Cheap but safe way to lower my 55 ford f-100
Discussion in 'The Hokey Ass Message Board' started by locospup, Feb 14, 2012.
  1. locospup
    locospup
    I need to lower my 1955 ford f-100 but don't alot of cash any ideas
  2. Let the air out of the tires.
  3. 296 V8
    296 V8
    from Nor~Cal
  4. Abomb
    Abomb
    Safe as hell too, you can't get up much speed with flat tires. :D
  5. locospup
    locospup
    not building a 50k street rod just having fun with a father and son project. any real ideas out there.
  6. dirtbag13
    dirtbag13
    mono leaves up front !
  7. shocker998md
    shocker998md
    mono leaf and spring under in the back. Maybe blocks too if you need them in the back. Then measure out for some cheaper monroe shocks over the parts counter and thats a start.
  8. Fatbob309
    Fatbob309
    Lots of great threads on this topic. Try the search.
  9. rocknrolldaddy
    rocknrolldaddy
    You can start by removing every other leaf in the front until you find the drop that fits your needs. You might not have the best ride but, if you get new shocks, it's not as bad. In the rear, run your axle on top of the leaf springs. I got spring perches for less than $20 from speedway, I think. I've seen guys run the axle right on top of the leaf springs. I feel safer with the spring perches and new shocks all the way around, I have kids. Thats the safest and cheapest way I've done it. It's around $100.
  10. Rico's Chop Shop
    Rico's Chop Shop
    Flip the axle and remove leafs
  11. LOST ANGEL
    LOST ANGEL
  12. jazz1
    jazz1
    I removed 3 leafs, shortened spring shackle added 2" lowering blocks on my IHC,all that brought it down about 5".
  13. no55mad
    no55mad
    Recently, there were some new springs in the cl***ifieds here.
  14. hr31hr
    hr31hr
    from PA
    See if there is a spring shop in the area that can de-arch them. removing leaves works well and while you are at it smoothe the edges and use teflon liners between the the leaves. Makes the ride much smoother.
  15. Damn angel,
    How will I ever unsee that. :eek:
    De-arch the springs. Move the axles to the tops of the springs. You can do both safley, maybe I should say I can do both safely, I don't know your skill set.
    dropped front axle, either get your dropped or buy a droped axle. You can also Z your frame on both ends, it has been done is not difficult.
    There is a pretty long list of backyard ways to make it squat. Choose one and research it.
  16. styleline
    styleline
    from so-hol
    take the wheels off
  17. AnimalAin
    AnimalAin
    Springs and dropped axles are pretty available and straightforward methods that work. If you have some fabrication skill, moving the axles to the top of the spring will get a substantial drop for hardly any investment in parts, but will require some fabrication and welding.
