Elrod Model A Coupe Thrash - Flathead V8 time
Discussion in 'The Hokey Ass Message Board' started by Elrod, Feb 16, 2012.
  1. draggler
    draggler
    Couldnt say that dash has been seen before.{purty schvweet}
    You've got the right help to get it done .
    she'll knock some socks off for sure at lsru and then some!
  2. draggler
    draggler
    Man thats an awsome metamorphesis!
    Schvweet dash conglom.
    Looks like youve got the right folk in tandem for a healthy completion!
    It'll knock socks for sure lsru or not!
  3. full foot notch
    full foot notch
    from orlando
    for a second i thought the guy was in orlando cause theres a Betos mexican food here, didnt know there were others
  4. Tomcats30
    Tomcats30
    Looks great Elrod!...can't wait to see how you mount the wishbone to the crossmember.
  5. choptop36
    choptop36
    looks good man, i really like the dash
  6. Dig the coupe . Subscribed ..
    Will be watching closely..
    Thanks for sharing..
  7. Anderson
    Anderson
    ....I believe we can claim our Betos as the original, the "master" Betos if you will.
  8. Great to see progress! I'm learning a lot watching this thread too.
  9. Elrod
    Elrod
    Yeah. I saw some pictures online of (I think it was you) that just moved the pedals over a full bolt hole width. That is not going to line up with the notch in my firewall or the steering column. I'm going to move it inward about one inch and drill new holes.
    Thanks man. I think I sold you the rear window section for your Franken A. How's that coming along?
    Basically going to do the same thing that is on my 32 K member. There is a lip that protrudes forward with a wishbone ball mount in it. Right now, the wishbone ball is falling directly infront of the F1 crossmember, so a gusseted tab will be installed.
  10. titus
    titus
    I heated and reworked the pedals so they fit where i wanted them.
    JEFF
  11. Elrod
    Elrod
    Excellent idea. I was just brainstorming how to cut out the bolt holes and flip them over mirror image and re-weld them in but probably much easier to bend the pedals.
  12. titus
    titus
    We ended up filling the old holes anyways, maybe cut out a sqaure and patch it and start fresh, if i remember correctly the pedals were really tight to the boxing plates when we were all done so kinda had to move it over as much as we did.
    we also used a f1 steering box in the car, i think we mounted it really close to where the stock box went. i probably should have cut the flange off and welded a new one on but i opted to shim it, it worked fine.
    jeff
  13. Elrod
    Elrod
    A few updates...
    Filled the old master cylinder hole in the F1 Crossmember and re-drilled on inch closer to the center of the car. This lines up the pedals with the hole in the cowl allowing the steering column to fit nicely between the pedals. The clutch linkage is also tucked in close to the frame rail.
    We then welded in the center trans crossmember in the frame.
    Also dressed up the front crossmember to flow smoothly into the re-worked 38 front crossmember motor mounts.
    In working on the frame, Anderson and I really realized that...
    FIRST, it's really flimsy! Man there is a lot of twist and not much support in these Model A frames. So next step is to go onto the frame table. boxing plates are on order and arriving today.
    SECOND - It's gross working on this frame all crusty, so now that the motor mounts are located in the frame, it's off to the sandblasters. That should be back by Monday. More updates to come when the frame starts getting boxed.
    brEad likes this.
  14. Elrod
    Elrod
    Frame returned from the sand blaster's shop. Boy it's nice to work with clean parts...
    I also bought some "Easy Weld" backing plates off of ebay. These are the kind with the little tabs that hold the plates flush to your rails, but are still just slightly undersize to allow for a very nice easy weld and great penetration.
    They fit perfectly, but had to do a little t******* for the body bolt holes and for the trans crossmember and front motor mounts.
    Took the pedal ***embly apart to change out the bushings. WOW! that pin is in there really tight. Had to heat, drill and beat the living ba-jezus out of it before it finally gave up.
    I found out that I could really use a new pedal shaft as the original one is worn. I thought the bushings were supposed to wear out, not the pedal shaft!
