Mounting radiator sideways?
Discussion in 'The Hokey Ass Message Board' started by jmlcolorado, Feb 18, 2012.
  1. jmlcolorado
    jmlcolorado
    from Parker, CO
    Hey folks. Been a while since I've been on here.
    Just picked up a radiator that the right dimensions for what I need, cept the wrong way.
    I need it to be taller then wide.
    Jas anyone ever run one clocked 90 degrees?
    I'm thinking of cutting off the filler cap and mounting it on the side......which will be the new top.
    Any words of advice?
  2. chrisntx
    chrisntx
    from Texas .
    this was discussed not long ago
    search is your friend
    that car looks insane
    ratrod?
  3. jmlcolorado
    jmlcolorado
    from Parker, CO
    I tried Clocking radiator, rotating radiator, sideways radiator.....which have turned up no results. Found fitting a mustang radiator in an A grill, but that's not quite what I'm looking for.
    Advice on a better search term?
  4. Engine man
    Engine man
    from Wisconsin
    I haven't done it but I don't see any reason that it won't work.
  5. fiddy
    fiddy
    It works just fine man.
  6. tfeverfred
    tfeverfred
    I thought it was going to be a boring saturday night. Help has arrived.
  7. Gerry Moe
    Gerry Moe
    I am currently running a 392 hemi w/671 blower with the radiator mounted with tanks on the side. It has been done for years in GM products
  8. airbag
    airbag
    Holy rat rod
  9. That would make it a "crossflow" radiator (which were post '64) which would mean your ride would lose its traditional status ...... or so it seems.
  10. a.y1320
    a.y1320
    Those spikes will scare off would be thieves. Good think
  11. 296 V8
    296 V8
    from Nor~Cal
    Iv seen GM cross flows turned for use in 32 shells ... it works fine.
  12. airbag
    airbag
    Thieves wouldn't even steal that, that thing is too sick. Hahah
  13. gnichols
    gnichols
    from Tampa, FL
    Some sprint cars have horizontally mounted radiators down low and ahead of the front axle. But they are ducted so cool air flows below them and then upwards thru the core. The hot air is then ducted up, back and out thru a vented area in the hood. I think they may get some downforce from the way the air is moved thru the nose, too, but I don't know for sure. Have fun, Gary
    Never mind, I was thinking of my other sideways. Gary
  14. badshifter
    badshifter
    Let's pretend those are clecos.
  15. jmlcolorado
    jmlcolorado
    from Parker, CO
    They are currently holding the top and bottom half of the cab together prior to welding. They will be removed :cool:
  16. jmlcolorado
    jmlcolorado
    from Parker, CO
    I apparently need some education on how radiators are built and function too.
    I always thought that all the little tubes were all together causing the antifreeze to enter them, p*** back and forth through the radiator allowing cooling. My thinking was that this action kept the same amount of fluid in contact with the cooling fins as long as possible to cool as much as possible.
    I was thinking the tubes looked similar to a transmission cooler, or even a refrigerator coil on the back.
    In looking inside this radiator, It seems the tubes only go from one side to the other. So anti freeze would fill from the bottom, work it's way to the other side rather quickly, then re enter the engine?K
    Also, on a SBC 350, does HOT coolest enter the top or bottom of the radiator? Does the water pump **** or pump from the lower hose?
  17. Hnstray
    Hnstray
    from Quincy, IL
    Most engines pump (hot) water out the top, into the radiator, either vertical tube or horizontal, from there the water is cooled as it p***es through the tubes, to bottom or other side and reenters the engine via lower hose.
    Late model GM LS series engines, and perhaps others, use "reverse flow" .
    Ray
  18. Willy301
    Willy301
    JML, the tubes are not continuously connected within the tanks, they all just p*** fluid from tank to tank, regardless if they are horizontal or vertical. It should work for you, good luck on the rest of the build...
  19. jmlcolorado
    jmlcolorado
    from Parker, CO
    Sounds good. We'll give it a shot.
    Thanks folks!
  20. GassersGarage
    GassersGarage
    This was mounted sideways in a '51 Ford G***er. Worked fine.
  21. It looks as if we will soon see another buck toothed, early body on a late ch***is, abortion. God, I hope I'm wrong. Every time I see one of those bug eyed creations with the radiator sitting two feet ahead of the axle centerline, I die, just a little bit, inside. They all look like an old Walter truck.
  22. Shane Spencer
    Shane Spencer
    was JUST looking at a 57 chevy truck build. sideways mounted radiator. all worked fine for him
  23. 49ratfink
    49ratfink
    yeah.. from the pics shown it does not look very traditional.
  24. Hnstray
    Hnstray
    from Quincy, IL
    It's a COA......cab over axle :D
    Ray
  25. jmlcolorado
    jmlcolorado
    from Parker, CO
    ACTUALLY, the word is not abortion, since I am not prematurely ending this trucks life. I am, however, saving it from certain death.
    Perhaps the word you were looking for was abomination.
    I, personally, think the trucks proportionately well. I have spent a great amount of time to make NOT look like an "abortion" .
    This photo shows the truck prior to relocating the rear axle to properly place it in the wheel wells.
    And just to clarify further, the engine is behind the wheels and the radiator will be a couple inches in front and be the furthest forward point.
  26. Ummm, your chop is uneven from front to back... reverse rake?
  27. hotroddon
    hotroddon
    A0dn yet we all lose :eek:
  28. Why not a tractor radiator to fit your tractor grille ??
  29. El Caballo
    El Caballo
    from Houston TX
    This is not going to end well.
