1950 dodge short bus wayne conv
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Feb 14, 2012.
  1. iwanaflattie
    iwanaflattie
    So I am buying this shorty bus,it looks to be 57-60 dodge with a v8 poly engine,its very complete except the windshield (kids) and some missing windows,,,I am getting it cheap.
    The downside is that its got no ***le but its been sitting of this guys yard for more than 10 years.
    Are there any short bus experts on the hamb???
    I could not locate a vin,
    the guy says it needed a fuel pump and thats why he couldnt move it.
    the body is not rusty but its got Mississippi plates.
    Iwill try to take a pic of it soon.
  2. neverdun
    neverdun
    Save the plates, they can help you find the owner.
  3. iwanaflattie
    iwanaflattie
    Well I took some pics.
    anybody can help ID the year?
  4. Hnstray
    Hnstray
    from Quincy, IL
    That's a '58 to '60 ish model, not '48/'52, so the V8 is likely original.
    Ray
  5. Frankie47
    Frankie47
    from omaha ne.
  6. Frankie47
    Frankie47
    from omaha ne.
  7. Frankie47
    Frankie47
    from omaha ne.
  8. sololobo
    sololobo
    Cool old bus! ~sololobo~
  9. norville
    norville
    The parts stores sell a product called ozium (sp?) It's an ozone based spray , kinda expensive for a tiny bottle but works great. Unless you know someone with a shop style ozone generator...
  10. damagedduck
    damagedduck
    from Greeley Co
    i was told that lemon juice mixed with water will get rid of smoke stains & smell,pot??
  11. gas pumper
    gas pumper
    with luck on your side that windshield might have also been used in another commercial vehicle. An auto gl*** guy might be able to help you from the numbers on them.
  12. Dodge made that body through '66 on the Suburbans and the 58-60 cabs were used on their big trucks (think semi tractor) even longer. Gl*** looks bus only, though.
  13. typo41
    typo41
    I had a modern/older (84) short bus based on the chevy van for awhile and here in California it was handled as a car/suburban with no wieght fees, and the vin was the serial number stamed by Wayne, not the ch***is number.
    Hope this helps
  14. Rusty O'Toole
    Rusty O'Toole
    I bet the same windshield was used on all Wayne bus bodies for years, regardless of size of bus or ch***is make.
    Try your local auto gl*** company first. If they can't get one, you may have to try the Wayne company. Or search for another one in a junkyard. They often have old busses full of parts that they keep for years.
  15. stillrunners
    stillrunners
    from dallas
    it's RARE....as in MOPAR rare....
  16. That's a good point, the gl*** is probably Wayne, a lot of those busses from the cowl back the body was by the coachbuilder.
  17. vividlyvintage
    vividlyvintage
  18. vividlyvintage
    vividlyvintage
  19. outlaw256
    outlaw256
    man give them kids my #, thats gotta be some killer weed to still smell with broken gl*** and the wind going thru it! just kidding. ive always wanted a fixed up small bus to go to car shows in. but when i would find one it was always more than i could invest in it. ( needed to keep money for cars) lol good luck on it.
  20. Gromit
    Gromit
    At Home Depot here they sell an orange cleaner called Zep.. gallon jug is pretty cheap and it is an amazing cleaner. the local detail guy has used in cars and it takes a lot of .. aroma out. spritz it down and pressure wash tha mutha... good luck, it looks cool... once you paint over the graphics... cough....
  21. Chris Blatti here on the HAMB is having a "fire sale" on gl***.He can probably fix you up.
  22. How could you think that 4 headlights would be late 40's.
  23. tjmercury
    tjmercury
    That's a really cool bus! Just think of the possibilities
  24. 73RR
    73RR
    Remember that the 'A' series engines like your 318 had some major design changes for the 1962 model year so until you have a handle on what is what be sure to identify the parts you need by the model year.
    Yes, a later 5-speed would be a great up grade and you may not then need to change the rear axle. Do not, do not, do not swap the bell housing to anything 1962 and newer, make the trans fit the bell that you have.
    I do believe that a 400-440 will be make the rig more pleasant to drive. Some 70's pickups still can be found with 400-440 and manual trans...
    I really doubt that a front clip will be a good idea for the curb weight you have...prove me wrong with a trip to the scales. Please.
  25. evs1
    evs1
    Wayne should have some info in their archives including a source for gl***. Might try them.
  26. evs1
    evs1
  27. the sure fire way to get rid of the smell inside is to completely paint it....guaranteed to lose the funky smell.
  28. George
    George
    At least on modern buses the frame maker supplys the windshields & frames.
    Good chance it's a 4 speed, but with 1st & 2nd so close that 1st wasn't used. Probably monster steep gears.
    Even modern buses are solid axle & drum brakes, motorhome axle might just work.
  29. Rusty O'Toole
    Rusty O'Toole
    Engine is a 318 2barrel which was 230 HP in cars, may be slightly less in a truck version. Probably has a 4 speed trans, is the shift lever on the floor? They made a Loadflite automatic with the shift lever on the dash too.
    If the shift lever has a second knob you pull up it has a 2 speed rear axle, which was common on buses at that time. Putter around town picking up the kids then shift to overdrive on the hiway.
    Later model 1 ton and larger trucks have beam axles and disc brakes, so do some buses. If you can find one in a junk yard swap out the whole axle.
    Old school buses sell pretty cheap. If you found a late model you might be able to swap your body onto the newer ch***is. The local school bus service is the place to ask. During the summer is when they usually get rid of old buses and replace them in the fall.
  30. 73RR
    73RR
    If the smallish 20ft MH is a 1-ton cab/ch***is pkg it will be closer to the physical size of the bus and a better donor for suspension and rear axle if you can make the swap.
    Does the bus have the very-large 5 bolt wheels? They were also used on some other brands in the 40's and 50's so you should be able to find some if you keep the oem pieces. You might check here for wheels.
    As to a disc brake swap, ask olddaddy if he has any info.
