Mid Sixties Buick Wildcat.......Disc Brake Conversion.....
Discussion in 'The Hokey Ass Message Board' started by stealthcruiser, May 13, 2011.
  1. stealthcruiser
    stealthcruiser
    Front brakes, in question.
    What's available out there?
    What later G.M. donors will work, and still keep the big bolt pattern?
    What have you used, for a conversion, on this era big Buick?
    I know you're watchin', Scarebird!!!!
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    What year car? I'm pretty sure that full size spindles interchanged from 1965-70, which opens you up to a factory setup.
  3. stealthcruiser
    stealthcruiser
    Whisper, whissper, whisssper..........'66
  4. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    1965-70 full size Buick have the same spindle ex. 65 Riv.
    Being rear steer your options in donors are nonexistent to my knowledge. We do offer a bolt up setup, and it fits inside the stock wheels.
  5. 32ford5
    32ford5
    from Australia
    There you go!
  6. stealthcruiser
    stealthcruiser
    Thank you, Brother..........................I'll forward the info to my Buddy!
  7. I Am a Little slow on the "UPTAKE" on this matter, If this is true then can't I just use a disc brake system from a Later model Wildcat/LeSabre? Also don't I need to go too a dual Resevoir? Due to the fact that the Disc system use more fluid? I have bought the brackets but as of yet I am not that far along in my resto yet. Tanks for any help in this matter in advance.
    Techman-10
    P.S. I have been away for awhile due to health reasons but I am doing a whole lot better
    So I want to get my CatProject going again!!!!!!
