Tarps made it worse. Rain crept under and rusted roof. Pop up garages? One of those bubble things? What do u use?
My Fairlane has a coat of paint on it. Works perfect for keeping rust away.. Sorry. Couldn't resist. Don't know what you would use. Seems like a good coat of wax or oiling it would keep the rust at bay.
Not cheap but it works. http://www.radrides.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=Gear&Category_Code=Protectants
Dont....unless you live in the driest desert around......Humidity is going to get at it ...Where is Silverlake?
For the money you will spend on high dollar protectants spray on a coat of epoxy primer. ouitside rust is hard to prevent unless you have the area heated.
This hood has been sitting in a garage for a year.. Just a little rust.....epoxy would be your best bet.....
I made a removable tarp "tent" over my leaky camper roof using PVC pipe. Now it looks like a covered wagon. A side benefit is that the tarp seems to be lasting longer. Did the same thing with some pallets on my bare metal model T frame. The pallets hold the traps off the car. You can pick up pallets for free on Craig's list or at many hospitals. The sharp corners tore the tarps in the wind, though. I may tie some rags around the corners of the pallets when I replace the tarp. Good luck.
Make a tent over it to keep the tarp from touching it. Tarps don't keep moisture out for long though, so a good coat of epoxy primer and the suspended tarp are your best idea.
I have been using WD-40 to keep the rust at bay on the parts of my truck that are stripped to bare metal, no rust yet. No idea how hard it will be to remove when it comes time to paint. I would find some sort of shelter or carport to keep it under so as to not trap the moisture.
im going to spray a car tomorrow with plasti dip you will not believe how preserved that car will stay the younger kids are using it to give the rice burner cars that flat black look on hoods and stuff with out having to damage or permenatly change the car you spray this stuff on and can peel it off later you can see a ton of videos on you tube http://youtu.be/z3u5pDMKI1A http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=plasti+dip&langId=-1&storeId=10051&catalogId=10053
WD-40 soaks into the metal. My neighbor used ATF when his car was in bare metal. He drove the car on a shake-down cruise to Arizona from So Cal to make sure everything was fine, before it was painted.
Holy cow, THANK YOU! I had no idea that stuff would peel off like that when you're ready. I don't even know if I'll ever use it but just knowing that feels like valuable information.
If you don't plan on ever painting it I would try Gibbs or heck just rub it down with linseed oil..But if you plan on painting some day any of those products could haunt the **** out of you come time to paint..I had to put this bare metal project outdoors for while so I wrapped it up in a coat of epoxy,,,about $7.00 worth of product..I have seen some bare metal rods at car shows shot with coat of clear however I don't know how long that will adhere to metal.
