1955 pontiac hydramatic
Discussion in 'The Hokey Ass Message Board' started by roaddevilray, Feb 18, 2012.
  1. roaddevilray
    roaddevilray
    from LA
    I have a 55 pontiac hydramatic along with the 55 pontiac mill. My question is do I need to have a pilot bearing for this trans? It does have a bit of a shaft sticking out of the front like a manual trans but it has 30 bolts from the torus to the flywheel. I didn't notice if it had one when we broke it down.
  2. damagedduck
    damagedduck
    from Greeley Co
    i don't remember any of mine one.
    The repair book only mentions it for standard shift trannies
  3. roaddevilray
    roaddevilray
    from LA
    Yeah that's what I figured too.
  4. andy checchia
    andy checchia
    from USA
    There is a roller bearing that goes into the crank for this transmission. Ames Engineering in New Hampshire sells it.
    Andy
  5. 56sedandelivery
    56sedandelivery
    They do take a "standard transmission-like" pilot bearing. The only real difference is, it is exposed to trans fluid, while a standard shift trans is not (except for the old MOPAR auto-manual trans). Butch/56sedandelivery.
  6. d2_willys
    d2_willys
    from Kansas
    I have both the engine and trans, and ALL single and dual range hydros up to 56 (62 for trucks) (when the DC hydro replaced it) had the pilot bushing. Some used bearings, some used simple sintered bronze bushings. My Pontiac has a ball bearing installed in it.
  7. roaddevilray
    roaddevilray
    from LA
    Thanks guys. Appreciate it.
  8. 55yak
    55yak
    Yes, pilot shaft does stick into pilot bearing of crank. Be sure and seal the flywheel to
    the crankshaft or you will have a leak. Use a good anarobic sealer. Also use something that doesn't harden like Hylomar on both sides of your torus gasket. If you
    want to do it right, check flywheel run-out 1st. Any more than .007 and you will have front pump leak after awhile. I know from experience. These slant pan hydros work great, but you have to be careful of leaks.-John
