'35 - `37 Ford Pickup Pictures
Discussion in 'The Hokey Ass Message Board' started by Iceberg, Nov 25, 2003.
  1. Iceberg
    Iceberg
    I'm looking for some more ideas for a '35 - '37 Ford pickup. I have a chance to pick up another cab & ch***is cheap. Here is a picture of my current truck.
  2. RC
    RC
    Here is my MBU 36. It's a work in progress. 327 with p-glide 55 chev rearend, 39/40 banjo wheel.
  3. RC
    RC
    Here is a couple more.
  4. bdrake
    bdrake
    Here is my '37 project. Maybe getting a little to smooth for some people but I'm the only one I need to please. I have a monster 1.5 inch chop, homebuilt hidden hinges and bumper bracket holes filled. The firewall battery mount was removed and filled in with a section from a '36. I want to lower it a bit more, has a dropped axle front with parallel leaf rear.
  5. bdrake
    bdrake
    From the rear is my home built bed, made a filler piece for the spare tire dip in the running board but settled on gl*** rear fenders. Building a rolled pan for under the bed and still need to make my tailgate. I cut the top below the rear window to leave it full size.
  6. plan9
    plan9
    heh RC, pretty sure that 2nd one is icebergs truck in a former incarnation [​IMG]
    bdrake, truck is looking pretty nice... whats the current drop on it? id like to go lower with mine, would be nice to have a base reference.
  7. RC
    RC
    I had that feeling, but gray or dark gray it still looks cool. Wonder what it's wearing now? [​IMG]
  8. RC
    RC
    [ QUOTE ]
    [/ QUOTE ]
    My truck needs to be dropped BAD! It's still stock up front. I have not decided on how I want to do it yet!
  9. plan9
    plan9
    [ QUOTE ]
    [/ QUOTE ]
    from the pics he hooked me up with, its primered black [​IMG]
  10. bdrake
    bdrake
    [ QUOTE ]
    [/ QUOTE ]
    My truck has a Ch***is Engineering front and rear suspension. Four inch drop axle, reverse eye spring, split bones and modified 37 spindles. Yea, added disk brakes. I also raised the front crossmember a little for maybe another half inch drop, not sure that was worth it and it is pretty close to the oilpan. Current front wheels are 15x5's, from a 55? Chevy, with some 145radials.
    The rear currently has 1.5 inch lowering blocks on the parallel leafs. Not much weight on the rear yet. All the springs are new so they may settle a bit more when I start driving.
  11. Crestliner
    Crestliner
    Mine has 59A engine alum. heads, fenton headers, elect. ign., columbia rear, spider caps nad banjo wheel. All this and more and it could be yours(bt it ain't cheap)
  12. bdrake
    bdrake
    So what are you thinking to do with the next one Iceberg?
    Here are a few other pics I have. Wish I had a good picture of the bed cover as it was pretty nice.
  13. bdrake
    bdrake
    Here is a local truck I've always liked. Notice the extended one piece hood top. Scratch built bed that is shorter than normal works good with the chop.
  14. bdrake
    bdrake
  15. bdrake
    bdrake
    This one is from the HammerArt site
  16. 50Fraud
    50Fraud
    Iceberg, the truck you have is really close right now. Here's a complete list of everything a '35 truck needs to look great:
    Dropped axle
    16" Kelseys
    Big & littles (WWW, or not)
    Done!
  17. Stone
    Stone
    [ QUOTE ]
    Dropped axle
    16" Kelseys
    Done!
    [/ QUOTE ]
    Pardon my ignorance(I'm learning)But what are Big & littles?
    I figure that 16"Kelseys are wheels.Any pics of them or should I just do a search?
  18. Iceberg
    Iceberg
    I'm thinking of making a fenderless truck next time.
    As far as my current truck goes;
    I have big & littles on her now (600-16 front & 700-16 rear). I should have went with 550-16 on the front for more drop. I'm into three new WW Coker's (fronts & spare) about $400 and I don't want them to just sit in my garage.
    I dropped the nose 4" with a Durant monoleaf. I'm still thinking of installing a dropped front axle.
    I like Kelsey wires, however I'm not sure they look that much better than the Ford wires to go through the h***el of changing them out.
    I plan on installing a blower on my flatmotor next winter. The ****** and rear end were rebuilt last month (3:78s installed) so it is time to break them!
  19. Iceberg
    Iceberg
    Another
  20. Iceberg
    Iceberg
    One more
  21. plan9
    plan9
    yah the truck looks good as it sits, so unless you are gonna put a hemi in it, it just needs a little something extra...
  22. Iceberg
    Iceberg
    My favorite before shot w/ the greyhound rad cap & blackwalls. I have a urge to drive her down to the farm and plow some fields! Which way to Green Acres?
  23. plan9
    plan9
    stone - do a search for kelseys. big n littles is bigger rim/tire combo in the back, and smaller rim/tire combo in the front, emulating the race car look... also,depends on the ride, you dont want to go too big or too little
    bdrake-thanks for the data.. helps quite a bit [​IMG]
  24. JamesG
    JamesG
  25. JimC
    JimC
    from W.C.,Mo.
    Did you say fenderless?
  26. Stone
    Stone
    Thanks guys.I know I'll learn alot here.
  27. motor mikey
    motor mikey
    from hanover pa
    Here you go
  28. speedo
    speedo
    from Dayton,OH
    JimC
    Where the Hell'd you get a picture of my truck???
  29. JamesG
    JamesG
  30. 50Fraud
    50Fraud
    Stone,
    16" Kelseys were aftermarket wire wheels made by Kelsey-Hayes to fit '35 Fords, or other early Fords with the same bolt pattern. They were a favorite with hot rodders of the '40s.
    For a further discussion of "big & littles" on wheels of this general type, see the earlier thread "Black '35 Wires and Blackwall 'Stones".
