Need advices (pics ) on how to decrown a roof
Discussion in 'The Hokey Ass Message Board' started by Zed, Sep 29, 2011.
  1. Zed
    Zed
    from FRANCE
    thanks a lot ;)
  2. Zed
    Zed
    from FRANCE
    I've got an album on it on my profile :D
  3. Zed
    Zed
    from FRANCE
    yep i remember those two nice cars :)
  4. Zed
    Zed
    from FRANCE
    if you find it, i would like a link, cause i'm ****in unable to find it myself ! :eek:
  5. Rusty O'Toole
    Rusty O'Toole
    Here is a simple way to do it without a lot of metal work. Cut the roof off just above the drip rail and make a new roof with 1" wide 1/8" thick strips of flat steel.
    Make 1 strip every foot or so, across the roof like headliner bows. They will have to be different lengths to make a nice curve front to rear. But you can cut a form out of a 2X6 to bend them over.
    When you have a nice shape add long strips front to rear to make a basket effect. Weld together, this is your roof support.
    Cover with expanded metal, then thin cloth, cotton padding and another layer of cloth. Adjust the padding by poking it around with long needles until you get the shape right.
    Now cover with a vinyl top or sailcloth.
    This is basically the way a Carson top is made. You could make any shape you want with minimal metal working skills just bending and welding on the bows. Then cutting and tack welding expanded mesh.
  6. pimpin paint
    pimpin paint
    from so cal
    Hey Zed,
    Judgging from the way you handled the 403 2dr. conversion, the roof section shouldn't be a biggie for ya!
    I'm guessin that is the 403 wagon in the background of the 2dr. photos?;)
    My thinkin is that a roof section without a chop to the roof of that vehicle would make it look abit Volva 242 like! The 403's have nice rounded lines, and a section outa the roof would flatten that look:( I'm gonna guess that a chop thru the A,B & CPosts with a cut down winscreen would cause you legal trouble in france, no?:eek: A 2''-2.5'' chop would change the profile of that wagon without a stupid ''hey, look what I did to my 403'' look , and stay in scale with the design's basic flow. Maybe you could hunt up some stainless trim from a late fifties Simca, like a Vedette, to break up the plain sides of the 403 and two- tone it? A few grille teeth from bumper overriders of a Renault would look DeSoto grille toothlike, but in better scale for a 403?
    Your 403 2dr. looks hot!
    " Meanwhyle, back aboard The Tainted Pork "
  7. Zed
    Zed
    from FRANCE
    Talk about great minds :D
    the subtle look is exactly what i'm looking for . I don't want my roof to look flat at all ;)
    here is the photoshop i did : hard to figure it is chopped and decrowned :rolleyes:
    but it is :D i decided to keep it in 4 doors to fool even more ;)
    the chop is almost done... uh at least tacked:eek:. It's my first one , and i wanted to be sure everything is ok before welding it ;) on the pics the back door is not done, but i did it yesterday ;)
    it is chopped just 4 cm. not legal , you're right, but i think it's a matter of how cool are the cops, and they re cool when you're driving an antique, custom or stock .
    And noiw the best part : you've talked about late 50's simca side trim ? well it's the plan ! :D 59 Montlhery side trim with the front part replaced by another set from rear fenders to keep it straight ! i did a photoshop of it too
    on a Simca Montlhery, there is a brushed steel part inside the trim, but i will use it to two tone it . I ve got a NOS set a real good friend find for me ... very rare :eek:
    as for the grille, i'm not a big fan of bumper guards used as teeth... they look what they are :( you seems to know your french cars so i can tell you my plan. i will rework the front with a mouth and grill from a renault fregate, the one with the oval mouth, and vertical grill bar. the horizontal bar will be removed. i will use frenched simca versailles headlights rims, and 54-55 aronde tailites .
    Thanks for the words on my ex-sedan ;) i'm not fan of the look of the roof and overall proportions, but at that time i was afraid of chopping a roof... now i'm not :rolleyes: she will probably be next:D
  8. 'Mo
    'Mo
    Bravo, Zed! Looking forward to seeing this develop.
