Projects Rusty 47 Ford Reserection
Discussion in 'The Hokey Ass Message Board' started by koolkemp, Apr 17, 2010.
  1. koolkemp
    koolkemp
    Ride his *** man!! Gotta keep us older guys focused and moving or nothing gets done!:D
    Thanks eah!
    The back bumper is about an inch or so lower than the stock one would be an pulled about 2 inches away from the body...lots of room around the splash pan...I am not really a fan of the bumpers "tucked" closer to the body unless its a hot rod...I like the long and low look for this car ...the front is in about the same location as stock, but I havent done my final adjustments to it yet. I am still gonna lower the car a bit yet so that will change the look some more as well. I will have to find that book,thanks! I actually went to the spinal clinic today, they actually called with a cancellation earlier this week....I could see the bone spurs built up on the 4/5 disc that are torturing the sciatica nerves...it hurt just looking at it ...the end result was that he ordered an MRI ...so more waiting :( for answers ....
    Haha they will keep you young :rolleyes:
    Depending how I feel when I get in tomorrow I will try and get a few pics up...but basically I have been sanding mud for the last couple of weeks...just about finished the skirt/lower quarter on the drivers side ...been fine tuning door and trunk gaps ...got the trunk pretty well ready for the first round of primer and both quarters...gotta block out the roof and fix a few low spots ...ready to pull the other door off, and do the last bit of metal work around the hinge and got the rocker/step plate area ready for prime as well...and a bunch of other little **** done that doesnt make for great pics lol but I will update !
  2. nali
    nali
    So you re gonna drive it for spring ? :p
  3. koolkemp
    koolkemp
    No Nali not by spring I still gotta blow it apart to finsh the frame and underbody ,then start putting it back together...I am hoping to have it running by the end of the summer, but I dont have much money to throw at right now ,but thats my goal!!
  4. nali
    nali
    We all don t have enough moneyy for projects ... That s why mine take so long ...
  5. jetnow1
    jetnow1
    from CT
    My father just went thru surgury for his back- had the same spurs pressing in the sciatia
    nerve, they missed one spur on the first round but got it on the second- 83 and he no longer needs a walker, hope your results are as good. Jim
  6. farmer12
    farmer12
    Still looking great koolkemp, but we need more pictures.:D:D:D
  7. 19Fordy
    19Fordy
    Wow! You sure have come a long way. Well done. My hat is off to you.
  8. koolkemp
    koolkemp
    Well I tell ya some days I feel 83 and could use a walker! I have a feeling they are gonna want to operate as I dont think any kind of physio is gonna make bone spurs dissapear ! If it helped your Dad it will hopefully do the same for me...
  9. koolkemp
    koolkemp
    I didnt get much done this weekend...froze my *** off all day sat working outside on my ol 12 valve ***mins ...electrical issues oh joy...like a fool I thought Mopar had there wiring issues resolved by then :eek: what a nightmare and even if I could push it in its too long to fit in the shop anyways. I did get some sanding done for a couple of hours on Sunday when I decided I wasnt freezing my *** off when I had a warm shop and some bondo to sand :D I will get some pics up in the next couple of night!
  10. koolkemp
    koolkemp
    Thanks! Much appreciated!
  11. BrerHair
    BrerHair
    I'm a member of that club! :)
  12. bbr
    bbr
    from Missouri
    what was wrong with it?? it didnt quit charging did it?
  13. koolkemp
    koolkemp
    Quit running after the wife started it...I found a broken wire near a fusible link that feeds the ignition switch, replace the bad wire,blew the FL ,replaced FL with a new fuse holder and 40 amp fuse, as soon as the switch is turned all the way to start it blows the fuse...the wire is fine all the way to the switch...dead short somewhere . I was gonna pull all the fuses and see if it will crank if it does I will start replacing them till it blows again, try and isolate the faulty circuit ...at least thats the current plan lol!
