Thinkin of turnin a big window to small split
Discussion in 'The Hokey Ass Message Board' started by Clik, Feb 13, 2012.
  1. Clik
    Clik
    I'm thinking of turning a big single back window into a small split window like a Willys or old VW bug. The car has a similar round shaped back. Are there any pics on here that might help me in fabricating this idea?
  2. FiddyFour
    FiddyFour
    post photos of your car... there are some absolute genius photoshop guys here on the board
  3. Clik
    Clik
    Oh, I've already got the visuals in my head. I'm just wondering what's the easiest way to do it.
    I guess I may have to spring for a flanging tool to make the steel lip, unless there's a better or easier way.
  4. put a cut down 38 desoto split rear in my 1949 Plymouth I built.
  5. SKULL ORCHARD
    SKULL ORCHARD
    from KS
    there is a 39 packard coupe in a u pick it lot here in kc ,double small windows would make a cool chop section.
  6. Clik
    Clik
    49 Plymouth: My Mom and Dad's second car after Dad rolled the Henry J. I can still smell that Plymouth's interior after all these years. That split window makes a difference for sure. I wasn't thinking of a transplant, I was thinking of building a flanged area inward and filling the voided areas with sheet metal.
  7. larry woods
    larry woods
    from venice fl
    Find one with the type of window you envision and sit in the drivers seat for a few mins gazing in the rear view mirror. that may help you decide.
  8. Clik
    Clik
    Ah, Hell, I don't care about the view. I'm a truck driver. We're used to not havin' a rear view. It's all about getting a different look from the outside.
    I am mostly thinking about how to make the flanged window frame without having to buy a bead roller or $300 flanging tool for one little job.
    If it weren't for all the round edges I could fold an edge over my half *** home made brake.
  9. You don't need a $300 flanging tool. Just get one of those cheap ones that go on your air hammer. That should work fine
  10. Clik
    Clik
    I haven't see one of those.
  11. Dizzie
    Dizzie
    Might be easier to graft in a section instead of making it. If interested, I have back window sections from a 1937 Lincoln Zephyr and 1937 Ford.
  12. oldcarfart
    oldcarfart
    I purchased my flanging/punch tool from Harbor Freight, once mastered it works great and the punch side works good for sheet metal plug welds.
  13. Hnstray
    Hnstray
    from Quincy, IL
    Since you don't want to do it the easy way, try this........
    Make a hardwood pattern (aka "buck") and hammer form the section. You can use hardwood or metal to make blunt "chisels" to form the metal in the tight corners. There are books and videos available for these techniques from several sources, such as Motorbooks.
    Ray
  14. Clik
    Clik
    Thanks for the offer Dizzy. I like the look of the Lincoln Zeph and 37 Ford but I think I would make the windows slightly smaller as my car is smaller. I may look into the flanger that Car Fart mentioned or the buck method Ray was talking about.
