Deuce Tudor, The Basic... Beginning
Discussion in 'The Hokey Ass Message Board' started by zombiescustoms, Jan 31, 2012.
  1. jackandeuces
    jackandeuces
    Dawg gone, there my roadster in the back ground....
  2. Weekend update:
    Got the grill shell and firewall ready for sealer
    and the hoods
    did some more work on the front frame horns, need to finish the spreader bar to make sure they are dead on
    my official garage helper, Hudson
    pushed outside to clean up the shop in the nice weather we are having
    both corners of the windshield posts were cracked, I stop drilled them and used oxy-acetylene to flow a little br*** in the crack, it made it easier to bring back the body line, and did not distort the area with a lot of heat.
    nice shot of where the two .45 cal slugs went through the cowl, still have not determined if I should keep them or not.
  3. I have set a HUGE goal of having this car drivable by May 19th, so it can make a lap or two at the Jalopy Showdown, I hope I can make it happen!
  4. Will Kimble
    Will Kimble
    Man, that is really neat - you are doing a great job!
  5. Got a few coats of sealer on the hoods and grill shell today
  6. Cut and fit the driveshaft and torque tube, and messed around with the rear spring to try to get the car to sit lower in the rear, I need to reverse the eyes still, and I think it needs one more spring left on top so its not so soft.
    Any tips on getting the center bearing out of the torque tube?
    I still need to cut the rear wishbones and remount the lug for them, I cut it off so I could clock the speedo mount to where the 32 was mounted.
  7. choptop36
    choptop36
  8. You've got a real beauty on your hands. Love the style.
    I've got a 31 Tudor waiting in the wings for after my roadster gets done. Taking her in pretty much the same direction as yours.
    Good luck with your goal of making the Jalopy Showdown. Looks like its well within reach.
  9. A bit more progress, got the spring eyes reversed, and the driveshaft cut and installed, shortened the rear wishbones, and reattached the mounting lug. Also got the front frame horns just about done and fit up the spreader bar. Sealed, painted and cleared the firewall, my wheels and tires should be here tomorrow, going to run 7.50x16 rears and 6.00x16 fronts on 16x 4 1/2 wheels. Just need to do the shock mounts and I will be able to do the final tear-down to spray the frame and suspension stuff, and then the ***embly starts. the plan is to run it in the blue sealer for the summer and then do the final paint next winter. Here are some updated pics with the new stance and because the weather has been super warm here I got out my other deuce to blow off the cobwebs.
  10. Got my wheels and tires mounted up today, they totally change the look of the car. I still think the front needs to come down about an inch. Threw the headlights and grill shell on for some pics:
  11. bubba67
    bubba67
    from NJ
    Very cool starting point. I love the transformation so far !
  12. greaser
    greaser
    This sedan is turning out GREAT! One of my all time favorites. Going to look awesome with or without fenders.
    Please remove any trace of the rodent by fixing the .45 holes. (JMHO).
  13. BOP-Nut
    BOP-Nut
    Man, you're really moving on her. Lookin' great.
  14. fab32
    fab32
    Whoa Baby!! Those wheels did the trick. Now you've got the "look" only have to finish the details. This one is going to be a winner. If I sound prejudiced...............check the avatar.:)
    Frank
  15. scotti32
    scotti32
    Wow cool project. I am building the same, stock height highboy
  16. 343w
    343w
    You are really rollin with the tudor project, you have gotten me fired-up for my own tudor project. I've been collecting parts for over 2 years and am finally at a point where I can start building, both with the parts and time needed to do so. Keep it rolling brother!
  17. Mike
    Mike
    Whoa Nelly! I just came accross this thread today. Man, It's hard to believe that's my old car. The transformation is amazing. This car is definately born again *****in'. I really liked that old machine and I did consider fixing the brakes, re-insuring and keeping it. I'm really glad that you and your dad got the car and I'll definately be watching it's new incarnation take place.
    Just plain *****in'.
    P.S. I still owe you the lower rear seat spring ***embly. Sorry I haven't sent it on, I have no real excuse :eek:.
  18. 3wLarry
    3wLarry
    from Owasso, Ok
    if you run 5.00/5.25x16 tires on the front instead of 6.00x16's, it will drop the front a little over an inch...and give it a nice rubber rake.
    kidcampbell71 likes this.
  19. I actually needed to raise the rear up about an inch to avoid needing to c notch,so it does have a bit more rake now.
  20. cruzr
    cruzr
    Looking good
  21. butchmerkel
    butchmerkel
    from oxnard ca
    Looks great. Did the br*** work ok ,can you get good paint results over the br***?
  22. 3Deuce40
    3Deuce40
    from Colorado
    I just finished mine and I used 5.60-15's in the front and it doesn't sit as good as I would like. Will the 5.00/5.25x16 work better?
  23. flatoz
    flatoz
    Do you want more rake? or want the tires up under the guards more?
    More rake = 4.50-4.75 tires
    Tires up under guards more = remove a spring leaf or two and reverse eyes on spring and more drop in the axle.
    ZOMBIECUSTOMS
    looking good, following with interest. love how its coming along.
  24. 3Deuce40
    3Deuce40
    from Colorado
    Thanks. Sorry to hi-jack the thread. ZombieCustoms, car is super cool. Keep the updates coming!
  25. milwscruffy
    milwscruffy
    Will you be tinning the brazed area before paint?
  26. Can you elaborate on the tinning of the br*** repair? I know if there is any flux left paint will not stick.
  27. Finished all the rear shock mounts and got the rear back in, also got the front F1 mounts cut and mounted. Need to finish the steering from the box to the spindles, and then I can tear everything down for starting the paint on the frame.
  28. Got a lot done the past week, stripped the car down to the bare frame, and prepped the frame and suspension stuff for paint, sprayed the frame today, and hope to have the front and rear axle ***emblies painted by the end of the week.
  29. drmrman
    drmrman
    from new Jersey
    Ive had my eyes on this. Cool build.
    Subscribed.
  30. greaser
    greaser
