Exhaust paint
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 4, 2012.
  1. Blue One
    Blue One
    from Alberta
    Anyone have any successs with painting exhaust pipes ?
    What I mean is the whole exhaust system.
    I know some guys have painted headers, and I have had limited success with that as it usually doesn't last long.
    Thinking about the new exhaust I want to build for my 36 sedan.
    Going to order Porter mufflers in 2 1/2" size.
    I'll buy a mandrel bent kit and go from there. I don't want to go to the expense of stainless.
    I know an alternative is having the system ceramic coated, not sure I want to go that route either.
    Just wondering if it's worth the effort to paint the pipes.
    Will it last ? And if so what product and prep ?
  2. Blue One
    Blue One
    from Alberta
    No one ? Maybe it's not worth thinking about ?
  3. I painted mine with BBQ black Rustoleum. It seems to be holding up well.
  4. Imperial Kustom
    Imperial Kustom
    VHT ceramic works really well.
  5. morac41
    morac41
    Hi ..... Just spend the dollars and get a stainless system and never worry about it again....
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    I had the pipes on my 27 coated with high temp powdercoating. I wasn't sure if it would hold up as the pipes were over 20 years old when I had them done, but surprisingly once they were sandblasted and coated they have been holding up great. Ceramic coating is much better, but this was a fairly inexpensive alternative.
    Don
  7. Frankenstein57
    Frankenstein57
    I bought some high temp paint for my headers from KBS coatings, I painted the welds on my exhaust system and it has held up well. Mark
  8. 19Fordy
    19Fordy
    Spend the extra $$ for ceramic coating. You will be happier in the long run. I have never seen any paint that really worked over time -especially with a flathead.
  9. 1971BB427
    1971BB427
    from Oregon
    Painted my headers and my exhaust sytem with VHT Flameproof rated 1300-2000 degrees. It's holding up great on headers and exhaust.
  10. themoose
    themoose
    Another option is to use the aluminized mandrel bent pipe to build your system.Its much cheaper than stainless and IMO looks just as good ceramic coating. I built my system 3 years ago and it still looks like the day I finished it. I mig welded the joints and cleaned and painted each weld joint about 1/2" out on each side of the weld using silver high heat paint and they too have not discolored or rusted.Worked great for me.
  11. Blue One
    Blue One
    from Alberta
    That's interesting as the mandrel bent kit I'll buy will likely be aluminized.
  12. Bar Ditch
    Bar Ditch
    from Tacoma
    BBQ, used it many times and holds up reasonably well.
  13. Dapostman
    Dapostman
    I'm using stove black, It was used extensively prewar.
  14. 55Hydramatic
    55Hydramatic
    x2 Painted my manifolds with it and now have 16,500 miles on the truck, still looks like the day I painted it, also painted the rest of the exhaust with it too and its holding up just as good.
  15. Mike Miller
    Mike Miller
    Sanded the pipes with 80 grit then cleaned with paint prep solvent and coated with VHT,
    hung it up to dry till the next day. The first picture was 3.5 years ago with 4 trips to the salt, just pulled the headers this week to re do. The pipes still look OK. The second picture is from 2 years ago.
  16. Jim Bouchard
    Jim Bouchard
    I have had good luck on the exhaust pipes with Eastwood's exhaust coating. However it usually burns off the first 6-8" behind the manifolds/headers. Scotch brite then a wipe with solvent to get any oil off.
  17. thebronc4019
    thebronc4019
    from New Jersey
    I used a product Eastwood sells. I think they market it as an exhaust manifold paint. I followed the directions exactly as they appeared on the can which included having to sandblast the pipes. I sprayed two coats on this stuff on the entire system south of the header collectors and it has held up perfectly for 7 years. I only bought a pint can because you don't need much. Great stuff, highly recommend.
  18. tommy
    tommy
    I use the brush on stainless steel header paint from Eastwood. It has held up well over the years. Headers are hardest on the paints. Your exhaust behind the headers will not get as hot as the headers and the paint will hold up quite well. I'm too poor for the expensive stuff.:D
    My buddy just this week painted over his 427 Ford cast iron headers that he had professionally done 15? years ago. He's very picky. I don't know what system that was used but it was state of the art back then. He was no longer happy with it and brush painted it to clean it up.
  19. chinarus
    chinarus
    from Georgia
    What's a good source for the aluminized mandrel bent exhaust kit?
    All I have ever used is ordinary steel tubing bends.
  20. cylhead
    cylhead
    John Deere Muffler Paint-the best there is
  21. hr31hr
    hr31hr
    from PA
    +1
    After two years it is just turning a little grey where it dumps out of the headers.
  22. Bigchuck
    Bigchuck
    from Austin, TX
  23. themoose
    themoose
  24. hr31hr
    hr31hr
    from PA
    Comparison pictures..
      98.2 KB
