which do you like better?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Feb 17, 2012.
  1. #1
    I'm trying to decide if the cowl modification is worth it. I think it makes a big difference in the flow of vertical lines. The bottom of the cowl is stretched 2" forward in pic # 2.
    When the firewall gets reversed, ya kinda loose some girth there.
  2. Pete
    Pete
    Is this a trick question??
  3. Luckey7
    Luckey7
    Thats what i was thinking!
    I guess i dont see the change.
  4. See that's how subtle the change is.
  5. JMel
    JMel
    Took me about 15 p***es to figure out what the hell is different, but I finally see it. If forced, I like the first better...but also wonder if its that subtle, is it worth the time to do?
    I fully appreciate attention to detail, but somethings will just be lost.
  6. Master of None
    Master of None
    I kinda like pic number 2. Fills in the dead space nice.
  7. Pete
    Pete
    I give up!!! Someone please tell me>>>>>
  8. Pete
    Pete
    Hmmmm......forget it.
  9. 303e10
    303e10
    from kansas
    the 1st picture is the best
  10. #1. Two looks goofy.
  11. fleet-master
    fleet-master
    pic one looks better IMO the extra piece makes cowl look too fat
  12. john mullen
    john mullen
    My vote.... #1 all the way. Very cool car
  13. You guy's serious? You don't see that??!!
    No#1 By a long shot, but mate it's your car it may be a hard decision but it only has to please you.
    Doc.
  14. flatout51
    flatout51
  15. flamedabone
    flamedabone
    I would leave it alone. My mind knows what that is supposed to look like and when it is diffrent I'm drawn to that area trying to figure out what is "wrong."
    But, the whole area would look diffrent with or without a hood sides...
    The car looks kick *** by the way. Nice swoopy frame rails and the lower cowl panel looks right at home with the frame.
    Nice work, -Abone.
  16. Just Gary
    Just Gary
    I agree with Jeff K.
  17. I was thinking that in stock form it shows the rake a little too much right there with out the fire wall extending past the cowl. Looks kind of odd, top heavy cowl and.... well thats why I'm asking. Certainly not after the broken back look. The proposed addition follows what the profile of the fire wall would have been except for the toe board return. I would add the piece behind the detail and retain all of the leading cowl edge, just move the bottom edge or swing it forward. It's a 0 to 2" over 22" pie piece.
    Thanks for the compliments guys.
  18. OK cool! You could put an angled 'lump' in each side of the bottom of the firewall like a 32, that would knock off the rake look a little.
  19. Molonewolf
    Molonewolf
    Another vote for#1.
  20. Hdonlybob
    Hdonlybob
    Me too on #1.
    Cheers........
  21. knotttty
    knotttty
  22. ct1932ford
    ct1932ford
  23. junkjunky
    junkjunky
  24. tomkelly88
    tomkelly88
    I'll vote 1 also
  25. 60 ford
    60 ford
  26. tb33anda3rd
    tb33anda3rd
    number 1, number two looks...well...like number two. the second picture modification reminds me of a replica body.
  27. hotroddon
    hotroddon
  28. Big Jon
    Big Jon
    number one , because it visually seems to match the angle of the door gaps better?
  29. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Damn I was looking at the tape lines.For 5 minutes....Cant comment on the peice of steel you added in second pic.....
  30. metalshapes
    metalshapes
    If you want to lengthen the cowl, I'd to that behind the vertical characterline not in front of it.
