Projects New Hauler for the Strange Bird gasser! 1950 Chevrolet COE!
Discussion in 'The Hokey Ass Message Board' started by Chuckles Garage, Feb 7, 2012.
  1. spankster
    spankster
    Nice COE. You see less of those 5400 series 134"in. wheelbase Chevrolet COE's than you do the more common 5700 series 158"in. wheelbase COE's. The 5100 series 110"in. wheelbase are even less common.
  2. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    No, the Strange Bird only went to europe in print.....not selling it haha.
    The original ch***is is staying. I'm going to swap in the 364 nailhead, and use the stock transmission, and PTO. The only thing I may modernize is the axles. I have access to a set of axles from a c6500 Kodiac cab and ch***is that I may use. Waaaaay better brakes, and the tires will be radial 19.5" instead of bias ply 20"
  3. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Scotty..you could call that hauler the "Krow's Nest"
    ha ha ha
  4. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Hmmmmmmm....or simply, "Bird's Nest"
  5. captainjunk#2
    captainjunk#2
    thats cool , what an awesome period car hauler it would make
  6. Shopking
    Shopking
    from central Pa
    If you paint it white.do a lot of brightwork up front like your silverado.
  7. M.Edell
    M.Edell
  8. carlisle1926
    carlisle1926
    If you swap ch***is, a good candidate for a ch***is is the 1980's/90's Chevy/GMC 3500HD 1-1/2 ton trucks. These are the trucks that have a heavy duty straight axle from end and 19.5" wheels. The rear ends are ten lug and they have a much better gear ratio than the original stuff. They also have disc brakes on all four wheels. They can handle the load of a car on their back. They use these ch***is under a lot of tow trucks and box vans.
  9. TexasSpeed
    TexasSpeed
    from Texas
    Nailhead for sure!
  10. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Hmmm......the 364 Might go in my newly acquired Hillman Husky....
    Still....it NEEDS nailhead power!
  11. fabmancoe
    fabmancoe
    Nice build material for a hauler...you guys should join the COE group if you haven't...lots of ideas and coe trucks in progress. It is a good group of guys. Good luck with your hauler build. Fabmancoe
  12. Cornerwindows
    Cornerwindows
    from Oregon
    Just saw it on Ebay, good luck with the sale.
  13. breeder
    breeder
    Bummer. Was looking forward to this build!
