19teen speedster
Discussion in 'The Hokey Ass Message Board' started by gastruk, Feb 14, 2012.
  1. gastruk
    gastruk
    from minnesota
  2. Crankhole
    Crankhole
    That is a hot rod. Bad *** !!!
  3. Jalopy Journalist
    Jalopy Journalist
    from Austin, TX
    That would look goofy as **** with a set of 18's and a sbc. I would love to see it with a set of E&J's and a Rajo head.
  4. RussTee
    RussTee
    visit north west vintage speedsters for a look see
  5. gnichols
    gnichols
    from Tampa, FL
    Thanx for the image. Yes, I'm thinking about a car along these lines, but updated thru the early 60's and with an O/T engine (blown I-4 or I-6). Gary
  6. UnsettledParadox
    UnsettledParadox
    as real hot rods get more rare we may end up just building speedster looking contraptions to fill the void. i know i would!
  7. JEM
    JEM
    It's basically an early sort of underslung frame.
    The spring mounting is either attractively industrial or just funky depending on your perspective.
    I'm working on a frame design for an underslung roadster, '30s Chevy Dubonnet front and floating-cantilever rear suspensions. Pictures of the frame design coming as soon as I clean up some of my sloppy CAD dimensioning in the model.
  8. Mr48chev
    That car was a real factory hotrod in it's day. No need for modifications to it.
    I'd think that it is a cut down racing version of and American Underslung from 1906/1908 or so.
    I'd sure like to build a speedster that resembled it with a small four banger under the hood.
  9. gastruk
    gastruk
    from minnesota
    A mid size pickup remove body metal drum for seats machinery tank for gas old semi brake handle squeeze handle brake 30inchers and ...the hood from a big air compressor has louvers and...
  10. JEM
    JEM
    You won't get an underslung axle configuration that way.
    I think the old American Underslung designs used something like 40in diameter tires (which I have to think had all kinds of potential for shimmy problems) but that's not really necessary, I've got what appears to be a workable configuration around 30.5-31in overall diameter.
    The big issue is scrub line, you need to make sure a flat tire won't leave some part of the car dragging on the ground.
  11. gnichols
    gnichols
    from Tampa, FL
    This photo just popped up on the vintage sprint car thread. Now, this is stylish! I thought cars like this only appeared in the dreams of Stefan Majoram! Now THAT'S a high cowl! Gary
  12. Crankhole
    Crankhole
    Definitely wouldn't happen on that rod. Nothin's hangin below the frame and there's plenty of clearance between the frame and the ground.
  13. Ryan
    Ryan
    ADMINISTRATOR
    Get the seat lower... and the column down as well... Sit in it, not on it... Then a banger with a Miller head. Damn thing would fly.
    I'd use something like 18" Ford wires for wheels... I guess would could chain drive it, but I'd rather see it with a closed driveline using one of those Fiat boxes that my boy Doug uses in Australia.
  14. Rusty O'Toole
    Rusty O'Toole
    Note how the frame is flat, is the lowest part of the car, and how it turns up at the front. One of the features of the car was that in real bad road conditions it would not hang up but skid over obstacles like a sleigh. This was brought out in their ads.
    Now think what the roads must have been like back then, to need 40 inch wheels and a frame like a sleigh lol.
  15. gastruk
    gastruk
    from minnesota
    Im thinking AMBR Trophy.
    With maybe a HUDSON.
    Tyres rear 700x20 firestone
    front 600x20 firestone
    Wheels Weld 20" x5" S74
  16. gastruk
    gastruk
    from minnesota
    See
    SPEEDSTEROD
  17. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
  18. HRS,
    Fred Simeone has a couple stock versions of the American Underslung in his collection... wonder what it would take to have him bring something to the RoG :D???
  19. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    maybe I will ask him when I see him... I will be down there soon :cool:
  20. gnichols
    gnichols
    from Tampa, FL
  21. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    [​IMG][/URL][/IMG]
    My Cousin built this and is working on another one.
  22. You LUCKY dog:D
  23. gwhite
    gwhite
    SUPER MODERATOR
    I'm thinking you're on the wrong website.
  24. pdunn10
    pdunn10
    what about an inverted dodge frame with parallel leaves, that would be flipped also. Put some A wheels or even bigger solid wheels. Gets the juices flowing a bit!
  25. gastruk
    gastruk
    from minnesota
  26. pdunn10
    pdunn10
    lose the disks/ fenders/ and Corvette wheels and you have a winner..
    Is that chain drive just so you could do it because there is no reason a drive shaft would not fit under
  27. I'ts been a while since I've had to quote this, but "while all things are permissible, not all are beneficial"
    Your drawing skills are admirable, but there is nothing attractive about the combination of parts and styles you have put together.
