Hot Rods Stripping with a grinder
Discussion in 'The Hokey Ass Message Board' started by Leadsled612, Feb 19, 2012.
  1. Leadsled612
    Leadsled612
    Spent a few more hours today with the 4 1/2" grinder stripping rust areas to clean white metal with flap discs.
    A very time consuming effort...however much needed.
  2. mastergun1980
    mastergun1980
    from Alva OK
    When I read this ***le I pictured a 7" angle grinder with a 1/4" thick grinding wheel! Thankfully it looks like you're using a flap disc! Looks good!
  3. sixtysicks
    sixtysicks
    What type of disc are you using exactly? Im in the middle of the same job on my 66 Chevy. Ive been using chemical stripper and a DA
  4. Very cool. What kind of discs were you using in the grinder?
  5. skyrodder
    skyrodder
    no flap disc! use a paint buster its easier on the metal, flap disk sands the metal while paint buster does just that busts paint off..
  6. The37Kid
    The37Kid
  7. IFABSTUFF
    IFABSTUFF
    Thats how I like to strip to bare metal too. Nitrile gloves are a must too.
  8. Leadsled612
    Leadsled612
    Lowes has their "DeWalt" brand flap discs wich seem to hold up the best. I've tried local hardware stores and their off brands just don't hold up. They were too stiff and not as beafy.
    The troubled areas I started with 36 GRIT --- 60 GRIT--- then 80/120 GRIT.
    I didn't want to spend the $$$ to get her blasted...call me cheap, so I did it myself for about $55.00.
  9. fastcar1953
    fastcar1953
    that was my thoughts. i used about 5 of these and about 15 hrs.
  10. mastergun1980
    mastergun1980
    from Alva OK
    You did all that for $55.00 !?! I'm impressed!
  11. Leadsled612
    Leadsled612
    Skyrodder, these are awesome! I used them to cut the painted surfaces to the metal and then took care of the rust!
  12. IFABSTUFF
    IFABSTUFF
    by the way ledsled612 looks sweet, bare metal is soooo bad *** in my opinion. ****s that steel rusts
  13. Leadsled612
    Leadsled612
    I still have the roof and "A" pillars to do and so far the clock was 14hours. My guess is another 6 hours
  14. fastcar1953
    fastcar1953
    i am not completely done myself. it really is not that bad to do. less mess than stripper and cheaper than blasting. car looks great by the way
  15. Leadsled612
    Leadsled612
    I'd love to have a car in bare metal form with perfect machined swirls in pattern. Would look kick ***!
  16. Scott
    Scott
    I use a 3m pad on a polisher/sander does a good job but I still hate it:rolleyes:
  17. jerseymike
    jerseymike
    just went through your album of over 1000 pictures! really nice job on the chop. i like how you did the side quarter windows, for me that rear curve can make or break the whole chop. can't wait to see it in paint. pick a color yet? good luck.
  18. Leadsled612
    Leadsled612
    thanks for the compliment Mike.
    Goin black...
  19. Chucky
    Chucky
    I used a twisted wire wheel(s). I did a whole truck with them. They don't remove metal. They do bust rust and take out seam sealer/bondo too.
  20. Buddy Palumbo
    Buddy Palumbo
    YIKES ! Black is such a ***** - the car's gotta be more than perfect to pull it off . I'm sure I'll never have a black-worthy car , because I don't have the patience and I like to drive my stuff . Yours looks like it's well on it's way to being worthy though . Keep the updates coming !
  21. I was hoping for a stripper with a grinder
  22. Willy301
    Willy301
    When he said "stripping with a grinder" I expected to see a pic of his t-shirt wrapped around his angle grinder and several new cuts and abrasions... Definitely a better pic was shown, nice car! I agree about the black though, bodywork needs to be spot on and then some. Car seems to be in really good shape to start with though..
  23. Leadsled612
    Leadsled612
    I agree the body must be near perfect for black paint. I will leave that up to the body shop for the finer details. In addition I am flaming the merc from front to rear...this will break up the larger body areas of any inperfections.
  24. marman1950
    marman1950
    Rapid strip is the way to go. Works very well. Your hands will be shaking like a old man at the end of the day but it's cheaper then blasting!
  25. carlitos way
    carlitos way
    i also like to strip with aircraft stripper and the "da" but i like using the larger "hog" sander it has been the best for me.beside walnut shells
  26. 46fatford
    46fatford
    Where can I get the Norton paint buster discs for my angle grinder?
    Thanks
    Matt
  27. john walker
    john walker
    the paint buster discs tend to clog with paint and primer in a few minutes and don't work so well after that. i'm stripping a '50 cadillac now and that's what's happening. some paint may be easier to strip with them. this stuff doesn't wrinkle with aircraft stripper either, just turns into a drooly goo. i guess it's going to be the drooly goo method, after spending $100 on a bunch of those pads.
  28. cederholm
    cederholm
    You look much better in your avatar! :D
  29. mashed
    mashed
    from 4077th
    So nobody's disappointed.
