TECH - Wheel Reversal, Buick Hoops/Ford Centers
Discussion in 'The Hokey Ass Message Board' started by LSGUN, Mar 1, 2012.
  1. LSGUN
    LSGUN
    from TX
    I wanted to take a crack at making a pair of wheels the "old-timey" way and capture the look. As most of you know, many of the new reversed wheels today don't have that good looking slope you see in the little books. Back in the 50's Buick wheels were a popular choice to rob for hoops due to the wider width.
    Here is how I did it:
    I started off with a pair of mid 50's Buick wheels.
    Note the slope of the wheel hoop, this is important and will make sense later.
    Center punch the rivets.
    Drill out the rivets but don't go all the way through, knock out the rest with a punch.
    Hell, get your girlfriend involved. :D
    Knock out the center.
    Here is the early Ford/Merc center going in.
    Clean up the drop center with a grinder.
    Knock the center in the front side "reversed" of the wheel hoop and line up the holes (sometimes they do) for the rivets. They didn't in this case because I wanted a certain back spacing.
    You can now see the "reversed" deep dish look with the beveled hoop.
    Now spin the wheel and check to see if it runs true. With a dial indicator get the runout to less than 1/32", adjust as needed.
    Tack it up and check it again, then finish weld watching your heat.
    Teach your girlfriend to weld and then weld up the rivet holes last.
    Grind down her boogers if needed. :p
    You can see the difference from the wider Buick hoop and the deep dish look from being reversed.
    wandi harry likes this.
  2. LSGUN
    LSGUN
    from TX
  3. Looks good. Nice tech article
  4. ALEISTER
    ALEISTER
    Great tech. Love the look of a true reversed wheel. Killer!
  5. Nice job, thanks!
  6. falcongeorge
    falcongeorge
    from BC
    Good stuff. this ones a keeper.
  7. dirtbag13
    dirtbag13
    looks great , stupid question but did you just leave the valve stem hole on the back , or weld it up and move it up front ?
  8. LSGUN
    LSGUN
    from TX
    I just left the holes on the back. You can weld up the originals and drill new ones up front if you'd like. It's a cleaner look with them in the back IMO.
  9. BJR
    BJR
    OK someone's gotta say it, Great picture of your girlfriend drilling the wheel. See I did notice the drill and the wheel.
  10. need louvers ?
    need louvers ?
    I saw the drill too! I promise...
  11. Great post ... I've got a pair of wheels I have already separated, just haven't welded them up yet. One thought did cross my mind though (maybe you did this) ... before you bolt the wheel onto something in order to check runout before welding, make sure to check IT's runout first. Would be a horrible thing if you "squared up the wheel" using a bent axle or warped rotor.
  12. SLCK64
    SLCK64
    Nice!!!
    (note to self; get girlfriend like that :D)
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Glad he posted that also. Them painted toe nails had me there for a bit :eek:. But all is good.
  14. n.z.rodder
    n.z.rodder
    Baahahahaha, I had to go back and check for the painted toe nails.:D
    Great tech, subscribed for later use.
    Scotty.
  15. TexasSpeed
    TexasSpeed
    from Texas
    Nice tech, man.
  16. meengrinch
    meengrinch
    from ipswich ma
    drill tool?????????????
  17. Great tech, but ya kinda lost me here. :rolleyes:
  18. TexasSpeed
    TexasSpeed
    from Texas
    Now that I think about it.. I should have made a tech about making a cheap and easy frame jig out of a trailer frame.
    Crud.
  19. norm ricardo
    norm ricardo
  20. 34toddster
    34toddster
    from Missouri
    Un-Fair advantage, You will win Tech of the week.
  21. Pretty sweet!!! ...on both counts!
  22. terd ferguson
    terd ferguson
    Buick hoops are the best looking hoops in my opinion. Nice job and nice write up!
  23. hotrodA
    hotrodA
  24. I've been looking for Bob Bleed's old tech on this, but the pics are gone, Thanks, I have some '56 Ford wheels I need to reverse on themselves (2" BS), and The pics help a lot... especially the drilling one... :)
  25. shocker998md
    shocker998md
    TIGHT! I love the deep dish.
  26. DD COOPMAN
    DD COOPMAN
    BTTT...just for the "drilling"! DD
  27. Nice work!
    I think you may be trying to sway some votes ! :D
  28. OoltewahSpeedShop
    OoltewahSpeedShop
    Nice.... and the wheel tech was pretty good too. :D
    Great info.
  29. Anyone know what all year and make wheels have the taper, and what widths?
  30. GARY T.
    GARY T.
    from S.W. Pa
    Nice work!
    Are the centers and hoops from 15" or 16" wheels?