    ANYONE KNOW WHERE TO ORDER AN F1 PEDAL SHAFT?
    Trimmed the driver's side boxing plate to sink the pedals into the frame a little bit. I wanted the linkage as close to the side as functional to place the pedals close to stock Model A as possible. I love how it turned out.
    Next up will be the driver's side boxing plate. I'll be back at it again tonight after work.
    brEad likes this.
  15. ironandsteele
    ironandsteele
    Nice!! You're making great progress.
  16. chopt top kid
    chopt top kid
    Awesome!!! Keep up the good work!!! I ordered an F1 pedal shaft from Mac's a while back and they had to back order...
  17. Elrod
    Elrod
    Hmmm.. Thanks for the tip on the Mac's pedal shaft. I just saw that they had them, but I also have read a lot about long waits from them. I wonder if JobLot has them... I may call them first.
  18. titus
    titus
    Looking really good.
    my machinist buddy made me a new one.
  19. brad2v
    brad2v
    THese guys might have it http://johnsf100.com/
  20. Elrod
    Elrod
    Hey brad2v! Thanks for the promising lead, but I'm only seeing the slightly later F100 stuff. I wonder if there is a johnsF1 store?
    I called Mac's and they did say they are 2 weeks back order on that shaft.
    UPDATE: JobLot is the company that makes those shafts and they had them in stock when I called.
  21. brad2v
    brad2v
    What year are the F1 pedals? their catalog shows 48-56, I just ***umed it was in here somewhere. I dealt with them a while ago on some frontend stuff and they were great.
  22. Anderson
    Anderson
    F1 is '48-'52. F100 is '53-'56.
  23. Elrod
    Elrod
    Last night's task was to finish boxing the frame for strength. Instead of using cage nuts in the frame, I wanted to have access to the body bolt holes, so drilled the boxing plates...
    And this is what they look like after drilling the holes
    Anderson went to town on the welding while I was drilling, and it turned out VERY nice. Here are a few shots of the finished boxing.
    Stay tuned for the modification of the stock brake cross shaft to operate the rear emergency brakes.
  24. Hitchhiker
    Hitchhiker
    I've been throwing that idea around myself. Looking forward to see what you do. looking good man.
  25. draggler
    draggler
    Oops sorry for the double reply,,issues of the time log kind.
    Yes shes all mocked up with the rear window section. She
    is stalled for now ,thanks for askin! Yours is coming along nicely btw.
  26. Elrod
    Elrod
    Put in some more work on the coupe this weekend. Actually my wife said she would be happy to help out, so I put her to work prepping a lot of small parts for paint. That put a big smile on my face!
    [​IMG][​IMG]
    Anderson built the bracket to support the un-split wishbones. I ordered one of the 50s style worn wishbone ball caps. My wishbone was actually not worn out at all, so it fit nice and snug.
    At this point, it was time to pull the frame off the frame table. Wow! Much heavier, but EXTREMELY strong now. No flex side to side. Test fit the front axle. Success!
    Close up of bracket
    Now time to flip the frame over and weld up any small spots that were not accessible on the frame table.
    Major milestone achieved this weekend. Frame table fabrication finished! Front end placed, pedals located and engine in place!!
    I'm sure it will come apart a dozen times again before I'm done, but excited that it started to look like a car again. Thanks again to Anderson and my wife for spending a Saturday hacking on this thing with me.
    brEad likes this.
  27. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    This is all coming together really nicely. No sense in doing something on this scale if you're not going to do it right,,,,, and if this wrong, well I don't wanna be right (in my best Coming To America reverend voice).
    Trans mount turned out great!
  28. roseville carl
    roseville carl
    Lookin good!!.................
  29. Elrod
    Elrod
    Thanks guys. I really want this to be early 50s period correct, and I've been collecting parts for about 10 years to do it right. I'm really happy that it is finally coming together.
    This is the image that I have stuck in my head, and is the inspiration for the build...
  30. Wide Whites
    Wide Whites
    from N. Texas
    Looking good! I like the inspiration pics too! Are you going to run hood sides?
