1954 Chevy headliner???????????
Discussion in 'The Hokey Ass Message Board' started by ttarver, Feb 27, 2012.
  1. ttarver
    ttarver
    from austin
    Has anyone ever installed a headliner in a 54 Chevy car? I am getting ready to do the interior on my car and I have a few questions.
    Does the gl*** have to come out on this particular car to do the headliner?
    What can I use to replace the crumbling, old tack strips that you staple the headliner to?
    I am guessing the wind lace goes in first. Is this correct?
    Any help from guys that have actually done this would be greatly appreciated!!
    Also if I decide to take it somewhere, does anyone know of a good headliner shop in the Austin Texas area that would do a good job?
    Thanks for the help guys!
  2. ttarver
    ttarver
    from austin
    Bump for the evening crew!!!!
  3. huskersnb2
    huskersnb2
    from nebraska
    the windows stay in the car remove all inside chrome and trim and take it out slowley the old one and you have to have the metal bows also i used some staples on mine when i did it a a most of the materail just pushes up inside of the crack you can google it that will help out alot trial and error is what i did
  4. ttarver
    ttarver
    from austin
    Did you replace the tack strips. Mine are a little rough.
  5. stichbitch
    stichbitch
    Windows don't need to come out. Windlace goes in first. You can replace the crumbling tackstrip with new, I use a rubber one. There are different sizes of tack strip, try googling it, that should come up with a supplier for ya (The supplier I get it from won't sell w/o a tax id). I use rivets to install the new tack strip. Be patient and you'll do fine.
  6. ttarver
    ttarver
    from austin
    Awesome! Thanks. I was hoping I would not have to take out the gl***. I hope I can tackle this without a bunch o wrinkles.
  7. parklane
    parklane
    Depending on material used for the headliner, you can use steam to get wrinkles out. Thats what car plants use.
  8. Lone Star Mopar
    Lone Star Mopar
    Theres a reason its not cheap ! Ive taken one out in one piece and thats hard enough...but take your time and you might get it in right. In a pinch an old fanbelt might be used in place of tackstrip. Seems like my guy started in the middle , then worked his way foward and back. They also had a steam wand, good luck.
  9. Jalopy Joker
    Jalopy Joker
    did you order a headliner for your car? doesn't company sell tack strips. or whatever, for install? yes, installation is a real challenge if your first try.
  10. ttarver
    ttarver
    from austin
    I found some tack strips through national chevy ***ociation. They are on the way! Ez-boy rod interiors is making the headliner.
  11. 54fierro
    54fierro
    from san diego
  12. ttarver
    ttarver
    from austin
    Thanks 54fierro!! That should really help a lot.
  13. Chevy54
    Chevy54
    from Orange, CA
    Heres a couple shots of mine while being done if it helps at all...Good luck man!
  14. stichbitch
    stichbitch
    Just to for warn ya the tack strip from national chevy you may have to split in half for the rear window and the windshield, it will most likely be too thick.
