Floating Hubcaps
Discussion in 'The Hokey Ass Message Board' started by Kage, Feb 7, 2012.
  1. jjsound
    jjsound
    Different part of town.
  2. HotRodHon
    HotRodHon
    Anybody got a picture of one of those?
  3. Crystal Blue
    Crystal Blue
    Sorry about the OT pic :eek:
  4. stamierdodge
    stamierdodge
    I've never seen the floating road runner 'caps in person,but A friend of mine once told me he found a semi-trailer,back in the '80's,parked behind a small closed-down factory,I think in Wyandotte,MI...FULL of those caps![/QUOTE]
    and wtf did he do with them?!
  5. Crystal Blue
    Crystal Blue
  6. Frankie47
    Frankie47
    from omaha ne.
    Thank you.
  7. 1 KooL "MoFo"
    1 KooL "MoFo"
    On the right car they look kool I.M.O.
    oh ya they been around for a long time uesed on " KUSTOM'S "
  8. 46jimbo
    46jimbo
    so the spinner/center csp stays stationary while the outside of the hubap spins?
  9. afaulk
    afaulk
    OK, stop this already LMAO! I wear trifocals and can't take too much of this....seriously though cool as ice.
  10. stealthcruiser
    stealthcruiser
    Any time.
  11. 46jimbo
    46jimbo
    if the center stays stationary, i think this would be cool as hell done with a lancer style hubcap with the checkered pattern around the outside. look forward to seeing them on your car Kage, should look sweet.
  12. Frank32
    Frank32
    Nice, keep the updates coming
  13. Hdonlybob
    Hdonlybob
    Way cool, and yes I am old enough to remember them also!!!
    Keep the pics coming.
    Cheers......
  14. Kage
    Kage
    from Delano, TN
    I have finished my floating caps. here are the final pics. I have to videos I will get uploaded in the next day or so.
    I screwed the all thread into the tapped spindle and then cross drilled it so i could still use the cotter pin. I then ran a nut to the base of the all thread to help snug it against the spindle and to act as a stopper for the cap.
  15. SHIFT DISTURBER
    SHIFT DISTURBER
    from NOR CAL
    Would love to see the finished product!
  16. Kage
    Kage
    from Delano, TN
    I have a couple of videos to put on here but I have had trouble loading them. Hopefully I can get them on here this weekend.
  17. SHIFT DISTURBER
    SHIFT DISTURBER
    from NOR CAL
    looking forward to em!
  18. 60galaxieJJ
    60galaxieJJ
    Can't wait to see the vids
  19. resqd37Zep
    resqd37Zep
    from Nor Cal
    I've seen guys go as far as moving the valve stem to the backside of the wheel and welding up the hole on the front side. I think they're kool for parking lot cruising but when you hit freeway speed they have a tendency to swing back and forth on the spindle nut. Guys have been doing this forever and a day now.
  20. 59KUSTOM
    59KUSTOM
    I like the idea. There was a green Merc that used to go to Lead East that had floating caps & they were always a big hit. They are absolutely a traditional idea.
  21. chaos10meter
    chaos10meter
    from PA.
    Doing some now on a 48 Chev Aero Cp.
  22. Kage
    Kage
    from Delano, TN
    Those caps will work good. what size all thread did you use? I used 3/8's
  23. chaos10meter
    chaos10meter
    from PA.
    I used 5/16" only because I had some.
  24. SHIFT DISTURBER
    SHIFT DISTURBER
    from NOR CAL
  25. slim tempo
    slim tempo
    Totally mother frikkin cool and kind of queer....In a good way.
  26. chaos10meter
    chaos10meter
    from PA.
    I bolt a small after market valve stem into the hub cap original hole using a chrome washer (to fill the oversized hole)for looks and then drill and mount the valve stem on the back side of the rim.
    Yes then ya have to crawl under the car to check the air pressure
  27. R. Seghi
    R. Seghi
    My thought exactly.
  28. rev. munster
    rev. munster
    from houston,tx
  29. bonez
    bonez
    from Slow lane
    Ahaha, that was a good one.
    Sometimes it only needs to be not liked by one "special" person and the sheep crowd will do the rest.
    A circular slot where the stem would poke out...then you'll have a REAL floatin hubcap edge :D
    No really, theyre hella trippy. Good job
  30. go-twichy
    go-twichy
    you got to relax friend. the topic is on how to make your hubcap's stationary. not a real serious matter. just something fun to look at. sorry it tickle's my funny bone.
