Anyone ever install a 57 Buick grille in a 57 Chevy?
Discussion in 'The Hokey Ass Message Board' started by fordnutz, Mar 10, 2012.
  1. This was popular back in the late 50's and early 60's. Anyone everdone the swap? Pat
  2. Vintagevin here on the HAMB installed one on his 57 red Nomad.
    I'll look to see if I have pictures of it.
  3. Orn
    Orn
    The other way around, 57 Chevy grill in 57 Buick.
  4. Rusty O'Toole
    Rusty O'Toole
    A local guy had one in his 57 Bel Air hardtop around 1960. He kept the car for years and years, I used to see it around from time to time.
  5. Ralphies54
    Ralphies54
    Put one in my 57 last winter,not to hard to do. I used the smaller of the two sizes grills. Lots of cutting to the Buick grill,so once you start there's no going back so it's going to be either a nice custom grill or a pile of junk potmetal. Unfortnately I didn't take any"during"pictures but I do have some Afters that I'll try to post when I find them.
  6. MikeRose
    MikeRose
    from Yuma, AZ
  7. Ralphies54
    Ralphies54
    Found a few pictures,it's tight in my garage so they are close up.
  8. SquireDon
    SquireDon
    from Oregon
    That grille transplant looks great. What a clean look.
  9. Pharouh
    Pharouh
    The AMT model kit has that option. Looks cool.
  10. 296 V8
    296 V8
    from Nor~Cal
    Nice downgrade
  11. That was the only way to get an "A" in shop cl*** in '62...........
  12. zman
    zman
    from Garner, NC
    that's what I was thinking.
  13. Homemade44
    Homemade44
    The Buick changes include 57 Chevy head lights and hood spears. I don't get it.
  14. rld14
    rld14
    It's original at least. :rolleyes:
  15. Rebracer
    Rebracer
    The current issue of Hot Rod Deluxe has a black 57, with a Buick grille.
  16. 57belair
    57belair
    from Michigan
    Congrats to ralphies54 this is the way a finished
    install should look.
    Ends rounded around bumper ends and cut to neatly
    tuck under top bar.
    Have seen so many cobbled installs so it is nice to see
    one so nicely done.
    The grille in my '57 was installed in Jan. 1958
  17. Kustom7777
    Kustom7777
    from Austin, TX
    i remember seeing that particular swap in several of the "little books" from the 50s. i've always thought that was one of the nicer grille swaps.
  18. Molonewolf
    Molonewolf
    Heres one in a 49 Dodge.
  19. 40FordGuy
    40FordGuy
    One of those "just right" parts swaps...
    4TTRUK
  20. 40fordtudor
    40fordtudor
    sure helps that front end--
  21. What model grille did you use? Is it the Roadmaster that has a bigger grille. I never knew there was more than one grille in the 57 Buick line. Pat
  22. Custom Effies
    Custom Effies
    from Seattle
    I put one in my 56 Olds...
  23. Post Apocalyptic Kustoms
    from Outside
    I put one in mine and used the bigger of the two grills, which made it a huge pain in the *** but the end result was worth it because it flows better with the shape of the bumper then the smaller ones. Quite a bit of fab work to the front end to make it a bolt in though. The headlights were an experiment, they were actualy off road halogens, but drew too much power and burned up headlight swithces and i didnt want to hack up my wiring harness to install relays.
  24. It was so popular back in the day that the AMT 3-in-1 model kit made the grille bar a seperate part and gave you a '57 Buick grille insert for the stock bumper as an option.
  25. manyolcars
    manyolcars
    I have one in mine
  26. oldwood
    oldwood
    from arkansas
    I have a complete grill for sale out of a '57 Buick. It is not a roadmaster.
  27. spooler41
    spooler41
    Check out the pix on "vintage shots from days gone by" Post # 59075. It's a great looking '57 Chev with a 57 Buick grill .
    ...................Jack
  28. 40StudeDude
    40StudeDude
    LOL...in 1962, I was working in Fremont, NE...wrecked my '57 150 two door- center punched a '60 Ford...insurance paid for a new front clip...I bought a '57 Buick grille to replace the stocker...took it to the body shop to have them install it before the car got painted...I called to ask when I could come over to see the new grille and the guy that answered the phone said "I don't care how they do it in California, in Nebraska, that grille ain't going to fit in that opening. Come and get it." I never got that fine grille installed in my '57 but I did get it nosed and decked instead...
    R-
  29. jr9162
    jr9162
    Prettiest grille ever placed in a 57 Chebbie
  30. Nads
    Nads
    from Hypocrisy
    I did, back in 1986, I bought my grille from a junkyard for $50, those were the days. It was quite the job as I recall, not exactly a drop in, it needed a lotta chopping to fit and I couldn't use my stock hood latch, I had to do reverse hood pins it was a a pain in the ***, looked gorgeous though.
