Any ideas to cover old molding holes?
Discussion in 'The Hokey Ass Message Board' started by greasy53, Feb 27, 2012.
  1. greasy53
    greasy53
    Ok, don't have the cash to get all the old molding holes filled on my 53 ford customline. I like the look of the car without the old molding on it. I painted her sky blue.
    Any ideas on how to mask, cover or disguise the holes?
    I'm thinking sticker flames would be ****ty looking....lol!
  2. Muttley
    Muttley
    Anything you do to cover them is going to look worse than just leaving the holes open.
  3. jcmarz
    jcmarz
    from Chino, Ca
    maybe some chrome bullets?
  4. HOTRODPRIMER
    HOTRODPRIMER
    You already painted the car?,,how about duct tape?:D
    Seriously,,,unless you use some sort of stick on black or chrome molding to run from the front to the rear of the car or individual plugs to fill the holes would be the only option I can think of. HRP
  5. hotroddon
    hotroddon
    You could put on some really rad bolt on skulls from the Biker Shop :D
  6. junk yard kid
    junk yard kid
    just tell people there speed holes.
  7. drptop70ss
    drptop70ss
    from NY
    Drill more holes all around them so it looked like you made them on purpose..or maybe tint some bondo with your paint and fill them that way!
  8. Well, the right way to do it would be to grind the paint back off, back the holes with a piece of copper, and either fill them up with weld, or weld in small pieces of sheetmetal to fill them. A less desirable, but sometimes workable way to do it also would be to use body filler - I've read lots of bad about it but I've also seen bigger rust holes filled with it with no obvious ill effect.
  9. Mike W.
    Mike W.
    Another option is to solder plugs from the inside if possible, just don't use acid core solder.
  10. Get some of those spikes that are on dog collars .... that would look really cool PLUS it would keep the squeegie-man away from your car. ... just a thought.
  11. You could put lots of those "bullet hole" stickers on them.
    That would be Kick***....
  12. williebill
    williebill
    Nothing you can do that won't look like hell. just leave them,and if you ever paint again,weld them shut first. I'd much rather see the holes than some half*** attempt to fill them.
  13. Special Ed
    Special Ed
  14. Cerberus
    Cerberus
    You put the cart before the horse. I suggest putting the trim back on. Otherwise, weld the molding holes closed with plugs and repaint. Filling the holes with bondo won't last. I welded the molding holes closed with plugs on my '55, ground flush, very light coat of body filler, primer, later painted.
  15. Get a real hot pin-up model to stand in front of them - Nobody will even notice that you have a car!
  16. chaos10meter
    chaos10meter
    from PA.
    Play Dough, you can get it in different colors.
  17. traffic61
    traffic61
    from Owasso, OK
    One word.
  18. metal man
    metal man
    X2. Either cover them with the moldings or nothing at all.
  19. greasy53
    greasy53
    after reading the responses, I guess just leaving them is the way to go...not to say there weren't some funny ideas..lol..dog collar spikes...LOL, bullet hole stickers...LOL...funny ****.
  20. Crankhole
    Crankhole
  21. 60 ford
    60 ford
    I'd just put the moldings back on until I could repaint it, and then fix the holes.
  22. If you don't want to weld the holes. You could cut some small patches of metal and use 3M panel bond to attach them . Then a small amount of filler and of course primer then paint.
  23. nofin
    nofin
    from australia
    Holes down the side? Just tell people it's a Buick.
  24. metalman
    metalman
    I must admit I'll never understand taking chrome off a car and filling the holes unless it's to put moldings from another make on it. I guess my thought are why would you want to make your car look like a cheaper one. You have a Customline, why turn it into a plain jane Mainline? Polish out your trim and put it back on!
  25. x10000.
