'm surprised it's not more common, it doesn't require a hugh investment or skill.
    Stogy likes this.
  19. Blue One
    Blue One
    from Alberta
    Thermal spray coating or material build up has been around for a very long time and there are plenty of different companies making equipment and consumables of all types for it.
    There are lots of applications and variations of the process from the basic flame spray to arc spray transfer methods like plasma spray.
    We have learned about the process and how to apply and use it for many years here in our Alberta Welder Apprenticeship program.
    You can find all kinds of info on the process theory including applications and history
    here.
    Good info.
    http://www.thermalspray.org/index.php
    The International Thermal Spray ***ociation, a Standing Committee of the American Welding Society, is a professional industrial ***ociation dedicated to expanding the use of thermal spray technologies for the benefit of industry and society.
    Stogy, BradinNC and kidcampbell71 like this.
  20. Dynaflash_8
    Dynaflash_8
    from Auburn WA
  21. fearnoevo
    fearnoevo
    from Iowa
    spray welding/metalizing has been around for ages. I first learned about it fixing some huge rollers for a laminating machine 20 years ago. The bearings had gone south and chewed up the bearing journals on the rollers. A few phone calls later and we found a local machine shop that could do it. A couple of hours later, a part costing upwards of $30k with a 6 week lead time was repaired for around $500.
    Powdered metal technology has come leaps and bounds since then. Net cast parts are common today using a process nearly identical to injection molding. 2 years ago we machined a series of hydraulic pump bodies using powdered metal. It was pretty cool stuff. The bores only had to be reamed and burnished to attain the tolerances and surface finishes they required.
  22. dragsled
    dragsled
    from Panama IA
    Thanks Metalman Now I can bug our welder to fix my flathead blocks along with my KB blocks I blow up HA HA Tim Jones
  23. fordor41
    fordor41
    Or spray welding. Can be used to weld a crank jounnal on a lathe. Keep it turning slowly, when hot, spray the powered metal on to build up a layer.
    Stogy likes this.
  24. badshifter
    badshifter
    My metal shop teacher in high school had that rig. That was 1978-1980 and it seemed like an old set-up then. But it sure worked awesome. Never seen one since. Cool they are still being used.
  25. Shopking
    Shopking
    from central Pa
    Very interesting,I'm glad I read this thread.It is worth looking into to save certain parts
    Stogy likes this.
  26. plym49
    plym49
    from Earth
    As cool as this technology is and thinking even broader, can you imagine the repair technologies that might be possible? Too bad we have become a 'just order a new part' or, worse, 'just order a whole new thing' society. If this was a SBC, a phone call and a new cylinder head (or long block) is dropeped off at your door. We have gone to far down the 'just replace it' road.
    Stogy likes this.
  27. jimvette59
    jimvette59
    Try googling Eutectic Castoline spray powder. I used these processes in the sixties.
  28. Blue One
    Blue One
    from Alberta
    If you visit that site I posted you can learn all you ever need to know about thermal spray processes and applications.
    It's the AWS for crying out loud !! :D
  29. jamdonut
    jamdonut
    from Australia
    What he said ^
    I use the the "Superjet" flame spray torch from Eutectic at work. We make and refurbish drill bits and high wear components for oil/gas/mineral drilling and agricultural industries. You can get bronze, chrome and nickel based powders it all depends on the base material and conditions it will be used under. We use a hard facing powder ( tungsten carbide) mainly, and the process is pretty user friendly.
    Stogy, BradinNC and fauj like this.
  30. Lotek_Racing
    Lotek_Racing
    Very cool, a local shop has been advertising this process but I've never seen it done.
    I wonder how it would hold up on exhaust manifolds. I have an O/T turbocharged car that eats cast iron manifolds.
    Shawn
    Stogy likes this.
