truck dies or sputters when I brake hard?
Discussion in 'The Hokey Ass Message Board' started by sixtysicks, Feb 21, 2012.
  1. sixtysicks
    sixtysicks
    My truck dies or sputters anytime I brake hard, like it runs out of fuel. Im not sure what the problem is. Carb issues? Any ideas?
  2. Ob1
    Ob1
    Got vacuum ***isted brakes? Could be a leaking booster.
  3. themoose
    themoose
    Check your float level.
  4. could just be the float run some in the tank carb cleaner
  5. Mr48chev
    I rather agree with Themoose in that I'd be checking the float level. If it is too low the low speed or idle circuit may be getting uncovered during hard braking if it only happens during hard braking.
  6. davedriveschevy
    davedriveschevy
  7. #1 sounds like a carburetor float problem causing flooding issues. Verify float level
    #2 check also the attachment hardware on the carburetor , causing vacuum leaks, make sure the carburetor base and body are tight.
    #3 I've seen a bad ignition switch causing the same symptoms, the guy had a huge wad of keys that acted like a pendulum, basically wore the switch out.
