1932 Roadster project
Discussion in 'The Hokey Ass Message Board' started by AULIZ, Mar 9, 2012.
  1. AULIZ
    AULIZ
    Today I got paintjob ready. It was "small Christmas" after long 5 month working with body and frame.
    Rgds,Aulis
  2. ChuckleHead_Al
    ChuckleHead_Al
    That looks cool, what color is that? Great job.
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    what size are the tires?
    kidcampbell71 likes this.
  4. DenverFlash
    DenverFlash
    Love that color! More photos!
  5. AULIZ
    AULIZ
    Thank You very much.
    Color is Olive Green 2K Acryl (glasurit). 10% matting base increased.
    Tires are 28", both front and rear.
    Wheels 1936 Ford 16x4.
    Aulis
  6. Harrison
    Harrison
    Love that color and the '39 dash!
    Looks similar to this one I saw at Columbus in 2010.
  7. Louie
    Louie
    from NJ
    looks great, where did you get those big posters?
  8. AULIZ
    AULIZ
    Posters are made here in Seinajoki city (Finland). Advertising agency print those out to the cloth. something 50euro (70usd) ea.
    Aulis
  9. Ditto on the dash. Nice touch.
  10. Deuce Daddy Don
    Deuce Daddy Don
  11. 60 ford
    60 ford
    Looks great, can't wait to see it finished.
  12. AULIZ
    AULIZ
    Thank You Sirs.
    I put some more pictures when frame has got color etc. and when all going back together. Monday I go to pick up interiors from West-Coast, 50miles from here, and can´t wait to see how all are done,....... I have give instruction and pictures from 40´s - 50´s rod interiors when I left tempered 1939deluxe sofa + plywood panels there.
    Rgds, aulis
  13. She's a beauty!
  14. Royal Deuce
    Royal Deuce
    from Sweden
    I like the dash, What is it?
  15. AULIZ
    AULIZ
    1939 Deluxe has given Dash, Column.
    Aulis
  16. 3wLarry
    3wLarry
    from Owasso, Ok
    If you are using that WWII oxygen tank as a fuel tank...it only holds about 6 US gallons.
  17. AULIZ
    AULIZ
    I was think that it takes 25-30litre and if You say 6 gal = little under 25litre.
    That´s enough for 80-100miles, OK.
    Aulis
  18. AULIZ
    AULIZ
    Good Morning Steve,
    Cam not arrived yet, but it will come just right time! I try to do all "dirty jobs" ready before I start to go over engine and rear end.
    Maybe engine has been done before I bought project from Norway. I was look with ledlights and mirror inside and there are new Isky springs, SS valves and hollow lifters,... if Im lucky, need only change that old Harman&Collins cam and look all over,...
    Rear end will be bigger problem. I have bought new 3.25:1 ring and pinion (´35 and later) and I have decided to fit it inside 1932 original rear. I also pieced rearaxle yesterday and I can say that before I have had 39 and later rear axles and those are very much different system inside like this ´32 axle,.... but ,,... hot rodding idea is that You must have different ideas and sometimes those take very much time and planning,... For example pinion gear must cut, make new thread, bore hole thru for driveshaft and make keyway thru, . Have somebody done that job earlier?
    ****** I opened yesterday before come out from garage and it was like brand new.
    I was lucky because both cars (1932 and 1939 deluxe) have been 40-60years pieced in barn (norway) and all parts are very good condition and maybe not so much kilometers behind.
    Rgds,
    AULIS
  19. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    What size luan did you use? My auveeco clips fit like **** and that's after opening them up a bit because they would not fit at all on 1/8" thick luan. I'm almost convinced that trim screws are going to replace those damn clips!!!
    Roadster looks awesome!!
  20. AULIZ
    AULIZ
    Thanks.
    Panels are plywood (4mm = + 1/8") and corners are steel. I made using englishwheel, so can have curved corners both ways.
    Clips I bought from C&G Early ford Store (escondido, CA), B 20015 - door upholstery clips - few dollars 50pc.
    Aulis
  21. harleycontracter
    harleycontracter
    Looks great I too like a different color
  22. ct1932ford
    ct1932ford
  23. AULIZ
    AULIZ
    Just picked up interior and hood belts (originally FinnishArmy belts from 50´s).
    Aulis
  24. Royal Deuce
    Royal Deuce
    from Sweden
    Looks great are we gonna see you at the A-Bombers show this year.
  25. AULIZ
    AULIZ
    Hello,
    If car is ready and works good, maybe I come to A-bompers.
    Last summer I was not spend so much time in Sweden, like I did past.
    Aulis
  26. LowA100
    LowA100
    Here is what it will look like done! I have had it done for 3 years now. Cant wait to see your finished
  27. Hitchhiker
    Hitchhiker
    What is the canister in the trunk to the right of the fuel tank?
  28. AULIZ
    AULIZ
    I like that Brown roadster very much. Black interior and wheels with hub caps makes it very very nice. Color is also "timeless", cl***ic!
    Is that dash + steering column 1940 ford?
    Small roundend ganister is old toolbox. Maybe from tractor, old catepillar, car,...I do not know what it´s originally, but looks good and rather good shape.
    aulis
  29. Harrison
    Harrison
    LowA100's car has a '39 dash. Column drop is a '40 piece.
    JH
