"Gowjobs": Depresion Era Performance and Early day hop-up tech
Discussion in 'The Hokey Ass Message Board' started by MrModelT, Aug 13, 2010.
  1. Bigcheese327
    Bigcheese327
    I would think an aftermarket Ruckstell "Dual High" Transmission would be the pinnacle for a Model A until the availability of the Model B box and Zephyr gears later in the decade.
    I asked about the worth of mating an early Buick 3-speed to a Chevy 'banger a few months ago on VCCA and they kind of laughed at me, either saying the '28 'box was good enough, or why not go all the way to a T5.
    -Dave
  2. What about a AA two speed underdrive run backwards?
    Or is that what the Ruckstell is?
  3. Bigcheese327
    Bigcheese327
    The Ruckstell is similar in concept to a modern 4- or 5-speed overdrive, but without direct drive. Top gear is overdrive, and second splits the difference between 1st and 3rd. There is no 1:1 gear as there would be on the Ford trans. I don't know how it would accelerate, but it would improve top speed and reduce cruising RPMs. Just the ticket for a highboy roadster or speedster.
    -Dave
  4. I only mention the AA 2 spd because my dad just bought a restored A truck that has this done to it. I haven't seen the truck yet, the shipper hasn't delivered it yet but I should get to go for a spin in about 2 weeks. I will have to report back after then. It does seem like a period mod though
  5. MrModelT
    MrModelT
    Very interesting find Dave. I wonder if those were more common back then? I don't think I have ever seen one....so it might not be the most practical or obtainable option, but certainly a unique one. The taller Ruckstell "High" would sure give it long legs for racing at say Muroc, but you're right...I wonder what it would do to acceleration?
    Did the B gearboxes have better gear ratios then the A boxes?
  6. Bigcheese327
    Bigcheese327
    On page 29 of the book “Dry Lakes and Drag Strips: The American Hot Rod” by Dean Batchelor, there is a photograph of Regg and Dolores Schlemmer in a ‘31 roadster with Chevrolet-type hood sides, Packard wire wheels, and one of these transmissions.
    Here's another thread on MTFCA.com discussing them.
    That I don't know, but I have gleaned from the Monthly Banger Meets that one can run V8 gears in them and thereby get the advantages of the V8 trans without having to adapt the case.
    -Dave
    Outback likes this.
  7. MrModelT
    MrModelT
    I will have to give that a read over...
    Interesting! I didn't know that the V8 gear clusters would fit in a Model B gearbox. As far as I know, they won't fit in an A gearbox...but the B must have had a different case, like the V8 car...but without the integrated cast bell housing.
    That would be a hot setup! ...V8 or Lincoln gears in a B gearbox backing up a hot A motor....I like that! :D
    Outback likes this.
  8. Bigcheese327
    Bigcheese327
    Oh yeah. So, does this mean you're starting a fourth project?
    -Dave
  9. MrModelT
    MrModelT
    Oh goodness no, I have too many as it is......but it gives me ideas for building my own overdrive for the Roadster :D
    A B gearbox...with V8 or Lincoln gears coupled behind my T motor......perhaps with a Gallivan DOHC head....5-main T block.....Counterbalanced heavy crank and rods....Roots blower....
    ...need I say more? ;)
    Outback likes this.
  10. Bigcheese327
    Bigcheese327
    Nice! Are you familiar with the Art Gerrick car? He ran an A trans behind a T block. Supposedly at one time there was an aluminum pan available to do that.
    -Dave
  11. MrModelT
    MrModelT
    Yes I am actually. Nicely built car....will have to read back over the specs though about the trans..
    Outback likes this.
  12. MrModelT
    MrModelT
    It actually looks like an early V8 transmission and not a Model A. I have the feeling that the adapter, dry plate clutch and pan are all custom. Don't remember ever seeing these in production...
  13. Bigcheese327
    Bigcheese327
    I think on the Gerrick car, they are custom, but I heard somewhere (MTFCA?) about the aluminum pans for sliding-gear trannies.
    -Dave
  14. Clayton, I have been pondering a more highway friendly gear for my not yet built T roadster on an A ch***is/ A powered. I'm not sure when they started to turn up ( probably later than you are talking about) but I have been looking into a torque tube mounted overdrive unit. I ran across a picture this weekend of a '32 ch***is going together. I am not sure who's it is as it was in my "swiped pictures file" but I was thinking something like this...
  15. Looks like a Borg Warner unit?
    As an aside, I just picked up a '46 Lincoln OD for a different project and I am super geeked about it!
    Sent from my Droid using TJJ ****a!
    Outback likes this.
  16. youngster
    youngster
    from Minnesota
    It's acually not that hard to adapt the v8 box to the A motor. The same basic box was used from '32 to '39 in cars and into the early '50's. You put a '38 perameter on the years so I would go with a v8 box. The '37 & 8 boxes are what I would look for. Any of the post-'39 box gears can be swaped into the earlier box even the side shift models.
    Ron
  17. MrModelT
    MrModelT
    That is actually a very rare driveshaft mounted overdrive used as accessories for the 1939 and 40 Lincolns, but they may have been used as late as '48 as accessories for Ford and Mercury cars too. Not sure who made them though...
  18. 64 DODGE 440
    64 DODGE 440
    from so cal
    You could always go with a Columbia Rear Axle. Ran a couple of those back in the mid '60s and they work good. With the right gear set in the ****** you can split shift and get six even spaced gears. Did that in a '47 coupe with a built flathead. Wish I still had that one, but I got drafted and it went away.
    Outback and volvobrynk like this.
  19. youngster
    youngster
    from Minnesota
    The Columbia was first avilable in '35 or 6 so that would be a viable rear end to use.
    Ron
  20. Angry Frenchman
    Angry Frenchman
    I love b model fords!! just saying lol
  21. Johnny Speedster
    Johnny Speedster
    from Atlanta
    This one here has a Warford aux 6 forward gear and 3 reverse. Top end is around 90 mph.
    Outback, GuyW, Dannerr and 1 other person like this.
  22. You're up early, John :)!
  23. Bigcheese327
    Bigcheese327
    Here we go:
    -Dave
  24. MrModelT
    MrModelT
    Interesting Dave, interesting!
    If they were made by Fronty, there are a period accessory...but I think they would be RARE. They would have been issued during that transition period between the T and the A. Why go to that work to fit a an A trans/bell housing/flywheel to a Model T when you could just use an A engine from the start?
    ..I wonder how many they made?
  25. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The '32-'34 four cylinder transmissions do have an integral bell housing, but with the starter bulge in the appropriate place. You'd need a '39 style cover to go along with the '39-'48 ge****t for the shift forks to line up properly.
  26. Bigcheese327
    Bigcheese327
    How long did it take for the Model A speed equipment industry to get up to speed? Especially at the start of the Great Depression, I'm thinking that somebody with a fully built T motor might have wanted to keep that and just move into the newer trans?
    But yeah, I'm thinking hen's teeth on that one. Still, it's one of my reasons for deciding I'm not out of line to run an A trans behind my Chevy banger.
    -Dave
  27. MrModelT
    MrModelT
    Ah! Okay, now I understand how it works! Thanks for the clarification HEATHEN! :D
  28. Bodger45
    Bodger45
    Another priceless tidbit of hamb information. Thanks for sharing.
  29. 777
    777
    from Pasadena
  30. 64 DODGE 440
    64 DODGE 440
    from so cal
