sprung or bagged
Discussion in 'The Hokey Ass Message Board' started by ASPHALT RIPPER, Nov 17, 2010.
  1. robleticia
    robleticia
    ^^^^Well said!
  2. octobeak
    octobeak
    Im running a sprung suspension about as low as possible. I manage to get around town white knuckled with my front bodywork about 2 inches from the asphalt(I don't recommend this to everyone, you have to look far ahead and not follow very close). My bodywork is far from being started so I don't mind the mild s****ing now and then, but I have plans on modifying the chin to rectify my situation down the road.
  3. Hemi8me
    Hemi8me
    I would think here in the Northeast.......Bags would be a must. My driveway has a steep approach, so I am thinking bags is the only way to get to the garage.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  4. 49ratfink
    49ratfink
  5. dt50chev
    dt50chev
    Mine is a static drop for now. Front fenders are less than 4 inches off the ground. This is usually not a problem except for a few speed bumps. I would like to get it lower, but this will require bags to be driveable and I am willing to install them when the budget allows.
  6. stamierdodge
    stamierdodge
    looking into my 48 Plymouth i found to lower the front anywhere close to what i wanted would be way to expensive. drop uprights and coils aren't cheap for a mopar, so the way i see it is why not bags to get as low as i want and be able to go everywhere i need to. washington isn't flat! that being said you guys keep saying "done properly" bags not touching anything.... what else?
  7. hustler1984
    hustler1984
    from lindsay ca
    I have complete build pictures of this one I did if you need any help just let me know
  8. Zandoz
    Zandoz
    For me I'd have to say springs. The only way I'd go with bags is if I could afford to have them professionally installed I've seen too many butchered bag installations.
  9. Shane Spencer
    Shane Spencer
    theres a guy with a BRIGHT yellow chevy custom ( 51 or 52 ? ) in maryland that is slammed without bags. he said he s****es like hell everywhere, just added some plates in areas underneath. but he still drives the hell out of it on **** maryland roads
  10. fluiddrive1949
    fluiddrive1949
    from Austin TX
    Im thinking about bags just in the back of the wifes car. Its a 54 cadillac he**** an like 22feet long the whole sideways speed bump crossing manuver does not work in a car that long! also gets hung up on spots the other lowered cars drive right over
