53 chevy pickup
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by welderman5033, Mar 12, 2012.
  1. welderman5033
    welderman5033
    from ky
    I am building a 53 Chevy pickup. Is it best to do a frame swap or a subframe? I would appreciate some ideas or pictures for help. Thanks.
  2. tommyd
    tommyd
    from South Indy
    Welcome from Indy. Good luck with your build.
  3. tunes48
    tunes48
    from Kamloops
    like they always say. " there's nothing better than what they were born with ". Keep the original frame and work with it. You'll be happy you did.
  4. Willy_P
    Willy_P
    Welcome from Kansas. I'm going to have to do a frame-off, but plan to keep the original unless its tweaked.
  5. big tap
    big tap
    well I know what you are talking about I just got a hold of an 1985 el camino that has a bad *** engine and i mean bad ***. well now I was wondering if I could raplace the frame of my 1952 chevy truck with the one from the el camino does n-e one know if this is possible...
  6. EnragedHawk
    EnragedHawk
    from Waco, TX
    Welcome from Texas! I did an S10 frame, and I regret it, plus they really don't sit well with the HAMB. If you're just looking for IFS, go MII.
  7. welderman5033
    welderman5033
    from ky
    Wheres the best place to get mustang 2 suspension parts?
  8. 60 ford
    60 ford
  9. robleticia
    robleticia
    Welcome from Texas!
  10. CAMSHAFT666
    CAMSHAFT666
    I have a buddy that has a 48 with an olds g-body frame under it. Its been shortened, narrowed, and it was a ***** to mount the running boards. Stay with the original frame and go with an MII. Or go with a drop axel... motor swaps are easily than frame swaps...
  11. How about posting a proper introduction per the rules. Then you will have better luck after posting in the general forum area.
