Tips to remove underbody coating from firewall and inner fenders
Discussion in 'The Hokey Ass Message Board' started by johnboy13, Feb 13, 2012.
  1. johnboy13
    johnboy13
    I'm looking to remove some under body coating from the front of my F100. I've tried a wire wheel, a flap disc, and a scotch pad on my angle grinder with very little success. They all just gum up too quickly. What have you done too remove this stuff?
  2. porkshop
    porkshop
    from Clovis Ca
    Dry ice layed on the inside, and the stuff comes right off with a s****er.
  3. iamben
    iamben
    Get it warm and peal it off with a putty knife. If memory serves thats how we have done it in the past.
  4. Cymro
    Cymro
    Usually an eletric heat gun and a s****er, don't let the stuff burn, just soften and s****e.
    A squeeze bottle and water is good for flames, ( keep the heat gun out of the way)
    Mineral spirits or paint thinner on a cloth will get off the residue, Wear , mask, gloves and eye protection, horrible stuff.
  5. Mike51Merc
    Mike51Merc
    If it's brittle and on something that can take a little abuse, I use an air chisel with a blunt edge. If it's soft, I use a heat gun and a s****er.
  6. 49ratfink
    49ratfink
    X 2 for the heat gun and a s****er.
  7. aaggie
    aaggie
    Eastwood sells some stuff in a spray can that you spray it on and after ten minutes or so it wipes off. I haven't used the product but they have been selling it for years.
  8. I had to s****e the enitre bottom of my 50 Chevy. I used a propane torch and a s****er. Just get it soft and it will come right off. After I scrubbed it all down with mineral spirits and a green scotchbrite pad to get rid of any residue. It is a slow process but it worked well. Todd
  9. zman
    zman
    from Garner, NC
  10. heat gun with a s****er, and also had success with a wire wheel in a drill.
  11. fleet-master
    fleet-master
    get the wife to do it? ...no? ok heat gun and s****er. If its not tooo thick a sharp gasket type s****r will take it off cold.
  12. Butch/1
    Butch/1
    from Dublin ,Va
    Aircraft Paint Remover works good.
  13. william.ali.kay
    william.ali.kay
    from Milwaukee
    Heat gun and a s****er works great. Just remember to put down some cardboard or something. Otherwise you end up s****ping it off the floor later from stepping all over it.
    Dont ask me how I know.
  14. lincolnhead
    lincolnhead
    from Marysville
  15. txrider
    txrider
    from Texas
    The whole underbody and frame of my old military truck was coated in old asphalt undercoating..
    I used a needle gun to knock it off. Like you would use to knock rust off shipd or marine equipment. Worked better than anything else I have used, and not so messy. If you have a compressor that will run one.
  16. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Its dangerous but gas will break it down ,with lots of s****ing and rags
  17. Hotrodbuilderny
    Hotrodbuilderny
    Tried the wife didn't work so I got my soon to be son in law to do it that was 9 yrs ago.He's been married to my daughter for a few yrs now, don't know if it will be so easy the next time.
  18. 60 ford
    60 ford
    Heat gun and putty knife as said before.
  19. This..
    did this in less than a minute.
    I haven't used it underneath on the thick stubborn stuff, but I hope it's still pretty fast. I got mine at home depot
  20. joel
    joel
    I just finished my 40; Dual range heat gun on the low range (most of the time) and acouple of putty knives. Wipe the panel clean with laquer thinner, and it'll be like the day it was stamped. BTW, I tried the spray remover, and this is much better.
  21. johnboy13
    johnboy13
  22. zman
    zman
    from Garner, NC
    It's cool, so many people call it different things.
