Anyone know of a nice simple, easy to wire, minimum number of wires, horn relay? Apparently i need one to make my horn work, news to me. Thanks
Auto Zone has a one wire relay with a blade type fuse I ran mine to the bat, side of my starter switch works fine..
I am using one from autozone that is for a '63 Chevy truck. I has on hot wire, one wire to the horn and a ground that runs to the horn botton/switch. I have wired them up hot, just using a hot wire and a starter ****on. if you don't lay on the horn forever at a time it will do just fine.
Thanks guys, sounds good to me. I couldn't ever remember using a relay before,i just wired them in, but thats what i was told to use. I guess i don't use a horn much? You know what the one wire relay is for, because thats the first question they're going to ask ?
PnB suggested '63 Chevy Truck... Standard Products P/N HR117 with Spade terminals HR125 with Screw terminals If those are too big there are small plastic units that work well but are less traditional looking...
