292 Y-block oil filter adapter question
Discussion in 'The Hokey Ass Message Board' started by BobbyD, Mar 11, 2012.
  1. BobbyD
    BobbyD
    from Belmont NC
    I'm ****oning up the 292 I have for sale here on the hamb and when trying to ***emble the oil filter adapter last night the adapter fittings both check at .750 while the bolt hole in my block checks at .968, roughly 31/32. I do not have the stock cannister parts, is that where my problem lies? If so I'm in need of a stock cannister oil can deal. Or can i just machine a nut threaded .968 on one side and .750 on the other or is the stock piece a neccessity?
  2. 56 ford custom
    56 ford custom
    from Socal
  3. 40FordGuy
    40FordGuy
    I'd wonder if it's the correct adapter kit ? I don't know if the 239 thru 272 (54 thru 55) cans and parts were different....
    4TTRUK
  4. thunderbirdesq
    thunderbirdesq
    Sounds like maybe you're missing the stock seal plate and threaded retaining bolt that the adaptor threads into. You don't need the canister but you do need the plate and retainer.
  5. BobbyD
    BobbyD
    from Belmont NC
    Cool, then I'm in search of the stock ****, thanks man.....
  6. Cliffy
    Cliffy
  7. BobbyD
    BobbyD
    from Belmont NC
    Apparently there are 3 different ways to do this, I have the adapters which have the .750 block side and .750 filter side in both course and fine thread (Ford-Chevy) I guess, well Dennis Carpenter has it where the block thread is 1"-12, get rid of ALL the stock stuff and put adapter in place. See attached scan, this is the way to go when you have nothing to start with like me. Same part # as a lot od places carry, they should note the thread count so you know what your getting. Same Ford part# as all. B7A-6882-A
  8. d2_willys
    d2_willys
    from Kansas
    It has been awhile since I put a spin on filter adapter on my 317 Lincoln Y-block. As I recall, I believe I left the threaded insert in place and then put the o-ring and retainer plate right over the supplied threaded insert, or perhaps I threaded on the retainer plate. But I am pretty sure I DID NOT remove the original insert. The supplied insert is .75x.75 for threads and found that it would screw into original insert. All I know is that the filter fits fine and does not leak.
  9. Cliffy
    Cliffy
    Here is a pic