    Thoughts for paint? (Will be killer, no doubt! :cool:)
  9. pimpin paint
    pimpin paint
    from so cal
    Hey Zed,
    SWEETTTTTTTTTTTTTTTTTT!:D
    You've nailed it! The Simca side trim should give you plenty of different ways to go with colour on the sides of your wagon. The amount of chop, jus about perfect! 2''-2.5'' outa the crown should blend in perfect for a clean suttle ''hey, there's something goin on there, but what?" look.
    Yeah, the bumper overriders as grill teeth usually require alot of rework to pull off the correct look, but sometimes with using ones off the rear of a vehicle (usually smaller than the fronts), and with some pie cuts made, will work. The Fregate grill w/o the centre bar should add a very clean/tasteful almost '' Italian showcar '' look to the front area. I can't place the Versailles head lamp doors, are they the same as the Vedette?
    The Aronde tail lights should add a clean, not too large and outa scale look ,to the rear.
    For the final colour/s I'd go with a lite & medium based colour with pearl.
    You don't want the body mods to have to ''duke it out'' with the colour for first billing;)
    '' Meanwhyle, back aboard The Tainted Pork "
  10. Zed
    Zed
    from FRANCE
    Thanks Bro ! :D
    i still have no idea of the paint ! some time i imagine stockish french colors something like the one i've posted the picture, some time it's some pastels color ( kinda 50's american stockish color), but most time i'm thinking metallic paints, but don't have a special color in mind .to me color is probably the last think to choice, because when a build takes time, you can change of mind as many times as they is colors !lol!
  11. Zed
    Zed
    from FRANCE
    yeah , i'm looking for the " damn, i didn't knew those peugeot 403
    wagon were so elegant!"...hope i will aim that !lol!
    Versailles, Trianon, Ariane and Regence are some different name for the same car, the vedette , you're right ! not the one that resemble a mid century mercury, but the next one, but i think you figure that, because the one that looks like a mercury have very boring headlight rings, not so different that the one from a 403 ;)
  12. koolkemp
    koolkemp
    I think that looks great Zed! I really like the decrowned roof in the photoshop looks cl***y !
  13. pimpin paint
    pimpin paint
    from so cal
    Hey Zed,
    I don't think the roof panel section job will prove that tough for you, once layed out, and the corners releif cut, it will be just alot of welding and heat control.
    Any plans to radius the hood panel to clean up the shut lines, and perhaps ''pancake'' it? Also, check out the shapes of the front facebars on late fifties Renault Dauphines and Florides/Caravelles. They both have a shape that looks like a Kaiser overrider, built in to the design, on a much smaller scale. Perhaps you can use one below your Fregate grille choice? If used on the rear you'd have to invert it to clear the rear cargo door. Anyway, just a thought, and probably a bad one:eek:
    " Humpty Dumpty was pushed "
  14. Zed
    Zed
    from FRANCE
    lol! no, no reason to be ashamed !!;)
    You know your french cars very well ! i'm really impressed ! :eek:
    the front bumper from the cars you mention are very appealing. i'm gonna use the caravelle one on my coupe because of the overrider :D
    i will have to rework the hood because the fregate grille will be a little lower, but not the way you describe, but that way is planned for another project... great minds :D i've got way to much project on french iron ;)
  15. chrisp
    chrisp
    Could have asked Zed I did pancake the roof on my 58 Renault wagon.
  16. Zed
    Zed
    from FRANCE
    well, i was sure nobody has ever done that in france :confused: i'll take your pics if you have, and advices ( in french !:D ) . it's more a matter of bracing and what not to do that i'm looking for :)
    thanks for your help Chris ;)
  17. chrisp
    chrisp
    I'm building 5 cars at the same time for myself plus customer cars and don't post everything so...
