Customs TECH WEEK: 20$ STEERING COLUMN with minimal tools.
Discussion in 'The Hokey Ass Message Board' started by Ian Berky, Mar 6, 2012.
  1. Ian Berky
    Ian Berky
    So this tech is no rocket science, but I think this is something that most people can do in the garage with very minimal tools and time! I hope this can help the few like me who don't wanna spend 200$ plus dollars on a column.
    First off, find a wheel you like and pull the shaft out of the column.
    Then go to your local metal supply shop and hopefully they sell all this good stuff......
    I decided to go with the round cup for this one.
    measure your column to fit your application best and make sure to leave at least 3" of shaft out the tubing
    these are the 2 bearings you're gonna need, you can get them at OSH or at most hardware store for 5$ a piece.
    also get an allen screw and an O ring that fits tight on you steering shaft.
    find the center on your steering cup and use a whole saw to cut the hole for the tubing.
    Insert your bearings on both ends of the tube and slide it down the steering shaft until the bearing rests on the wheel, then slide your cup for correct spacing/gap. and tack it in place and finish weld it
  2. Kona Cruisers
    Kona Cruisers
    I have been wondering what people use for the bell portion. Great tech!!
    Also, what locates the shaft lenght wise in the tube? just a question
  3. Ian Berky
    Ian Berky
    now clean the welds smooth
    next and final step, drill and tap the retaining screw.
    slide the O ring in between the bearing and screw.
    and you're done.... as for the steering joint, have someone with a lathe or?? fit the joint to the shaft and you just save yourself a bunch of $$$$$
  4. cgc1958
    cgc1958
    Pretty slick!
    I especially like the OSH parts numbers and such, thanks.
  5. damagedduck
    damagedduck
    from Greeley Co
    damn nice!!! as stated above NO#'s and every thing..thanks
  6. what a guy !!!!!! thanks man .... summer is here i can feel it ...
  7. Fenders
    Fenders
    You can also use exhaust pipe for the tubing if you have any lying around....
  8. Wish there was a metal supply store like that here... Nice job.
  9. falcongeorge
    falcongeorge
    from BC
    Good one! this contest is heating up...
  10. rottenleonard
    rottenleonard
    Where did the piece on the right go?
    Just want to make sure i've got it all as I'm definatly saving this one, cool post!
  11. thunderbirdesq
    thunderbirdesq
  12. Nice Ian! Thanks for sharing!
  13. Crankhole
    Crankhole
    Very nice...but how did you get a 1-3/8" bearing into a 1-1/4" tube?
  14. Ian Berky
    Ian Berky
    Thank you very much guys!
    The piece on the right is just to show there are options as far as cups go. I went with the round one for this one, fits better for a futuristic look!
  15. Crankhole
    Crankhole
    He used the one on the left...not the right.
  16. Ian Berky
    Ian Berky
    Fits like glove without ANY tapping! just a push with the thumb!
  17. I believe you can use either one of the two, not both, just depends on what look you want. Great Tech!!!
  18. Crankhole
    Crankhole
    Are you sure that's a 1-1/4" tube? That's a whole 1/8" difference.
  19. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    VERY COOL! Thanks! I wont be buying another $200 column, thats for sure.
  20. K13
    K13
    He must have taken a pic of the wrong label. That one is for square tube 1 1/4" x 1 1/4"
    Nice work Ian! (I mean on the column not the wrong picture:D)
  21. Noland
    Noland
    awesome. very well done.
  22. Ian Berky
    Ian Berky
    100%
  23. Ian Berky
    Ian Berky
  24. Ian Berky
    Ian Berky
    Sorry guys.... Hopefully this human error won't make my tech obsolete! :(
  25. K13
    K13
    LOL just delete the picture most people don't read through the whole thread anyways:D
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    Except for that little picture hiccup you have done a great service. This a very well illustrated and explained tech piece. Handy for anyone building any early car.
    Thanks and how did you hook that horn up anyway? :)
  27. BenDaPirate
    BenDaPirate
    Ian you are the ****ing man!! Was trying to figure out what to do without spending a fortune on a new column. This will work perfectly! Great tech! Thanks!
  28. ronbo48
    ronbo48
    your column is very cool. I will build one on my next car. get tech article
  29. Dakota
    Dakota
    from Beulah, ND
    Rather than Drill and tap the Shaft, couldent you use a 3/4 slip collar with a set screw?