  14. fitzee
    fitzee
    Steve sound like that main power wire is grounding out somewhere. Can you find both ends??where it starts and ends. make a jumper and by p*** it. Try using a test light on the fuse.. power up the test light and use the fuse as the ground..light lights up it crossed out sonewhere..Oh and then cut the fuse out and try both ends to to see what side it is grounding on..
  15. zibo
    zibo
    from dago ca
    Big difference with the grille in there.
    The skirts really smooth things out.
    One of the original plans on my 40 was to have the 41 style bubbles on the bottom,
    but using the stock running boards was easier.
    Looking at your car I'm gonna have to see if I want to add a weeks work...
    Keep at it!
    TP
  16. shoebox1950
    shoebox1950
    that's a great looking chop!
  17. graverobber63
    graverobber63
    Alliance Vendor
    I just re-read this WHOLE thread from the begining. Steve, you are a ****ing MADMAN!!!
  18. spasecadet
    spasecadet
    from PDX
    Steve, a friend of mine had a similar problem with his. In his case it was the engine stop solenoid that cuts the fuel when you turn the key off. iirc its energized with the key on and can pull a lot of power when something goes wrong with it.
    Thought I would p*** that along.
    ~spasecadet
  19. OahuEli
    OahuEli
    from Hawaii
    So hows the body work coming?
  20. bobo1
    bobo1
    from France
    Very nice job on your car
  21. koolkemp
    koolkemp
    Thanks ..can ya tell me what it looks like lol? I really dont know much about diesels..its not gettin looked at till it warms up some...
  22. koolkemp
    koolkemp
    About as exciting as it gets ! I have been trying to get it fairly straight...less work to do later I am close to ready to get a fresh coat of epoxy on the roof/quarters and trunk lid, buts its still a little too cold to paint...which is how and why I kinda got carried away getting the mud work doneat least now I will be able to seal up the basic shell and get going on the rest of the panels. Anyways you guys seem to like pics :rolleyes: so heres a few boring bodywork ones. The yellow zinc primer is to keep the flas rust away from the bare metal spots where I have broken through the stuff epoxy on the car now.
    Door gap looked like **** so same idea as the other side 1/8 rod fully welded on..
    Bit of fine tuning later on and it will look pretty decent...
    I hated this side of the splash panel its pretty much covered by the bumper but I still had to re do it.Went super fast with the shrinker, new piece cut/formed and welded up in about 35 mins !
    Cleaned up and the offending area removed..
    Welded up ....notice I cut it too short and had to weld the end back on :rolleyes:
    kidcampbell71 likes this.
  23. The doors gap looks great. What a big difference on the before an after!
  24. koolkemp
    koolkemp
    This trunk gap drove me nuts till I fixed it this weekend...doesnt look like much but its much betters and I can live with it..it will get some fine tuning later anyways. The gap was too wide, and lower than the trunk skin in some spots and higher in others.I cut the whole edge off and did some reshaping then welded a piece of rod in, but it looks so much better.I forgot to take pics before but I am sure you could see it somewhere else in this thread.
    Splash pan is all moded in..
    See nothin to exciting to look at but a bunch of work nonethe less! I am looking forward to seeing it all primed up hopefully soon.
  25. BuilderRhys
    BuilderRhys
    Speaking of before and after!!!!!!!!!!!! From the two pictures you would not believe these are one in the same car (unless you read the entire thread that is). It looks incredible. Your the man Steve. Regards, Rhys.
  26. I'm impressed. You have some skills sir.
  27. 1/2done
    1/2done
    from Ohio
    Wow! I'd lost track of this build and just reread the thread. You've certainly come a long way. Lookin' good!
  28. aw1950
    aw1950
    Geesh Steve your moving right along . Its looking good and I agree that it will look even better when you get the primer to it . Then you will be able to fully appreciate the amount of work that you have into this thing. Stay at it . Later , Andy...
  29. GizmoJoe
    GizmoJoe
    Steve,
    Yup, it sure is "Looking good!"
    How much time are getting on it through the week?
    Cheers. :)
  30. TexasSpeed
    TexasSpeed
    from Texas
    Whoa. That looks killer! I love when 4-door to 2-door conversions turn out half as great as this one has.
