6 volt fun!
Discussion in 'The Hokey Ass Message Board' started by 91bluecamaro, Feb 19, 2012.
  1. 91bluecamaro
    91bluecamaro
    I have the 49 Pontiac w/ the 6 volt battery. I hooked up my charger to it and its not even lighting up:(. I know my chargers ok because I hooked it up to the 56' battery andit lit right up. Is there an option besides buying a new battery? I know growing up that you could put acid in some batteries... Any suggestions?
  2. squirrel
    It's an old dead battery? if so you need a new one....
  3. F&J
    F&J
    Some/most battery chargers won't start to charge if the battery is dead flat. Hook another 6v battery with jumper cables to get it to trip. Then it will charge, but no gaurantee that the battery will hold a charge if it's real old.
  4. Ken Carvalho
    Ken Carvalho
    Or you can daisy chain a charged battery with jumper cables or alligator clips and wire also. Newer chargers need to "see" an excite source before they will start charging. Like the excite wire on a GM alternator.
  5. 91bluecamaro
    91bluecamaro
    Not sure what you mean by this:confused:, draw me a map brother!:D
  6. 48 Chubby
    48 Chubby
    Simple test.
    Turn on the charger to 6v low amps with no battery hooked to it.
    Tap the charger's two hook-up clamps together.
    No spark="excite type" charger
    Sparks=need a new battery
    If your charger needs an "exciter current" hook two batterys together (one with some charge in it) with jumper cables-Pos to Pos Neg to Neg. After a few minutes unhook the exciter battery.
  7. squirrel
    If you have an old battery charger, one old enough to have a 6v setting, then it kinda implies that you have a defunct battery.
    But you never know...maybe screwing around with it for a while will get it to sort of look like it's working sort of. I haven't had much luck that way.
  8. 91bluecamaro
    91bluecamaro
    Ive got a simple trickle charger...
  9. junk yard kid
    junk yard kid
    Did you see if its out of fluid? put some water in it.
  10. tb33anda3rd
    tb33anda3rd
    four years or older...don't waste your time get a new one. went dead more than two times...don't waste your time get a new one.
  11. jan bogert
    jan bogert
    sorry to say, your battery is gone!!!! time to rob the cookie jar. isn't it fun to own these cars.;)
  12. Ken Carvalho
    Ken Carvalho
    48 chubby described what I was meaning. Pos. to pos., and neg. to neg. with a working battery! Either with jumper cables or by another means of connecting them, such as alligator clips with wires connecting them.
  13. 91bluecamaro
    91bluecamaro
  14. 48 Chubby
    48 Chubby
    Time to buy a battery. Time to budget some funds for a good battery charger too if you gonna be messin with old cars.
  15. tb33anda3rd
    tb33anda3rd
    batteries are actually a good value about $60 for 60 month battery works out, for all the work it does, to picking up a returnable can or two a day.
  16. 68hillbilly
    68hillbilly
    from KENTUCKY
    IF you can't afford a new battery , try putting a few asprin in your old battery, and then charging it up. I have seen this work before. won't make it new but might help for a while. i know it sounds crazy.
  17. tb33anda3rd
    tb33anda3rd
    don't forget to check at the local bone yard!
  18. jan bogert
    jan bogert
    and when you do get a battery, go to walmart and get a $25.00 battery tender, so this doesn't happen again. JAN.:)
  19. d2_willys
    d2_willys
    from Kansas
    Walmart has Battery Tenders for $25, really? Are they 6 Volt variety? My 6V BT's cost $39 each and I looked for the best price, and that was 4 years ago.
  20. 91bluecamaro
    91bluecamaro
    got a battery tender, got the car yesterday, battery was already dead. Where can I get a 6v for $60?
  21. 91bluecamaro
    91bluecamaro
    So who has these? Not the cans, the batteries...
  22. Ford52PU
    Ford52PU
    from PA
    Tractor supply has 6volt batteries.
  23. F&J
    F&J
    Autozone had them a couple years ago when I was looking.
  24. d2_willys
    d2_willys
    from Kansas
    Tractor supply, Orschellins, Bluestem, those kind of places that are tractor and farm equipment suppliers. You could also get a 6 Volt Optima, but they run about 150 dollar. And from what I heard, the quality is questionable now. Had one for over 10 years before I killed it. Was great.
  25. Saxon
    Saxon
    from MN
  26. 91bluecamaro
    91bluecamaro
  27. Saxon
    Saxon
    from MN
  28. 91bluecamaro
    91bluecamaro
  29. 91bluecamaro
    91bluecamaro