    I never heard of a sectioned car either in France, still it doesn't mean it wasn't done (by me for instance ;) )
  18. Zed
    Zed
    from FRANCE
    i see your point, but if i had to section one of my pos i would prefer collect picture of that particular transformation here , on the hamb( and i've already done that) rather than searching for them pics of an hypothetical section job in france ...do you see my point ? :D
    I did my top chop after seeing zillion of pics here , and not a single one on french forum ... the number is the key ;)
  19. chrisp
    chrisp
    I wasn't talking about forums, I was just talking about hearing, most of the cars never show up on forums or magazines. I've never shown pics of the sectionning I did for a friend nor the pancaked roof on my Renault wagon (I probably took 3 pictures of that one 15 years ago while I was building the car but I'll try to find them for you)
  20. pimpin paint
    pimpin paint
    from so cal
    Oh Zeddddddddddddddddd,
    Did ya wack le toit of the wagon yet? Any mo peektures of your progress?:D
  21. Zed
    Zed
    from FRANCE
    Not yet my friend ! i worked on this car outside, and now it's -10° ( celcius) !!! too ****in cold ! lol! plus i've got miles of welding to do to my top chop before :D
  22. James D
    James D
    Nice ideas and two really interesting projects. I like seeing euro cars getting the treatment too.
  23. Zed
    Zed
    from FRANCE
    Since you've asked for it :D
    more in my profile ;)
  24. James D
    James D
    Ha, thanks, looks great. I should have read to the end of the post first!
  25. pimpin paint
    pimpin paint
    from so cal
    Hey Zed,
    Those are two smokin' hot projects you've got in progress!;)
    Maybe a 2''-2.250'' chop on the coupe' , and some clean, simple nave plates (wheel covers)- too bad '53 Caddie wheel covers are so expensive in france. Maybe some repopped Dodge Corrnet covers?
    Are the backlight & sidelights of the wagon made of laminated or tempered gl***? You won't be cutting down tempered ones:eek: Plexi-gl*** and Persiplex arn't legal, here in SoCal to run for window gl***, but some run 'um anyway! Who knows, maybe de gendarmes will look the other way on 'um:eek:
    'sorry to hear 'bout the weather:D It's almost spring, here in SoCal.
    Thanx for the photos-
    " The icecream truck in his neighborhood plays HelterSkelter ''
  26. chrisp
    chrisp
    The first years of Citroen ID had a plexi back window, some DB's too and Pichon Parat used that on his coachbuild cars, there might be others too, soooooo...
  27. bonez
    bonez
    from Slow lane
    Damn it Zed! I know your 2dor from a french forum! i remeber browsin in it years ago, there was a full build thread of the purple vedette that is on here as well. im pretty sure it was a general car forum with a custom section....
    Im not much into the flame job, but i aways dug those cars, they'd look bad *** choped.
    On the wagon, how much did you take out? never thought id say this, but sure it aint too mild? Work looks great thou.
  28. Zed
    Zed
    from FRANCE
    Thanks my friend ;)
    First plan for the "now coupe" was to rest unchopped. I liked the idea of an unchopped phantom coupe, but even with door size from the factory convertible, i'm not very please with the proportions. So now that i've chopped the wagon, and really enjoy doing it, i will chopping it too ! I'm not into hammered roof, so it will probably be subtle :)
    French car of that area came with tempered gl*** so i will probably made some new one, or use plexy. it's not legal, but gendarmes are cool with old cars ...even if the laws are not !! :D
  29. Zed
    Zed
    from FRANCE
    Thanks Bonez ;)
    I took only 4 cm ! It is supposed to be very subtle :D the decrowning is going to be very subtle too , i don't want a flat top . The idea of that car is to improve the original lines, but not being noticed by the average looker :D
  30. Skcollob
    Skcollob
    from UK, Kambs
    Nice wagon, nice project Zed...:cool: I have a Fregate wagon, it's my 'dream car' and I can't wait to start work on it. Mine was in a barn 25 years but is not too bad and will live again.
