An American rare quickee
Discussion in 'The Hokey Ass Message Board' started by Rex Schimmer, Mar 4, 2012.
  1. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I found the attached advert in the August 1950 issue of Speed Age. If I had my choice between the Downey Machine two speed quickee or the Allard one from "limey land" I would go for the Downey Machine it's trick, American and probably works reliably.
    Rex
  2. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Rex
  3. striper
    striper
    How does the 2 speed work Rex? Any idea?
    I'll take that Cyclone for $250 BTW.
  4. Stovebolt
    Stovebolt
    The Spalding Bros used a Pat Warren q/c in their 12 port powered T.
    i'd have either .... especially at those prices.
    You didn't read that Kevin :D
  5. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I am sure that one set of gears (both speeds) spin on a shaft with needle bearings and have a dog ring face on one side of them, then there is a dog ring that is shifted between the two gears to select either one speed or the other. Pretty common method, all of the NASCAR ******s shift this way, motorcycles also. So to shift you just let off the gas for a split second, pull on the shift lever and you are in the next gear, no clutch.
    Rex
  6. emiliedk
    emiliedk
    from denmark
    Hi Rex..thanks for that! I have one of those Cyclone quickies. Cyclone Kevin made 5? in the old mold! not trying to highjack the thread!
    that 2 speed sounds cool though!
    -Palle
  7. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I am sure that if someone sat down with an early quickee and some time you could come up with a two speed conversion that could literally bolt on to an existing quick change. I wonder what the market for it would be? If you look at the add it says the conversion parts are $129 !!!! I couldn't see anything for less than a thou today and you would have to have enough interest to be able to take advantage of some qty discounts on getting the parts made.
    Rex
  8. alchemy
    alchemy
    Here's mine. Not a two speed though.
  9. Gofannon
    Gofannon
    Spaulding Bros car. I believe they had the first one made.
  10. MATACONCEPTS
    MATACONCEPTS
    Cooks is still there on Telegragh. I've gotten driveshafts there.
  11. 38FLATTIE
    38FLATTIE
    from Colorado
    Rex, I think you should do it-I know you can! I could use 2-speed conversions for my Halibrand and Frankland.
    Want me to send you one? Lol!:D
  12. Bruce Lancaster
    Bruce Lancaster
    I think Halibrand once made a 2-speed version of the big Champion rear...the picture I saw was of a 1960's rear engine Offy car, in which it allowed engine to be ****ed right against the rear without need for an elaborate transaxle.
  13. alchemy
    alchemy
    Halibrand made two-speed quickies in the V8 and Champ sizes for sure, and maybe in the A/B size also. It didn't add any length to the housing. You sometimes see housings with the weird square boss on the lower right side. I think they sometimes used the same housing but didn't machine the boss out for the extra gear stuff. I think the one in this pic has a plain cover laying over the boss.
  14. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Buddy,
    I have done some very preliminary layouts when I had my Hildabrand V8 quickee apart but right now I am trying to focus on getting my lakester off the drawing board and into steel and aluminum.
    Rex
  15. Little Wing
    Little Wing
    from Northeast
    Pat Catalog,,also "American and probably works reliably.
    "?? Gimme a break
  16. 38FLATTIE
    38FLATTIE
    from Colorado
    Rex, I had to see if you would take the bait-can't blame me for trying!
    If you build a lakester, I'm sure it will be first cl***!
