Projects Where do I get 7" glass sealed beams with Signals
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Mar 3, 2012.
  1. harleycontracter
    harleycontracter
    Trying to fing 7" gl*** seal beams with signals that don t show amber till you turn on signals. Thought I saw some at the NSRA National once . Anyone know???
  2. Moneymaker
    Moneymaker
    Do you mean these?
  3. harleycontracter
    harleycontracter
    I'd like to not see the amber lights till the signal is turn on. Thanks though
  4. Moneymaker
    Moneymaker
    Then I think that the clear turn signal version is your only other option.
  5. 31 Coupe
    31 Coupe
    Try 70's F100 lamps and change the parking light bulb to Amber.
  6. harleycontracter
    harleycontracter
    Really ? There is a parking light bulb in it? Where would you get those?
  7. How can it be a sealed beam, with a removable bulb?
  8. harleycontracter
    harleycontracter
    Good question hmmmm
  9. skidsteer
    skidsteer
    Try Vintique for halogens with signals that you can't see until lit.
  10. bgolden
    bgolden
  11. seb fontana
    seb fontana
    from ct
    To my knowledge you won't find a sealed beam..7" reflectors that take a h4 type bulb...Speedway has them, can get retro to includ park light..MAY not be DOT approved, I have a pair and they don't put out anyway near what my Halogen sealed beams do, would only be good for trailer queens......
  12. gimpyshotrods
    gimpyshotrods
  13. greaseyknight
    greaseyknight
    from Burley WA
    X2, I have a set of cheap all plastic ones off of ebay, they put out really good light on high in good weather. But once it starts raining you can barely see a thing. The Hella's are the best out their with replaceable bulbs, don't know if they come with a turn single light inside.
  14. gimpyshotrods
    gimpyshotrods
    Yes, they do: http://www.rallylights.com/detail.aspx?ID=487
