Mid-40s Ford Truck Rear Axle
Discussion in 'The Hokey Ass Message Board' started by Richard D, Feb 27, 2012.
  1. How strong are they? Limited slip possible? Problems to look for? I just got a truck with a banjo axle and no torque tube and know really nothing about them.
  2. treb11
    treb11
    If its the one that came with your new 1/2ton project, the banjo is useful for converting an earlier banjo diff to a universal joint input. about the same strength as prior year (pre war) banjos. no LSD
  3. Yes, I changed the ***le to say "truck"
  4. If you're going to beat on it, get a 9-inch; it's not the weakest thing around, but as noted it's desirable for converting other rearends to open drive.
  5. anteek
    anteek
    What ratio were most of these?
  6. I want to run a banjo behind a flathead in a T. Someday. I'd do as suggested and pu a 9" in the truck. Again, someday.....
  7. Mike W.
    Mike W.
    If it is the one with rear axle to drum shear pins carry a few spares if you keep it and I would even check the ones in it now.
  8. KS Fats
    KS Fats
    I've had three of them apart over the years and all three were 4.11 but I think there may have been a 3.78 and a 4.27 option .....don't have my references available now so can't verify that....fats
  9. F-6Garagerat
    F-6Garagerat
    i have a 42-47 open drive banjo center with 37-41 axles/tubes in my "A" pickup. the open center came with a stock ford 3:54 ring and pinion.
