Flatheads....... lets see 'em!
Discussion in 'The Hokey Ass Message Board' started by sonoramic, May 14, 2009.
  1. My C59A, currently stock except for duals and Smithys.
  2. Dirty Dug
    Dirty Dug
    Here's some heaters
  3. Nobey
    Nobey
    Here's a 46 Merc I bought years ago. 99a 962**x stamped on the deck.
    It has Thickstun heads and manifold with 48 carbs. Turns over easy but
    has very little compression. It came with a chrome generator, I took off
    for My 32. It was painted gold originally but I have no history on it.
    Just thought you guys might enjoy seeing it.
  4. SteveB30
    SteveB30
    from Minnesota
    Hope I'm not digging this up from too far back but I saw a lot of nice setups in here. I'm not anywhere close to the majority of what is posted in here but here's my 8ba that I picked up this last summer for my model A pickup. The truck was originally going to get a 283 SBC until I stumbled on this at BTT50's and had to have it.
    Its not much now, but it runs. Going to run it as is for a few years after some cleaning, valve work, new head gaskets, and some paint. At this point I have more time into the engine stand and headers (priorities right?) I only hope that when I finally tear it apart that I don't find any serious cracks.
  5. 19Fordy
    19Fordy
    Run it and enjoy the "motor boat" rumble of a flatty.
  6. bobo1
    bobo1
    from France
    My french flat strocker and blow
  7. 19Fordy
    19Fordy
    Holy Moley, the blower is bigger than the engine. Extra cool.
  8. bobo1
    bobo1
    from France
    and my small flatheads
  9. In my 37 Ford pickup.
    221 with factory alumilum heads and intake.
  10. jack orchard
    jack orchard
    looks great. also, nice job of block smoothing...jack
  11. jack orchard
    jack orchard
    great work. i have heard of instances when the cast-in bellhousing breaks when supporting a complete engine on a stand. are the french blocks stronger? any thoughts? best of luck on all of your projects...jack
  12. paulie_boy13
    paulie_boy13
    from NC
    my 276. baron heads ,Navarro intake etc. H&h built.
    Sorry about the huge pics
  13. fenderless
    fenderless
    from Norway
    Looging really nice:)!
    I like them Baron Heads!
    Please post some more pictures!
    If you can, a picture from the front?
    Taildragger&fenderless
  14. Ramblur
    Ramblur
    My old Hornet motor broke both compression rings on #5 last year. Already .060 over on the bore and .030/.030 on the crank I went to plan B.
    The spare motor that came with the car ended up being a NOS never run factory deal that had been stored not so well. Now going together as 7X
    Nascar replica with more cam/bigger valves. Can't wait.
  15. ct1932ford
    ct1932ford
    My 1933 block!
      251.3 KB
  16. hombres ruin
    hombres ruin
    paulie what do you use for the element in your air filter?
  17. paulie_boy13
    paulie_boy13
    from NC
    Hombres Ruin, Haven't gotten that far yet but I'm thinking of finding the biggest, squarest k&n rated for this engine size then cutting it up (rubber dipping the edges to hold) and stuffing it in there.
    Fenderless, I'll see if I have a front shot to post. (looked I didn't have any shots worth posting, sorry)
  18. Tequila Bob
    Tequila Bob
    from Michigan
    Here is mine. 1949 8BA. Jerry Magnuson Twin 220 Supercharger set up.
  19. Tequila Bob
    Tequila Bob
    from Michigan
    Here is what I'm working on to put in my 51 Mercury Coupe.
  20. hombres ruin
    hombres ruin
    Its really hard to get anything to fit that i have spoken to many people who use that scrubbing pad made of metal wire stuff and they make it fit and swear by it..i just dont want metal elements flying into my carb
  21. Tequila Bob
    Tequila Bob
    from Michigan
    Here is my third flattie. 48 Ford, Hillborn injection. This is the oldest living example of a Hilborn Fuel Injection. unit number 16. Built in January, 1950. Original non-stack unit. Magneto is by Harmon Collins.
    This engine goes in the 31 lowboy Ford roadster that was built and raced by Pete Dean of San Diego in the early fifties. It was called Mother's Cookies.
  22. Love it! My 308 is .100 over
  23. acme30
    acme30
    from Australia
    here is mine - hopefully pics will work.
    I wanted mechanical accelerator linkages............... yes I know cable is easlier but I want what I want so 3 days latter :oops:
    And here is a motor shot from the other side
    Engine is an 8BA flathead with a merc 4 inch crank - almost ready to go together for the final time. Need to run some oil lines and check valve to head clearance then that should be it :)
  24. CheatersPete
    CheatersPete
    Can we have more info on the modification made on this blower set up?
  25. acme30
    acme30
    from Australia
    Thanks for the interest
    Blower is a GM453, manifold is a 2 carb Luberg (Australian) machined flat with a custom plate to the blower - BDS blow off valve fitted to front of adaptor and pressure relief valve fitted to snout. Carb adaptors - custom machined as is the rear cover plate. Carbs are blower referenced 94's
    Blower snout is a modified M90 from a V6 Commadore. Oiling of blower is via main oil feed from block (oil feed and return lines not run yet - oil goes in the side of the blower and drains back to block via internal lines in adaptor plate -then back into block in front of oil breather).
    Custom pullies - tension on belt is via alternator - hoping to get away with 1 v belt but if it slips will chnge to 2 belts.
    Have a good mate who did all the machine work:)
  26. CheatersPete
    CheatersPete
    thanks for the details! nice set up!
  27. cully33
    cully33
    This is my lot.
  28. AV88
    AV88
    Here is mine 8ba , early Navarro heads , early edelbrock slingshot intake ImageUploadedByTJJ1334056716.975632.jpg
  29. AV88
    AV88
    And my other stock heads offy regular dual intake ImageUploadedByTJJ1334056889.749773.jpg
  30. here is the one going in my '32 Tudor
